Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 03-08-2012, 17:31   #16 (permalink)
X-Shadow's Avatar
Member: 871
Originally Posted by pippopippo78 View Post
@ X-Shadow
@ ..::Angel::..
don't work for my box
Your SD Card cannot go IDLE State, which means you should check
the SD SLOT if soldering is good and check here if have some short
or bad solder. After you check, you can fix the problem for sure this
time!
ATF Minor Update v8.55 released:
The Following User Says Thank You to X-Shadow For This Useful Post:
Old 03-08-2012, 17:35   #17 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
@ X-Shadow
@ ..::Angel::..
u fist make modifie box ı think u need modifie box remove some elements..
Old 03-08-2012, 17:47   #18 (permalink)
Member: 652864
time!
*** official statement about sd card slot problem ***
tomorrow i try to resold sd slot
Old 03-08-2012, 18:20   #19 (permalink)
h-d
Member: 102872
ATF works very good. thanks
Old 03-08-2012, 22:25   #20 (permalink)
alwi7666's Avatar
Member: 368730
AdvanceBox Turbo Flasher A SN:Work Fine
1 ATF Box Found...
ATF Software has already paired itself
with this ATF Box.
Card Reset Done!
Initializing Micro SD Card...
Card Initialized OK (V2.0 Compliant)
Waiting for IDLE State...
Card is now IDLE!
Reading Micro SD Card Information...
Manufacturer ID : 0x02
Application ID : TM
Product Name : SA01G
Product Revision : 0.4
Serial Number : 9C0000CC
Manufacture Date: May 2010
Card CID: 02544D5341303147049C0000CC00A54D
Card CSD: 002E00325B59A3ADFFFFFF8F0A40004B
Card SCR: 0225000001000000
Card OCR: 0080FF8000
Maximum Speed: 25000000 Hertz
Checking Lock Status...
Micro SD Card is NOT Password Protected!!!
Old 03-08-2012, 23:50   #21 (permalink)
Member: 905037
Sonork: 1603825
After reboot it will be good
Old 03-09-2012, 02:36   #22 (permalink)
Rhyan777's Avatar
Member: 893209
Thankz ATF TEAM its Working,,,,,,,
Br,.
Rhyan
Old 03-09-2012, 03:35   #23 (permalink)
Member: 487150
Thanks ATF TEAM working
Old 03-09-2012, 04:05   #24 (permalink)
khalidjan's Avatar
Member: 624551
Sonork: 100.1584837
still i didn't updated the firmware but... it is removing password from sd memory card in my laptop... but not working in other computers.... just working in laptop....and i have removed many passwords ............thanx
Old 03-09-2012, 04:10   #25 (permalink)
Prem_India's Avatar
Member: 718725
Sonork: 100.1604953 QQ 2339690693
Thanks ATF Team Work Fine
Prem_India
Old 03-09-2012, 04:19   #26 (permalink)
Member: 186972
great job atf..u r really the restless product
Old 03-09-2012, 04:22   #27 (permalink)
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727
Thanks A Load My Favorite Team Really Fantasy Job, All Procedure is Working Tested by Me...
Best Regard
Old 03-09-2012, 04:40   #28 (permalink)
mfq
Member: 1083358
How to know my atf box pcb modified or not?
Old 03-09-2012, 04:42   #29 (permalink)
Member: 464543
Sonork: 100.1622465
Advance Turbo Flasher Found
Driver Version : 00020416
Library Version : 00030118
Box Type : AdvanceBox Turbo
Box Firmware : LogiCore 10.3.12
Software Version : v8.55
AdvanceBox SN : 80F2C00B9D9278219555943F
Box Status : ACTIVATED
Box Successfully Initialized
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Old 03-09-2012, 04:45   #30 (permalink)
Member: 464543
Sonork: 100.1622465
plz go to> Product support >> Box tool >> check atf big firmware type
The Following User Says Thank You to prasanth67 For This Useful Post:
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 04-06-2012 16:22
£2,000 for 5110/6110 unlock software 1 2 3 4 Dean O'Grady Wanted Products 14 03-19-2005 09:52
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 06-25-1999 08:21
Page generated in 0.81702 seconds with 12 queries
