12-28-2012, 09:36 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 774169 Status: Offline Thanks Meter: 123 | E63- Restarts when go to setting i have e63 which restats when i go to setting . actaully it was downgraded and when in blue light . After that it was flashed with latested version , now handsets ok . network comming . but when i go to setting , it restarts . i formmatted it , done ui setting . still no luck now i am thinking of erasing it . i have rpl & sim lock back up but donot have NETWROK ACTIVATION . shall i go for erase , its SL3 handset regards waiting for early response regarrds suraj |
12-28-2012, 17:47 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, If your box is NOT ACTIVATED for the ATF NETWORK then you should not make downgrade process... Because you will not be able to repair super dongle of your phone and there phone it will end up on contact service. Better you activate your box and downgrade with ATF Box. All tutorials, info about downgrade has been posted already in our section. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
