E71 camera problem turn to sim not valid Pls help me how to fix my E71, before it was camera problem if trying to take picture only black screen is coming and i tried to write different pm downloaded from this forum but after writing sim not valid and camera still the same problem. The problem is i did not make back up rpl and pm how can i fix the problem is there any chances? My box is not yet activated too. pls help me! here's the logs MCU Version: V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia IMEI Plain : 354856042743549 IMEI Spare : A354856042743540 IMEI SV : 33548560427435464F Phone Model: Nokia E71 Product Serial Number: MCJ202833 Product Code : 0561186 Basic Production Code: 0557205 Default SN Type : 0 PPM Version : V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia HW Version : 0915 RFIC Version : 17141716 DSP Version : ICPR71_09w40 AHNE Version : 11 APE SW Core Version : 510.21.009 APE Variant Version : 510.21.009510.21.009_v20 APE Test Version : RM346ENO74110842.a36 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** Unable to read SP Data.. MCU Version: V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia IMEI Plain : 354856042743549 IMEI Spare : A354856042743540 IMEI SV : 33548560427435464F Phone Model: Nokia E71 Product Serial Number: MCJ202833 Product Code : 0561186 Basic Production Code: 0557205 Default SN Type : 0 PPM Version : V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia HW Version : 0915 RFIC Version : 17141716 DSP Version : ICPR71_09w40 AHNE Version : 11 APE SW Core Version : 510.21.009 APE Variant Version : 510.21.009510.21.009_v20 APE Test Version : RM346ENO74110842.a36 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** Unable to read SP Data.. SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL MODE |
@poknokz Click BUSCHECK and paste the Logs here... It will show me if your phone is SL2 or SL3... If it is SL2 (most likely) then you can rebuild simlocks via Repair Simlocks (SL1 and SL2) option... If it is SL3, then you need to buy RPL... |
here's the logs sir AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 07700116 ID DWORD 1 : 58A60052 ID DWORD 2 : 1EF2D783 ID DWORD 3 : 57C02BDC ID DWORD 4 : 654685F3 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum C9 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 011.024.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 Checksum : 55 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 Flash Descriptor Manufacturer Code : 0020 Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g Algorithm File - Version 011.024.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 52570A2086C79E6965175815B5388535CDD5C6F7 Scanning Simlock Applet Type... OK ================================================= PA_SL3 Applet detected ================================================= * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... FlashInfo.RestartMode : 2 |
too bad you have PA_SL3 phone |
yes, and maybe that is the reason why i cannot fix my camera by writing new pm? i have one more question. If i buy rpl i can fix also the camera problem by software? |
I doubt you will be able to fix camera by using Original Nokia RPL... But it is worth a try, since simlocks needs to be fixed as well anyway. B/R> |
