Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 06-15-2011, 17:55   #1 (permalink)
Member: 1297764
Red face E63 black lcd... need help - [SOLVED]
hello friendzzz, i have e63 n problem is black lcd only vibration n after 30sec turn off.
log is here
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010006
     ID DWORD    3 : 400C1921
     ID DWORD    4 : 01051103
  2  ROM_ID 15
     Block Length  : 5  (05)
     ID DWORD    0 : 00000296
  3  ROM_ID 15
     ID DWORD    0 : 00000B22
  4  PUBLIC_ID 12
     ID DWORD    0 : 0CC00014
     ID DWORD    1 : CDAA0052
     ID DWORD    2 : 0A68928B
     ID DWORD    3 : AD82E6CB
     ID DWORD    4 : BE246308
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  C7 0C B0 73 24 05 6B C6 6A 82 43 47 F4 0D B2 D5
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 4B9B7510
     CRC         1 : 3E691FF8
Checksum           E4
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
Boot File - Version  010.050.00
Boot File - Revision 0x0002 (2)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : 06
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> not detected
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 0020 ->
   Device ID         : 0040 -> Type not in database
   Revision ID       : 0031
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> not used
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Revision ID       : 0031
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              : XSR 1.5
 Checksum   : 55
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031
Flash Descriptor
   Device ID         : 0040
   Revision ID       : 0000
   Size              : 10000000 (256 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg
Algorithm File - Version  010.050.00
Algorithm File - Revision 0x0002 (2)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
   PAPUB_KEYS_HASH_RESP_BB5 2A
   BB Asic Index   : 00
CMT PAPUBKEYS HASH:
D9C25399C696B8549EDCDB1497A950B3A20DDFB6
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            BB ASIC Index     : 0x00 CMT
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00010000
            Spare             : FFFFFFFF
            Num Partitions    : 00000006
            Partition    1
              Attribute       : 00000002  RO
              Start Address   : 00080000
            Partition    2
              ID              : 00000004  DEMANDONOS
              Start Address   : 01600000
            Partition    3
              ID              : 00000008  FILESYSTEM
              Attribute       : 00000001  RW
              Start Address   : 075A0000
            Partition    4
              Start Address   : 0F020000
            Partition    5
              ID              : 00000009  FILESYSTEM1
              Start Address   : 0F1C0000
            Partition    6
              Start Address   : 0F8C0000
PARTITION_INFO_REQUEST_BB5 : 64012F6F00030000010000FFFFFFFF000000060000000300000002000800000158000000000004000000020160000005FA00000000000800000001075A000007A800000000000B000000010F020000001A000000000009000000010F1C0000007000000000000A000000010F8C000000160000DD
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0xB1  (177)
ERASE Blocks :  0x04  (4)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x1B (27)
            Device Index     : 0x00
               0             : 00040000-007FFFFF
               1             : 00A00000-0759FFFF
               2             : 0F1C0000-0F8BFFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x00000000
            Format Info      : 000000000000000B0000000000000002000000640000000300000001000000010000000000000000
     2   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 00000000000000090000000000000001000000640000000400000001000000010000000000000000
     3   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 000000000000000A0000000000000002000000640000000300000001000000010000000000000000
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Erase_SendFormatPartition_BB5_NOR
Successfully erased..
Time Taken to Erase : 00:00:01
Flashing Speed: 5.00 Mhz (AUTO)
Processing  : rm437_510.21.010_prd.c00
Total blocks to write : 533
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS
>>  CMT Rootkey Hash CERT : SOS*UPDAPP
>>  CMT Rootkey Hash CERT : SOS*DSP0
>>  CMT Rootkey Hash CERT : SOS*ISASW
>>  CMT Rootkey Hash CERT : SOS*CORE
>>  CMT Rootkey Hash CERT : SOS+ROFS
ContinueFlash_DCT5 Complete
Continue Flash Complete :  : No Error - 0 (0x00)
Time Taken to Flash  : 00:00:41
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-437\rm437_510.21.010_prd.v43
CMT Type : BB5
CMT Algorithm : XSR 1.5
Secondary Sending Speed    : 650000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 6500000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  211
Entry Point:  0x0169
Page Format : -1
MAX PAGE : 0x00020000
No partition info....
StartErase_DCT5...
BlockLength  :  0x3F  (63)
ERASE Blocks :  0x02  (2)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 05420000-0759FFFF
            Device Index     : 0x00
Time Taken to Erase : 00:00:00
Processing  : rm437_510.21.010_prd.v43
Total blocks to write : 211
>>  CMT Rootkey Hash CERT : SOS+ROFX
Time Taken to Flash  : 00:00:17
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-437\rm449_510.21.010.32U
CMT Type : BB5
Number of Blocks :  171
Entry Point:  0x0122
Page Format : -1
StartErase_DCT5...
BlockLength  :  0x32  (50)
ERASE Blocks :  0x01  (1)
     0   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 00000000000000080000000000000001000000640000000A00000001000000010000000000000000
Processing  : rm449_510.21.010.32U
Total blocks to write : 171
Time Taken to Flash  : 00:00:14
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-437\sofie_erase_y_drive.fpsx
CMT Type : BB5
Number of Blocks :  0
Entry Point:  0x0000
Page Format : -1
StartErase_DCT5...
BlockLength  :  0x0E  (14)
            Device Index     : 0x00
               0             : 0F020000-0F1BFFFF
Processing  : sofie_erase_y_drive.fpsx
No FLASHDATA TO WRITE
Time Taken to Flash  : 00:00:00
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-437\RM437_ENO_008.07.45_100.71.952.a018.fpsx
CMT Type : BB5
Number of Blocks :  16
Entry Point:  0x0143
Page Format : -1
StartErase_DCT5...
BlockLength  :  0x10  (16)
     0   ERASE_AREA_BB5 0x13
            Block Length     : 0x0D (13)
Processing  : RM437_ENO_008.07.45_100.71.952.a018.fpsx
Total blocks to write : 16
>>  CMT Rootkey Hash CERT : SOS*ENO
Time Taken to Flash  : 00:00:01
Total Flash Write Time (Flashing Only) : 00:01:15
Total Flashing Time (Booting + Erase + Flashing) : 00:01:17
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00000001
          Additional Bad    :  00000001
          Correctable ECC   :  00000000
FlashInfo.RestartMode : 2
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
ERROR : PHONE READ INFO FAILED
Old 06-15-2011, 18:37   #2 (permalink)
mobile_hotman's Avatar
Member: 214340
Flash with Higher version will be solved.
Old 06-15-2011, 18:45   #3 (permalink)
Member: 1297764
i think this is last version 510.21.010
Old 06-15-2011, 19:01   #4 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Your Solution Is Here
Nokia E63 Black Screen Problem Fix
Old 06-15-2011, 19:35   #5 (permalink)
Member: 1297764
Originally Posted by shoaibrao View Post
yes this is right
i have 2 device same problem..other one is ok after write blank pmm.
Old 06-15-2011, 19:46   #6 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
I think Its Not Relevant To Hash But You Should Wait
For Any ATF Supporter For Better Assistance
The Following User Says Thank You to shoaibrao For This Useful Post:
Old 06-16-2011, 15:47   #7 (permalink)
Member: 963141
for e63 .this ppm work for white screen
Old 06-16-2011, 19:05   #8 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
First Post Here Flashing Logs.
If Flashing Problem Will Work.
But If Flashing Complete Then It Will Be Hardware.
Old 06-16-2011, 19:48   #9 (permalink)
Member: 1597482
log is here
  1  SYSTEM_ASIC_ID 01
  2  ROM_ID 15
  3  ROM_ID 15
  4  PUBLIC_ID 12
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
  7  ROM_ID 15
     CRC         0 : 4B9B7510
     CRC         1 : 3E691FF8
Checksum           E4
 MessageID  : 06
 SubBlocks  : 06
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0031
   Block Length      : 0B
   Device Index      : 01
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0031
   Block Length      : 09
   Data              : XSR 1.5
 Checksum   : 55
SendAlgoCode_DCT5..
Flash Descriptor
   Device ID         : 0040
   Revision ID       : 0000
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
   BB Asic Index   : 00
CMT PAPUBKEYS HASH:
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
Partition Info
            Device Index      : 0x00
            Spare             : FFFFFFFF
            Partition    1
            Partition    2
            Partition    3
            Partition    4
            Partition    5
            Partition    6
StartErase_DCT5...
            Device Index     : 0x00
            Device Index     : 0x00
            Device Index     : 0x00
            Device Index     : 0x00
CMT Type : BB5
Entry Point:  0x0169
Page Format : -1
StartErase_DCT5...
            Device Index     : 0x00
            Device Index     : 0x00
CMT Type : BB5
Entry Point:  0x0122
Page Format : -1
StartErase_DCT5...
            Device Index     : 0x00
CMT Type : BB5
Entry Point:  0x0000
Page Format : -1
StartErase_DCT5...
            Device Index     : 0x00
CMT Type : BB5
Entry Point:  0x0143
Page Format : -1
StartErase_DCT5...
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
Download letest ver. flash file & again flash ur phone post result
br.
.:::Aloktheultimate:::.
Old 06-17-2011, 00:05   #10 (permalink)
Member: 1297764
br.
i already flashed latest version 510.21.010
Old 06-22-2011, 18:24   #11 (permalink)
Member: 1297764
waaaw! i have fixed my problem....thnx ATF team
Old 06-22-2011, 18:35   #12 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks to the end users who helped you solve your problem ('',)
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 06-22-2011, 18:50   #13 (permalink)
Member: 1297764
actually sir i followed this thread e52 only vibrate final solution
of course thanks to all....n ATF box for good support.
Old 11-17-2011, 16:49   #14 (permalink)
Member: 44534
reflow on repido i hv solved this problem
Old 07-17-2012, 16:27   #15 (permalink)
Member: 1076019
Sonork: jaime
worrrrk 10000000000 percent
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.45983 seconds with 11 queries
