09-13-2011, 16:12 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: Gujrat
Member: 510263 Status: Offline Sonork: 100.1601350 Thanks Meter: 99 | Adwance team - (SOLVED) i do sx4 but problam not solved what do i do now ? MCU Version: V 09.98 06-09-10 RM-561 (c) Nokia IMEI Plain : 351517048914798 IMEI Spare : A351517048914790 IMEI SV : 33515170489147955F Phone Model: Nokia 2700 classic Product Serial Number: IAV692928 Product Code : 0589277 Module Code : 0204245 Basic Production Code: 0577212 Default SN Type : 0 MCU SW Version : V 09.98 06-09-10 RM-561 (c) Nokia MH BT MCM Version : 2222-302 PPM Version : V 09.98 06-09-10 RM-561 (c) Nokia HW Version : 2000 RFIC Version : 06540601 DSP Version : ICPR72_09w26 LCD Version : SEIKO Content Pack Version : Content: mh_black V 09.98 06-09-10 RM-561 (c) Nokia AHNE Version : 30 Retu Version : 16 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NIMMIIIIRRFF0A021001 DCC Ver: 002007 Status : OK ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-561.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 12 - Ok Field : 1 Sub : 1 Byte(s): 70 - Ok Field : 1 Sub : 2 Byte(s): 70 - Ok Field : 1 Sub : 3 Byte(s): 70 - Ok Field : 1 Sub : 4 Byte(s): 70 - Ok Field : 1 Sub : 5 Byte(s): 276 - Ok Field : 1 Sub : 6 Byte(s): 276 - Ok Field : 1 Sub : 7 Byte(s): 276 - Ok Field : 1 Sub : 8 Byte(s): 276 - Ok Field : 1 Sub : 9 Byte(s): 384 - Ok Field : 1 Sub : 10 Byte(s): 384 - Ok Field : 1 Sub : 11 Byte(s): 384 - Ok Field : 1 Sub : 12 Byte(s): 384 - Ok Field : 1 Sub : 13 Byte(s): 384 - Ok Field : 1 Sub : 14 Byte(s): 384 - Ok Field : 1 Sub : 15 Byte(s): 384 - Ok Field : 1 Sub : 16 Byte(s): 384 - Ok Field : 1 Sub : 17 Byte(s): 32 - Ok Field : 1 Sub : 19 Byte(s): 16 - Ok Field : 1 Sub : 20 Byte(s): 32 - Ok Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 2 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 5 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 8 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok Field : 309 Sub : 22 Byte(s): 12 - Ok PM Upload Done!... MCU Version: V 09.98 06-09-10 RM-561 (c) Nokia IMEI Plain : 351517048914798 IMEI Spare : A351517048914790 IMEI SV : 33515170489147955F Phone Model: Nokia 2700 classic Product Serial Number: IAV692928 Product Code : 0589277 Module Code : 0204245 Basic Production Code: 0577212 Default SN Type : 0 MCU SW Version : V 09.98 06-09-10 RM-561 (c) Nokia MH BT MCM Version : 2222-302 PPM Version : V 09.98 06-09-10 RM-561 (c) Nokia HW Version : 2000 RFIC Version : 06540601 DSP Version : ICPR72_09w26 LCD Version : SEIKO Content Pack Version : Content: mh_black V 09.98 06-09-10 RM-561 (c) Nokia AHNE Version : 30 Retu Version : 16 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NIMMIIIIRRFF0A021001 DCC Ver: 002007 Status : OK MCU Version: V 09.98 06-09-10 RM-561 (c) Nokia IMEI Plain : 351517048914798 IMEI Spare : A351517048914790 IMEI SV : 33515170489147955F Phone Model: Nokia 2700 classic Product Serial Number: IAV692928 Product Code : 0589277 Module Code : 0204245 Basic Production Code: 0577212 Default SN Type : 0 MCU SW Version : V 09.98 06-09-10 RM-561 (c) Nokia MH BT MCM Version : 2222-302 PPM Version : V 09.98 06-09-10 RM-561 (c) Nokia HW Version : 2000 RFIC Version : 06540601 DSP Version : ICPR72_09w26 LCD Version : SEIKO Content Pack Version : Content: mh_black V 09.98 06-09-10 RM-561 (c) Nokia AHNE Version : 30 Retu Version : 16 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : 12345 SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NIMMIIIIRRFF0A021001 DCC Ver: 002007 Status : OK |
09-13-2011, 16:24 | #3 (permalink) | |
Insane Poster Join Date: Feb 2011
Member: 1509031 Status: Offline Thanks Meter: 21 | Quote:
http://forum.gsmhosting.com/vbb/f299/nokia-2700c-security_test-failed-1320751/ | |
09-14-2011, 07:58 | #5 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Backup RPL and post RPL Backup File here also, try to write first ERASE_1_309.pm to your phone using SX-4... Then buscheck the phone... Now write RM-561.pm 1 and 309 back to your phone using SX-4 | |
09-14-2011, 08:38 | #7 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote: Your Phone does not have CCC and HWC Certificates... Try to write this RPL to your Phone C:\AdvanceBox Turbo Flasher\Nokia\RPL_Wout_NPC\2700c_without_NPC_DATA. rpl | |
09-14-2011, 11:54 | #8 (permalink) |
Member: 510263 Status: Offline Sonork: 100.1601350 Thanks Meter: 99 | Thanks adwance team for quick replay i write 2700c_without_NPC_DATA. phone ok now big thankssssssssss MCU Version: V 09.98 06-09-10 RM-561 (c) Nokia IMEI Plain : 351517048914798 IMEI Spare : A351517048914790 IMEI SV : 33515170489147955F Phone Model: Nokia 2700 classic Product Serial Number: IAV692928 Product Code : 0589277 Module Code : 0204245 Basic Production Code: 0577212 Default SN Type : 0 MCU SW Version : V 09.98 06-09-10 RM-561 (c) Nokia ML BT MCM Version : 2222-302 PPM Version : V 09.98 06-09-10 RM-561 (c) Nokia HW Version : 2000 RFIC Version : 06540601 DSP Version : ICPR72_09w26 LCD Version : SEIKO Content Pack Version : Content: ml_red V 09.98 06-09-10 RM-561 (c) Nokia AHNE Version : 30 Retu Version : 16 Tahvo Version : 22 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NIMMIIIIRRFF0A021001 DCC Ver: 002007 Status : OK |
many thanks to fast unloking team | rawhi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-26-2002 13:27 |
WinDLS by CODEC TEAM-ROMANIA | dedekwien | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-23-2002 15:33 |
hackertronics.com=FreeGSM team????? | robinhood | The Market Feed Back | 13 | 08-14-2001 20:17 |
_sHARe_dA sTuFF - mobile.box.sk -HQ releases from Royalgsm and RADiANCE TEAM | mr_johnson | GSM Mobile Links | 1 | 05-19-2001 22:29 |
NEW NEW X-treme Gsm Team | Salami1_1 | GSM Mobile Links | 0 | 04-13-2001 13:57 |
