AbDuLlAH kHaWaR | 11-24-2012 22:09 | E5 error....................... Quote:
atf software version v9.15
atf lightning fbus flash started...
Number of image files: 5
processing image file :
D:\nokia\phoenix\products\rm-632\rm632_101.003_prd.core.fpsx
cmt type : Bb5
cmt algorithm : Xsr 1.6
secondary sending speed : 650000 hz
algorithm sending speed : 6500000 hz
program sending speed : 13000000 hz
message reading speed : 98000 hz
number of blocks : 475
entry point : 0x01fd
page format : 128k
maximum page size : 0x00040000
changing mode : Flash
booting phone via fbus...
Vbatt powering down <<<<
vbatt powering up >>>>
set vccio level done
set bsi load done
advancebox sendbootcodeex
initialisebootstrap_dct5 dir
bootflashmode_dct5
time starts here
bootflashmodedct5ex succeeded after 3 attempts
system_id_response_bb5 (0xc0) - 0 (0x00) bytes returned
number of sub blocks 7 (0x07)
1 system_asic_id 01
block length : 21 (15)
bb asic index : 0 (00) cmt
id dword 0 : 00000003
id dword 1 : 00000226
id dword 2 : 00010007
id dword 3 : 600c1921
id dword 4 : 02031104
2 em_asic_id 02
block length : 5 (05)
id dword 0 : 00000c35
3 em_asic_id 02
id dword 0 : 00000c30
4 public_id 12
id dword 0 : 14200219
id dword 1 : 7dda0344
id dword 2 : E0bda2ae
id dword 3 : 64bf09c0
id dword 4 : 677e5557
5 asic_mode_id 13
block length : 2 (02)
mode id : 00
6 root_key_hash 14
block length : 17 (11)
hash : 91 6f 75 21 7f 32 08 12 48 b1 5c 38 df c8 e8 1b
7 rom_id 15
block length : 9 (09)
crc 0 : E693ef0d
crc 1 : Ac22615b
checksum f7
searchforbootstrap_dct5..
C:\advancebox turbo flasher\nokia\bb5_loader\new\rapuv11_2nd.fg
boot file - version 012.014.00
boot file - revision 0x0003 (3)
ebb5protocoltype == new
preparebootstrapfile_dct5 replaced "silo" with "2nd\0"
preparebootstrapfile_dct5 replaced "boot_mediax" with "boot_media0"
searchforbootstrap_dct5 : No error - 0 (0x00)
secondary loader sent...
Transmissiontyperequest_dct5_newprotocol
transmission_type_request_bb5 get_protocols_bb5
transmission_type_request_bb5 : 59 01 3e 00 c0
transmissiontyperequest_dct5_newprotocol
fpif_transmission_mode_list_bb5 using default mode 04 ddrand2tx
transmission_type_request_bb5 : 59 02 41 02 04 00 36 03 00 00 61 1c
transmission type request sent...
Configurationrequest_dct5 (ram_size_bb5 0x0000)..
Mcu_configuration_response_bb5:
Messageid : 06
subblocks : 06
1 sub block id : 10 storage_device_id_bb5
block length : 0b
bb asic index : Cmt 00
device type : Ram 05
device index : 00
manufacturer code : 0000 -> flash
device id : 0000 -> not detected
extended/fixed id : 0000
revision id : 0000
2 sub block id : 10 storage_device_id_bb5
block length : 0b
device type : Mmc 04
device index : 00
manufacturer code : Ffff -> flash
device id : 0000 -> bad flash type
revision id : 0000
3 sub block id : 10 storage_device_id_bb5
block length : 0b
device type : Nor 00
device index : 00
manufacturer code : 0020 ->
device id : 0050 -> type not in database
revision id : 0031
4 sub block id : 10 storage_device_id_bb5
block length : 0b
device index : 01
manufacturer code : 0000 -> spansion
device id : 0001 -> not used
revision id : 0000
5 sub block id : 10 storage_device_id_bb5
block length : 0b
device type : Muxonenand 03
device index : 00
revision id : 0031
6 sub block id : 35 nand_driver_version_bb5
block length : 09
data : Xsr 1.6
checksum : 34
fls1sendalgocodeex..
Sendalgocode_dct5..
Searchforalgorithm_dct5..
Looking for all devices...
Searching algorithm files muxonenand (03) manid :0020 devid :0050 extid :0000 revid :0031
flash descriptor
device id : 0050
revision id : 0000
size : 20000000 (512 mb)
vpp info : 0000
erase10s : 1e
block1s : 32
berase1s : 02
reserved0 : 00
reserved1 : 00
reserved2 : 00
c:\advancebox turbo flasher\nokia\bb5_loader\new\rapuv11_xsr17_alg.fg
algorithm file - version 012.014.00
algorithm file - revision 0x0003 (3)
algo loader sent...
Sendcodestart_newprotocol :
Sendcodestart_newprotocol_dct5 : No error - 0 (0x00)
sendalgocodefile_dct5 : No error - 0 (0x00)
fur_control_addclient_bb5() asic_index_cmt (ready)
fur control ok...
Vpp enabled by software
using internal vpp
vpp enabled by software
flash_voltage_init_bb5 : 5c 01 26 04 00 00 00 00 d4
papub_keys_hash_req_bb5
phoneinforequest_bb5 (asic index 00 )
phone_info_response_bb5
papub_keys_hash_resp_bb5 2a
bb asic index : 00
cmt papubkeys hash:
Ccd9f80559ba50d9b3e274f9e7120be1ee4eea7c
read type : Fiasco_bb5_do_not_read_certificate (01)
sending store_certificate_request_bb5 (cmt 00 only)
certificate 1
asic index : Cmt 0
certificate 2
asic index : Cmt 0
certificate 3
asic index : Cmt 0
certificate 4
asic index : Cmt 0
certificate 5
asic index : Cmt 0
store_certificate_request_bb5 : 61 05 2b 0d 4e 50 43 00 00 00 00 00 00 00 00 00 00 2b 0d 43 43 43 00 00 00 00 00 00 00 00 00 00 2b 0d 48 57 43 00 00 00 00 00 00 00 00 00 00 2b 0d 52 26 44 00 00 00 00 00 00 00 00 00 00 2b 0d 50 41 52 54 4e 45 52 43 00 00 00 00 00 3b
store_certificate_request_bb5 : No error - 0 (0x00)
processpartitioninfo_dct5...
Partition info
partition blocks : 1
1 partition_info_bb5
bb asic index : 0x00 cmt
device type : 0x03 muxonenand
device index : 0x00
partition version : 00020000
spare : Ffffffff
num partitions : 00000004
partition 1
attribute : 00000002 ro
start address : 000a0000
partition 2
id : 00000004 demandonos
start address : 03bc0000
partition 3
id : 00000008 filesystem
attribute : 00000001 rw
start address : 0e780000
partition 4
start address : 1f140000
partition_info_request_bb5 : 64012f4f00030000020000ffffffff00000004000000030000 0002000a000003b20000000000040000000203bc00000abc00 0000000008000000010e780000109c00000000000a00000001 1f140000003c000077
partition_info_request_bb5 : No error - 0 (0x00)
processpartitioninfo_dct5 : No error - 0 (0x00)
starterase_dct5...
Blocklength : 0x4f (79)
erase blocks : 0x02 (2)
0 erase_area_bb5 0x12
block length : 0x1b (27)
device index : 0x00
0 : 00020000-0003ffff
1 : 00060000-004dffff
2 : 008e0000-0e77ffff
1 format_partition_bb5 0x19
block length : 0x2f (47)
device index : 0x00
format info id : 0x02000000
format info : 000000000000000a0000000000000002000000640000000b00 000002000000010000000000000000
erase_senderaseblock_bb5_nand
task in progress... Please wait...
Status_request_bb5...
1 sub block id : 15 status_nand_ok_bb5
block length : 0f
bb asic index : 00
device type : 03
device type : 00
num bad blocks : 0000000b
additional bad : 0000000b
correctable ecc : 00000000
erase_sendformatpartition_bb5_nand
block length : 0f
bb asic index : 00
device type : 03
device type : 00
successfully erased..
Time taken to erase : 00:00:04
flashing speed: 5.00 mhz (auto)
processing : Rm632_101.003_prd.core.fpsx
total blocks to write : 475
>> cmt rootkey hash cert : Ada
>> cmt rootkey hash cert : Keys
>> cmt rootkey hash cert : Primapp
>> cmt rootkey hash cert : Rap3nand
>> cmt rootkey hash cert : Sos+pmml
>> cmt rootkey hash cert : Pasubtoc
>> cmt rootkey hash cert : Papubkeys [ccd9f80559ba50d9b3e274f9e7120be1ee4eea7c]
>> cmt rootkey hash cert : Genio_init
>> cmt rootkey hash cert : Sos*updapp
>> cmt rootkey hash cert : Sos*dsp0
>> cmt rootkey hash cert : Ldsp
>> cmt rootkey hash cert : Sos*isasw
>> cmt rootkey hash cert : Sos+core
>> cmt rootkey hash cert : Sos+rofs1
continueflash_dct5 complete
status_request_bb5...
block length : 0f
bb asic index : 00
device type : 03
device type : 00
flashinfo.restartmode : 1
continue flash complete : : No error - 0 (0x00)
time taken to flash : 00:01:10
making delay between files for 5000ms
D:\nokia\phoenix\products\rm-632\rm632_101.003_c00.01_default_prd.rofs3.fpsx
cmt type : Bb5
number of blocks : 38
entry point : 0x0139
page format : 128k
Advancebox sendbootcodeex
bootflashmode_dct5
time starts here
bootflashmodedct5ex succeeded first time
1 system_asic_id 01
2 em_asic_id 02
3 em_asic_id 02
4 public_id 12
5 asic_mode_id 13
mode id : 00
6 root_key_hash 14
7 rom_id 15
crc 0 : E693ef0d
crc 1 : Ac22615b
checksum f7
Messageid : 06
subblocks : 06
block length : 0b
device index : 00
revision id : 0000
block length : 0b
device index : 00
revision id : 0000
block length : 0b
device index : 00
revision id : 0031
block length : 0b
device index : 01
revision id : 0000
block length : 0b
device index : 00
revision id : 0031
block length : 09
data : Xsr 1.6
checksum : 34
Sendalgocode_dct5..
flash descriptor
device id : 0050
revision id : 0000
vpp info : 0000
erase10s : 1e
block1s : 32
berase1s : 02
reserved0 : 00
reserved1 : 00
reserved2 : 00
algo loader sent...
fur control ok...
using internal vpp
bb asic index : 00
cmt papubkeys hash:
certificate 1
asic index : Cmt 0
certificate 2
asic index : Cmt 0
certificate 3
asic index : Cmt 0
certificate 4
asic index : Cmt 0
certificate 5
asic index : Cmt 0
starterase_dct5...
Blocklength : 0x0e (14)
erase blocks : 0x01 (1)
block length : 0x0b (11)
device index : 0x00
0 : 0d100000-0e77ffff
block length : 0f
bb asic index : 00
device type : 03
device type : 00
Time taken to erase : 00:00:00
processing : Rm632_101.003_c00.01_default_prd.rofs3.fpsx
total blocks to write : 38
>> cmt rootkey hash cert : Sos+rofs3
block length : 0f
bb asic index : 00
device type : 03
device type : 00
time taken to flash : 00:00:06
D:\nokia\phoenix\products\rm-632\wall-e_sw_mc001_alps_2g_3.0.fpsx
cmt type : Bb5
program sending speed : 6500000 hz
number of blocks : 2742
entry point : 0x0197
page format : 128k
bootflashmode_dct5
time starts here
1 system_asic_id 01
2 em_asic_id 02
3 em_asic_id 02
4 public_id 12
5 asic_mode_id 13
mode id : 00
6 root_key_hash 14
7 rom_id 15
crc 0 : E693ef0d
crc 1 : Ac22615b
checksum f7
Messageid : 06
subblocks : 06
block length : 0b
device index : 00
revision id : 0000
block length : 0b
device index : 00
revision id : 0000
block length : 0b
device index : 00
revision id : 0031
block length : 0b
device index : 01
revision id : 0000
block length : 0b
device index : 00
revision id : 0031
block length : 09
data : Xsr 1.6
checksum : 34
Sendalgocode_dct5..
flash descriptor
device id : 0050
revision id : 0000
vpp info : 0000
erase10s : 1e
block1s : 32
berase1s : 02
reserved0 : 00
reserved1 : 00
reserved2 : 00
algo loader sent...
fur control ok...
using internal vpp
bb asic index : 00
cmt papubkeys hash:
mass_memory_config_request_bb5 : No error - 0 (0x00)
no restore certificate found in image file
no erase data for this image...
processing : Wall-e_sw_mc001_alps_2g_3.0.fpsx
total blocks to write : 2742
block length : 0f
bb asic index : 00
device type : 01
device type : 07
num bad blocks : 00000000
additional bad : 0000ffff
time taken to flash : 00:06:37
D:\nokia\phoenix\products\rm-632\rm632_101.003_01.01_euro_qw1_prd.rofs2.fpsx
cmt type : Bb5
number of blocks : 249
page format : 128k
bootflashmode_dct5
time starts here
1 system_asic_id 01
2 em_asic_id 02
3 em_asic_id 02
4 public_id 12
5 asic_mode_id 13
mode id : 00
6 root_key_hash 14
7 rom_id 15
crc 0 : E693ef0d
crc 1 : Ac22615b
checksum f7
Messageid : 06
subblocks : 06
block length : 0b
device index : 00
revision id : 0000
block length : 0b
device index : 00
revision id : 0000
block length : 0b
device index : 00
revision id : 0031
block length : 0b
device index : 01
revision id : 0000
block length : 0b
device index : 00
revision id : 0031
block length : 09
data : Xsr 1.6
checksum : 34
Sendalgocode_dct5..
flash descriptor
device id : 0050
revision id : 0000
vpp info : 0000
erase10s : 1e
block1s : 32
berase1s : 02
reserved0 : 00
reserved1 : 00
reserved2 : 00
algo loader sent...
fur control ok...
using internal vpp
bb asic index : 00
cmt papubkeys hash:
certificate 1
asic index : Cmt 0
certificate 2
asic index : Cmt 0
certificate 3
asic index : Cmt 0
certificate 4
asic index : Cmt 0
certificate 5
asic index : Cmt 0
starterase_dct5...
device index : 0x00
0 : 08980000-0d0fffff
block length : 0f
bb asic index : 00
device type : 03
device type : 00
Time taken to erase : 00:00:01
processing : Rm632_101.003_01.01_euro_qw1_prd.rofs2.fpsx
total blocks to write : 249
>> cmt rootkey hash cert : Sos+rofs2
block length : 0f
bb asic index : 00
device type : 03
device type : 00
time taken to flash : 00:00:42
D:\nokia\phoenix\products\rm-632\rm632_101.003_u005.000_prd.uda.fpsx
cmt type : Bb5
number of blocks : 97
page format : 128k
bootflashmode_dct5
time starts here
1 system_asic_id 01
2 em_asic_id 02
3 em_asic_id 02
4 public_id 12
5 asic_mode_id 13
mode id : 00
6 root_key_hash 14
7 rom_id 15
crc 0 : E693ef0d
crc 1 : Ac22615b
checksum f7
Messageid : 06
subblocks : 06
block length : 0b
device index : 00
revision id : 0000
block length : 0b
device index : 00
revision id : 0000
block length : 0b
device index : 00
revision id : 0031
block length : 0b
device index : 01
revision id : 0000
block length : 0b
device index : 00
revision id : 0031
block length : 09
data : Xsr 1.6
checksum : 34
Sendalgocode_dct5..
flash descriptor
device id : 0050
revision id : 0000
vpp info : 0000
erase10s : 1e
block1s : 32
berase1s : 02
reserved0 : 00
reserved1 : 00
reserved2 : 00
algo loader sent...
fur control ok...
using internal vpp
bb asic index : 00
cmt papubkeys hash:
certificate 1
asic index : Cmt 0
certificate 2
asic index : Cmt 0
certificate 3
asic index : Cmt 0
certificate 4
asic index : Cmt 0
certificate 5
asic index : Cmt 0
starterase_dct5...
device index : 0x00
0 : 0e780000-1f13ffff
block length : 0f
bb asic index : 00
device type : 03
device type : 00
Time taken to erase : 00:00:03
processing : Rm632_101.003_u005.000_prd.uda.fpsx
total blocks to write : 97
block length : 0f
bb asic index : 00
device type : 03
device type : 00
time taken to flash : 00:00:19
total flash write time (flashing only) : 00:08:56
total flashing time (booting + erase + flashing) : 00:09:26
waiting for phone to go online...
Elapsed time: 1s
elapsed time: 2s
elapsed time: 3s
elapsed time: 4s
elapsed time: 5s
elapsed time: 6s
elapsed time: 7s
elapsed time: 8s
elapsed time: 9s
elapsed time: 10s
basic phone information
mcu version: V icpr82_11w16.3.13 15-06-12 rm-632 (c) nokia
imei plain : 358631040728644
imei spare : A358631040728640
imei sv : 33586310407286430f
phone model: Nokia e5-00
category : Classic phone
phone type : Rm-632
extended phone information
product serial number: 2a68b91aa
product code : 059c2j5
module code : 0204475
basic production code: 0590165
long production sn : 0
mcu sw version : V icpr82_11w16.3.13 15-06-12 rm-632 (c) nokia
hw version : 3009
rfic version : |vapaus_6.5 | mikki_1.1
dsp version : 12w24
content : Rm632_101.003_u005.000_prd
ahne version : 11
ape sw core version : 101.003
variant version : 101.003101.003.01.01101.003.c00.01
ape test version : V0.034
retu version : 35
tahvo version : 00
ape hw version : 256
ape adsp sw version : 256
wireless lan id : 6c:a7:80:ba:32:47
bluetooth id : 6c:a7:80:b9:f3:c7
cs type : Gsm850, gsm900, gsm1800, gsm1900, wcdma i, wcdma ii, wcdma viii
simlock information
unable to read sp data..
Waiting for phone to go online...
Elapsed time: 1s
elapsed time: 2s
elapsed time: 3s
elapsed time: 4s
elapsed time: 5s
elapsed time: 6s
elapsed time: 7s
elapsed time: 8s
elapsed time: 9s
elapsed time: 10s
phone type : Rm-632
hw version : 3009
dsp version : 12w24
ahne version : 11
retu version : 35
tahvo version : 00
simlock information
Security_test : Passed
phone_mode : Local
dcc id : Not used
factory set to : Full factory set
failed
factory set to : User data
failed
factory set to : Leave factory
failed
factory set to : Service center
failed
factory set to : Software upgrade
failed
factory set to : Production tune
failed
forcing test mode via buscheck...
Booting phone via fbus...
set bsi load done
bootflashmode_dct5
time starts here
1 system_asic_id 01
2 em_asic_id 02
3 em_asic_id 02
4 public_id 12
5 asic_mode_id 13
mode id : 00
6 root_key_hash 14
7 rom_id 15
crc 0 : E693ef0d
crc 1 : Ac22615b
checksum f7
Messageid : 06
subblocks : 06
block length : 0b
device index : 00
revision id : 0000
block length : 0b
device index : 00
revision id : 0000
block length : 0b
device index : 00
revision id : 0031
block length : 0b
device index : 01
revision id : 0000
block length : 0b
device index : 00
revision id : 0031
block length : 09
data : Xsr 1.6
checksum : 34
Sendalgocode_dct5..
flash descriptor
device id : 0050
revision id : 0000
vpp info : 0000
erase10s : 1e
block1s : 32
berase1s : 02
reserved0 : 00
reserved1 : 00
reserved2 : 00
algo loader sent...
fur control ok...
using internal vpp
bb asic index : 00
cmt papubkeys hash:
scanning simlock applet type...
Ok
pa_simloc30 applet detected
use "scan phone" button to check if this phone
uses a 15-digit nck or a 20-digit nck...
* firmware version downgrade will kill phone !!!
* manual full erase will kill phone!!!
* simlocks are in pm 120 only...
* pm 308 is write protected...
Elapsed time: 1s
elapsed time: 2s
elapsed time: 3s
elapsed time: 4s
elapsed time: 5s
elapsed time: 6s
elapsed time: 7s
elapsed time: 8s
elapsed time: 9s
elapsed time: 10s
reset life timer to : 0000:00
ok
plz helpp....it shows local mode and test mode after flashing but it shows white lcd after vibrate......
Ak' |
