08-25-2016, 16:00 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | E71 cmt root key 479C6DDE3942E12C429C1D6ADED80371 I have E71 with 479C6DDE3942E12C429C1D6ADED80371 cmt root key hash. Can I unlock it without bruteforce with direct unlock? Thanks! |
10-07-2017, 07:11 | #3 (permalink) |
Junior Member Join Date: Oct 2007
Member: 621556 Status: Offline Thanks Meter: 1 | i have also Nokia e71 RM-346 P-Code 0576027 with ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 shown Phone start-up faild. contact with retailer. whenever i start the phone. and again goes to dead mode. can detect on pc suit. try many time with dead phone flash. with bb5 easy tools. phionex, and jaf . without box usb cable. but failed to fix the issue. after flashing phone goes to local mode and when check the issue. bb5 said. Phone found! Series 60 Device detected! read info... - Ok Read and Check phone data... ---------------------- RAP_BOOT: 0B01010502010000 RAP_PUB: 20C00009D1A000524A1592E06B88AF8D5BFF4BD2 CMT_ROOT: 479C6DDE3942E12C429C1D6ADED80371 RAP_PAPUB: 52570A2086C79E6965175815B5388535CDD5C6F7 ---------------------- Live Test Ok! ---------------------- CMT Flash ID : 00400020 < ST => M39BORBOAD ------------------------ SDD Key status : SD Data is Ok SimLock status : SimLock Damaged!!!!! Security status : Security Damaged!!!!! PA_SimLock Version : PA_SL2 phone detected Done! anyone have solution for this. |
11-01-2017, 08:30 | #5 (permalink) | |
Freak Poster Join Date: Feb 2010 Location: Manila Phulippines
Member: 1246625 Status: Offline Thanks Meter: 21 | Quote:
you can repair it via atf. see this picture..connect phone via usb. e71.png - ShotUpload | |
11-03-2017, 17:31 | #6 (permalink) |
Member: 621556 Status: Offline Thanks Meter: 1 | The link you send is not working. i try several times. a blank page with " down for maintenance" please send me a good link for complete procedure to use ATF. as i already used JAF and Phionex and BB5 Easy tool USB unlocked. i don't have any box but i try also using miracle box. but same results. need some video tutorials to do this step by step. Thanks in advance. |
