10-05-2012, 05:26 | #1 (permalink) | |
Crazy Poster Join Date: Mar 2011
Member: 1543245 Status: Offline Thanks Meter: 6 | e52 simlock problem need help..... so i do full erase but before i full erase i had already a back-up of rpl....i flash it using highest version and the phone is now powering on emei goes 123456106543210,simlock is ok when i restore rpl emei is ok simlock is corrupted i dont have a back-up of simlock or pm is there a alternative solution.. heres the logs when i restore rpl... Quote:
thanks in advance...... | |
10-05-2012, 06:15 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | @ADATEL21 1. Authorize phone by ATF Network 2. Do level 2 recovery. if level 2 fail to recover simlock then Proceed to level 3 recovery. |
The Following User Says Thank You to malka4u For This Useful Post: |
10-05-2012, 08:00 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | That is your mistake that you backup only RPL and what about Sim Lock data ? So these problem arise . There is very very less posibility recovery PM after full erase. Level 3 will help you . Br -srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
10-05-2012, 09:11 | #4 (permalink) | |
Member: 1543245 Status: Offline Thanks Meter: 6 | Quote:
thanks for the reply,but before i full erase i try to back-up simlock but sad to say theres no chance because phone cannot go to test/local mode, it only vibrate.... is there any option to recover this problem?? TIA.... | |
10-05-2012, 11:08 | #5 (permalink) | |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Quote:
You can read full flash and recover simlock from full flash before erase if phone cannot enter local/test mode | |
10-06-2012, 10:11 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Its normal when phone cannot get local/test mode. You got to use level 2 recovery in order to BACKUP SIMLOCK. RPL can backup in DEAD MODE if phone is NOT erased, but PM/SIMLock can't. If you would have used level 2 or Backup Full Flash before erase, then we could solve it, but now only solution is to repair by level 3 Recovery, it'll cost you 25 SRP credit. BR | |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
