05-03-2014, 09:19 | #1 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 337450 Status: Offline Thanks Meter: 718 | E63-1 Unlock Problem CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 ERROR: Simlock Block Not Found in PM 308!!! << Maybe this is an SL3 Phone >> It is SL3? this old nokia phone? Thanks. |
05-04-2014, 01:30 | #4 (permalink) |
Member: 337450 Status: Offline Thanks Meter: 718 | Sure Thing! Here's the log... Code: Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeded After 0 Tries SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0CD00017 ID DWORD 1 : BC980052 ID DWORD 2 : 3A9DCAF3 ID DWORD 3 : 9440C0B1 ID DWORD 4 : 381BD843 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : C7 0C B0 73 24 05 6B C6 6A 82 43 47 F4 0D B2 D5 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 CMT Secondary Loader: D:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: D:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPIDOv11_XSR15_alg.fg SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) SendCodeStart_NewProtocol SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 54 04 01 00 00 00 A5 VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 PA PUBLIC KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 FlashInfo.RestartMode : Test Mode Process Done... |
05-04-2014, 11:02 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | This phone is SL3 and you need to BF it's HASH in order to Unlock. Direct Unlock isn't possible for this RootKey Hash. BR |
