Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 05-12-2013, 02:05   #1 (permalink)
schwantz's Avatar
Member: 4975
Thanks Meter: 607
...:: Download official Nokia firmware without Navifirm+ ::..
Things you need:
1. Latest version of Nokia Suite (version 2013_13_4_4)
2. usergroupsconfiguration.cfg file
You can download both files from Here
Installation:
1. First install Nokia Suite. Do not run after the installation is finished
[IMG]http://www.****************/nokia/1.jpg[/IMG]
2. After Nokia Suite installs, copy and replace the usergroupsconfiguration.cfg file to
C:\Program Files (x86)\Nokia\Nokia Care Suite\Product Support Tool For Store 5.0
if you’re running a 64-bit version of Windows.
Or C:\Program Files\Nokia\Nokia Care Suite\Product Support Tool For Store 5.0 if on 32-bit.
Running Nokia Suite and Downloading the firmware:
1. Open Nokia Suite. And select ‘Product Support Tool For Store 5.0′
[IMG]http://www.****************/nokia/2.jpg[/IMG]
2. When prompted, select ‘CareSuite External’ then hit ‘Sign-in’ button.
[IMG]http://www.****************/nokia/3.jpg[/IMG]
3. From the Menu, select Tools, then ‘Firmware Download’
[IMG]http://www.****************/nokia/4.jpg[/IMG]
4. Now enter the product code of your device, hit ‘Check Online’ button, to check the latest firmware version of your product code.
[IMG]http://www.****************/nokia/5.jpg[/IMG]
5. Then ‘tick’ ‘Optional Content Files and ‘Download’ to save your firmware.
6. Wait a few minutes for your files to download
7. You may now manually flash your Nokia device with the firmware you just downloaded.
TIP:
- Your firmware should be stored in the C:\ProgramData\Nokia\Packages\Products folder of your hard drive.
- If you need to download a different firmware version for the same product code,
I suggest you wait for your first download to finish, save all the downloaded files in a marked folder, then proceed with your next download.
- Partial List of Nokia Lumia product codes.
WARNING & DISCLAIMER:
This process is for experimental purposes ONLY.
I will not be responsible for any damage your device may incur during the manual flashing.
PROCEED AT YOUR OWN RISK.
The Following 124 Users Say Thank You to schwantz For This Useful Post:
Old 05-12-2013, 12:27   #2 (permalink)
schwantz's Avatar
Member: 4975
Thanks Meter: 607
I think this must be sticky
Old 05-12-2013, 13:43   #3 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 236
hi friend...yes this is great opcion...y test and this is working great...
Old 05-13-2013, 05:00   #4 (permalink)
BISMILLAH MOBILES's Avatar
Member: 610502
Sonork: 100.1618428
Thanks Meter: 158
NokiaCareSuiteForStore-2013_1_3_4_2
Hi Bro i want to know that will this setup work with Windows X.p-SP3 or not or work only on Windows7 32 or 64bit?
Waiting for reply....
B.R
Sheraz
Old 05-13-2013, 05:06   #5 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 726
bro still im not undarstand to do
Old 05-13-2013, 05:20   #6 (permalink)
Member: 656277
Thanks Meter: 185
B.R
Sheraz
yes it's work with windows xp service pack 3
The Following User Says Thank You to nitish1 For This Useful Post:
Old 05-13-2013, 05:44   #7 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 105
cant install nokia care
bro i cant install nokia care suite it says an error ...........
The Following User Says Thank You to killme12 For This Useful Post:
Old 05-13-2013, 05:58   #8 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,048
Download Link
Nokia_Care_Suite_PST_5.0_2013.
Old 05-13-2013, 06:06   #9 (permalink)
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 726
me too face to like this pro
Old 05-13-2013, 07:38   #10 (permalink)
3STAR MOBILE's Avatar
Member: 1374790
Thanks Meter: 219
hai bro i am face same problem
1 step install
Microsoft Visual C++ 2010
2 step install
nokia care suite install .
i am testing 100% working xp service pck 3
The Following 4 Users Say Thank You to 3STAR MOBILE For This Useful Post:
Old 05-13-2013, 10:28   #11 (permalink)
Member: 430612
Thanks Meter: 259
how to cope and replace the file usergruop.... i dont understand ,plz explain to me
The Following 2 Users Say Thank You to luyanda For This Useful Post:
Old 05-13-2013, 10:44   #12 (permalink)
Member: 430612
Thanks Meter: 259
plz ,i need help when i open product support tool ,i get only 1 option to sign (firmware respository for care ,there no option care suite external
Old 05-13-2013, 12:07   #13 (permalink)
Member: 773022
Thanks Meter: 5
Thank you bro! Good work everything working... (winxp-sp3)
The Following User Says Thank You to etsiketsi For This Useful Post:
Old 05-13-2013, 18:57   #14 (permalink)
DUNIYA JAMAL's Avatar
Member: 192810
Sonork: Some people NEED change
Thanks Meter: 854
Things you need:
Installation:
TIP:
100% working
Great sharing thanks a lot.
BR.
The Following User Says Thank You to DUNIYA JAMAL For This Useful Post:
Old 05-13-2013, 19:04   #15 (permalink)
gsmnitinmobile's Avatar
Member: 1595511
Sonork: nnn
Thanks Meter: 120
nokia flash file 2013 offFffffffff
The Following User Says Thank You to gsmnitinmobile For This Useful Post:
Page generated in 0.41686 seconds with 8 queries
