Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 12-04-2010, 18:47   #1 (permalink)
mmrozibul's Avatar
Member: 725443
E63 flashing error! help!!
HERE IS LOG
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 70843880 (0xE8) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 400C1921
ID DWORD 4 : 01051103
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 ROM_ID 15
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 16C0010F
ID DWORD 1 : 36800052
ID DWORD 2 : FA7E1293
ID DWORD 3 : 47270B64
ID DWORD 4 : FB6B4D02
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : C7 0C B0 73 24 05 6B C6 6A 82 43 47 F4 0D B2 D5
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum AC
SearchForBootstrap_DCT5..
CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0400 -> Flash
Device ID : 0000 -> Type not in database
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0040 -> KAT00F00RA
Revision ID : 0121
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.5
Checksum : 25
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121
RAPIDOv11_algo.fg
First Algo byte : C0
RAPIDOv11_XSR15_alg.fg
First Algo byte : 56
Flash Descriptor
Device ID : 0040
Revision ID : 0000
Size : 10000000 (256 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPP INFO :
C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
No PAPUBKeysHash Returned
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000006
Partition 1
Attribute : 00000002 RO
Start Address : 00080000
Partition 2
ID : 00000004 DEMANDONOS
Start Address : 01600000
Partition 3
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 075A0000
Partition 4
Start Address : 0F020000
Partition 5
ID : 00000009 FILESYSTEM1
Start Address : 0F1C0000
Partition 6
Start Address : 0F8C0000
PARTITION_INFO_REQUEST_BB5 : 64012F6F00030000010000FFFFFFFF00000006000000030000 0002000800000158000000000004000000020160000005FA00 000000000800000001075A000007A800000000000B00000001 0F020000001A000000000009000000010F1C00000070000000 00000A000000010F8C000000160000DD
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0xB1 (177)
ERASE Blocks : 0x04 (4)
0 ERASE_AREA_BB5 0x12
Block Length : 0x1B (27)
Device Index : 0x00
0 : 00040000-007FFFFF
1 : 00A00000-0759FFFF
2 : 0F1C0000-0F8BFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x00000000
Format Info : 000000000000000B0000000000000002000000640000000300 000001000000010000000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 00000000000000090000000000000001000000640000000400 000001000000010000000000000000
3 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000A0000000000000002000000640000000300 000001000000010000000000000000
Erase_SendEraseBlock_BB5_NAND
Task in Progress... Please Wait...
Erase_SendFormatPartition_BB5_NAND
Successfully erased..
Time Taken to Erase : 00:00:01
Is Flashing CLOCK AUTO : -1
Processing : rm437_501.21.001_prd.c00
Total blocks to write : 532
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS*CORE
>> CMT Rootkey Hash CERT : SOS+ROFS
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00:00:38
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-437\rm437_501.21.001_prd.v345
CMT Type : BB5
CMT Algorithm : XSR 1.5
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 208
Entry Point: 0x0169
Page Format : -1
MAX PAGE : 0x00020000
No partition info....
StartErase_DCT5...
BlockLength : 0x3F (63)
ERASE Blocks : 0x02 (2)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 05420000-0759FFFF
Device Index : 0x00
Time Taken to Erase : 00:00:00
Processing : rm437_501.21.001_prd.v345
Total blocks to write : 208
>> CMT Rootkey Hash CERT : SOS+ROFX
Time Taken to Flash : 00:00:16
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-437\rm437_501.21.001.345U
CMT Type : BB5
Number of Blocks : 129
Entry Point: 0x0122
Page Format : -1
StartErase_DCT5...
BlockLength : 0x32 (50)
ERASE Blocks : 0x01 (1)
0 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 00000000000000080000000000000001000000640000000A00 000001000000010000000000000000
Processing : rm437_501.21.001.345U
Total blocks to write : 129
<<<STOPS HERE>>>
Uploaded with ImageShack.us
Old 12-05-2010, 08:48   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
@mmrozibul
Tick 'skip HW id check' and make flash again.
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Page generated in 0.40457 seconds with 11 queries
