03-11-2012, 14:41 | #61 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Keep eye on - Advance-Box - GSM-Forum soon it will release Thanks Br - srinibas |
03-12-2012, 13:55 | #63 (permalink) |
Freak Poster Join Date: Mar 2009 Location: dubai, UAE Age: 40
Member: 1000673 Status: Offline Sonork: 100.1597409 Thanks Meter: 115 | i have problem in update new firmware C:\Documents and Settings\XPPRESP3\Desktop\NaviFirmPlus\BIG_BOX_NOR MAL_PCB_10.3. 12\BIG_BOX_NORMAL_PCB_10.3.12>DirectC.exe -aprogram firmware.dat OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOO OO OO OO AdvanceBox JTAG In-System-Programming v1.0 OO OO OO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOO AdvanceBox JTAG: Open Port Success... Calculating timer calibration value... Timer calibration value = 1086 | | -<+>- Firmware Update will take approximately 7 minutes -<+>- | | ActID = 0 ExpID = 3A141CF Error return code 6 | | -<+>- WARNING: Firmware Update FAILED! -<+>- | | [o] Make sure that the USB Cable is Properly Connected... [o] Do not use USB Hubs or USB Extension Cables... [o] Use shorter and thicker USB Cables rated for USB 2.0... Please type 'exit' and press the 'Enter' key to close this Window... Elapsed time = 00:00:00 C:\Documents and Settings\XPPRESP3\Desktop\NaviFirmPlus\BIG_BOX_NOR MAL_PCB_10.3. 12\BIG_BOX_NORMAL_PCB_10.3.12>pause Press any key to continue . . . and atf inerface very hang after update to 8:55 any solved here atf team |
03-12-2012, 14:07 | #64 (permalink) |
No Life Poster Join Date: Apr 2007 Location: INDIA-uttranchal-rishikesh Age: 47
Member: 484665 Status: Offline Sonork: 100.1578012 Thanks Meter: 175 | 1 ATF Box Found... ATF Software has already paired itself with this ATF Box. Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V1.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x00 Application ID : Product Name : N/A Product Revision : 1.0 Serial Number : 17FA79CD Manufacture Date: December 2008 Card CID: 0020204E2F4120201017FA79CD008C2B Card CSD: 006F00325F5983C9F6DBDFFF8A4040F7 Card SCR: FFFFFFFFFFFFFFFF Card OCR: FF0080FF80 Maximum Speed: 25000000 Hertz Checking Lock Status... Micro SD Card is NOT Password Protected!!! but still mmc say password ..?? |
03-13-2012, 09:17 | #68 (permalink) | |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | Quote:
Follow instructions inside RAR file... If other boxes connected on USB port, then it will not update. If ATF EXE running, then it will not update Disconnect, then reconnect ATF Box m then try to update again | |
03-14-2012, 07:35 | #72 (permalink) |
No Life Poster Join Date: Jun 2004 Location: China Age: 46
Member: 68392 Status: Offline Sonork: 100.100701 Thanks Meter: 658 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020817 Library Version : 00030206 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 10.3.12 Software Version : v8.55 AdvanceBox SN : D5907167B7C3A814EDCE90A1 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ MMC readed after update box. thanks for good support. |
03-14-2012, 10:32 | #73 (permalink) |
Registered User Join Date: Jun 2006
Member: 291029 Status: Offline Thanks Meter: 97 | Code: C:\Users\Roezt99\Downloads\Compressed\BIG_BOX_NORMAL_PCB_10.3.12\BIG_BOX_NORMAL_ PCB_10.3.12>DirectC.exe -aprogram firmware.dat OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OO OO OO AdvanceBox JTAG In-System-Programming v1.0 OO OO OO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO AdvanceBox JTAG: Open Port Success... Calculating timer calibration value... Timer calibration value = 1200 | | -<+>- Firmware Update will take approximately 7 minutes -<+>- | | ActID = 32A141CF ExpID = 3A141CF Initializing Target Device... Setting BSR Configurations... Loading BSR... Reading Security... Performing Data Authentication.......................... Erase... ACTEL_SLOG_UROW = FF FF FF FF FF FF FF FF FF FF FF FF FF 0 FF FF Programming UROW... Programming FPGA Array.......................... Verifying FPGA Array.......................... Programming Rlock... Programming FlashROM... Programming SILSIG... Exit code = 0... | | -<+>- Firmware Update was a Success! -<+>- | | Please type 'exit' and press the 'Enter' key to close this Window... Elapsed time = 00:02:05 C:\Users\Roezt99\Downloads\Compressed\BIG_BOX_NORMAL_PCB_10.3.12\BIG_BOX_NORMAL_ PCB_10.3.12>pause Press any key to continue . . . Last edited by raditya; 03-14-2012 at 10:37. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
£2,000 for 5110/6110 unlock software 1 2 3 4 | Dean O'Grady | Wanted Products | 14 | 03-19-2005 10:52 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
