09-02-2013, 15:10 | #1 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 258525 Status: Offline Thanks Meter: 44 | e63 after flash only vibrates help me ATF Software Version v9.90 ATF Box FBUS Flash Started... Number of Image Files: 6 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-609\RM-609_111.140.0058_79_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 13000000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 666 Entry Point : 0x0222 Page Format : 128K Maximum Page Size : 0x00040000 Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0BF0010E ID DWORD 1 : E1F25840 ID DWORD 2 : 72BF1183 ID DWORD 3 : CA0E6C17 ID DWORD 4 : 0D04681E 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B Checksum 0F SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_2nd.fg Boot File - Version 012.014.00 Boot File - Revision 0x0003 (3) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0068 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0068 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 Checksum : 04 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0068 ExtID :0000 RevID :0031 Flash Descriptor Manufacturer Code : 0020 Device ID : 0068 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 40000000 (1024 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPUv11_XSR17_alg.fg Algorithm File - Version 012.014.00 Algorithm File - Revision 0x0003 (3) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 PAPUB_KEYS_HASH_REQ_BB5 PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 327C6B67C95DA04A763DEFD4BA15C19FF16D9AE7 =========================================== PHONE FIRMWARE VERSION: 025.008 =========================================== Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 Certificate 5 Name : PARTNERC ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 50 41 52 54 4E 45 52 43 00 00 00 00 00 3B STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00020000 Spare : FFFFFFFF Num Partitions : 00000005 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00140000 Size : 029C0000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 02B00000 Size : 0EC00000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 11700000 Size : 1CA00000 Partition 4 ID : 00000027 Attribute : 00000001 RW Start Address : 2E100000 Size : 10500000 Partition 5 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 3E600000 Size : 00400000 PARTITION_INFO_REQUEST_BB5 : 64012F5F00030000020000FFFFFFFF00000005000000030000 000200140000029C0000000000040000000202B000000EC000 000000000800000001117000001CA000000000002700000001 2E100000105000000000000A000000013E6000000040000038 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x57 (87) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-0007FFFF 1 : 000C0000-008BFFFF 2 : 00DC0000-116FFFFF 3 : 2E100000-3E5FFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x03000000 Format Info : 000000000000000A0000000000000002000000640018000000 000002000000010000000000000000 Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 0000000E Additional Bad : 0000000E Correctable ECC : 00000000 Erase_SendFormatPartition_BB5_NAND Task in Progress... Please Wait... STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 0000000E Additional Bad : 0000000E Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:06 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-609_111.140.0058_79_prd.core.fpsx Total blocks to write : 666 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : SOS+PMML >> CMT Rootkey Hash CERT : SOS+DECOMP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS [327C6B67C95DA04A763DEFD4BA15C19FF16D9AE7] >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : SOS+IVE3A >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE >> CMT Rootkey Hash CERT : SOS+ROFS1 ContinueFlash_DCT5 Complete STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 0000000E Additional Bad : 0000000E Correctable ECC : 00000000 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:32 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-609\RM-609_111.140.0058_C00.01_79_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 13000000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 14 Entry Point : 0x0103 Page Format : 128K Maximum Page Size : 0x00001E00 StartErase_DCT5... BlockLength : 0x16 (22) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 01378000-0139FFFF 1 : 107C0000-116FFFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 0000000E Additional Bad : 0000000E Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-609_111.140.0058_C00.01_79_prd.rofs3.fpsx Total blocks to write : 14 >> CMT Rootkey Hash CERT : SOS+ROFS3 >> CMT Rootkey Hash CERT : SOS+IVE3B ContinueFlash_DCT5 Complete STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 0000000E Additional Bad : 0000000E Correctable ECC : 00000000 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:00 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-609\RM-609_111.140.0058_35.01_India_QW_79_prd.rofs2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 13000000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 124 Entry Point : 0x00FB Page Format : 128K Maximum Page Size : 0x00040000 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 0CC80000-107BFFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 0000000E Additional Bad : 0000000E Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-609_111.140.0058_35.01_India_QW_79_prd.rofs2.fpsx Total blocks to write : 124 >> CMT Rootkey Hash CERT : SOS+ROFS2 ContinueFlash_DCT5 Complete STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 0000000E Additional Bad : 0000000E Correctable ECC : 00000000 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:19 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-609\RM-609_111.140.0058_U05.01_79.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 13000000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 767 Entry Point : 0x00FB Page Format : 128K Maximum Page Size : 0x00040000 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 11700000-2E0FFFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 0000000E Additional Bad : 0000000E Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:05 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-609_111.140.0058_U05.01_79.uda.fpsx Total blocks to write : 767 ContinueFlash_DCT5 Complete STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 0000000E Additional Bad : 0000000E Correctable ECC : 00000000 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:02:05 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-609\RM-609_PR21_v1_prd_APEONLY_eno.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 25 Entry Point : 0x013F Page Format : 128K Maximum Page Size : 0x00040000 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 008C0000-00DBFFFF Erase_SendEraseBlock_BB5_NAND Task in Progress... Please Wait... STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 0000000E Additional Bad : 0000000E Correctable ECC : 00000000 Successfully erased.. Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-609_PR21_v1_prd_APEONLY_eno.fpsx Total blocks to write : 25 >> CMT Rootkey Hash CERT : SOS*ENO ContinueFlash_DCT5 Complete STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 0000000E Additional Bad : 0000000E Correctable ECC : 00000000 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:03 Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-609\RM-609_M021.07.emmc.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 13000000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 2678 Entry Point : 0x01BE Page Format : 128K Maximum Page Size : 0x00040000 MASS_MEMORY_CONFIG_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) NO ERASE DATA FOR THIS IMAGE... Time Taken to Erase : 00:00:00 Flashing Speed: 5.00 Mhz (AUTO) Processing : RM-609_M021.07.emmc.fpsx Total blocks to write : 2678 ContinueFlash_DCT5 Complete STATUS_REQUEST_BB5... 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 0000000E Additional Bad : 0000000E Correctable ECC : 00000000 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:07:06 Total Flash Write Time (Flashing Only) : 00:11:07 Total Flashing Time (Booting + Erase + Flashing) : 00:11:25 Waiting for Phone to Go Online... Elapsed Time: 1s Elapsed Time: 2s Elapsed Time: 3s Elapsed Time: 4s Elapsed Time: 5s Elapsed Time: 6s Elapsed Time: 7s Elapsed Time: 8s Elapsed Time: 9s Elapsed Time: 10s ================================================ Basic Phone Information ================================================ MCU Version: V 79_sr1_12w18.5 27-07-12 RM-609 (c) Nokia IMEI Plain : 354875040848191 IMEI Spare : A354875040848190 IMEI SV : 33548750408481945F Phone Model: Nokia E6-00 Category : Classic Phone Phone Type : RM-609 ================================================ Extended Phone Information ================================================ Product Serial Number: 0 Product Code : 059F259 Long Production SN : 0 MCU SW Version : V 79_sr1_12w18.5 27-07-12 RM-609 (c) Nokia RFIC Version : |Alli_4.3.4 DSP Version : 92_12w18 APE BT Version : HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. AHNE Version : 11 APE SW Core Version : 111.140.0058 Variant Version : 111.140.0058111.140.0058.35.01111.140.0058.C00.01 APE Test Version : 0026_04 RETU Version : 40 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : 90:CF:15:30:6F:77 Bluetooth ID : 90:CF:15:2F3:37 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED PHONE_MODE : TEST DCC ID : NOT USED Sir phone was working i only update with same product code please give me solution Thanks Regards |
