04-12-2015, 20:53 | #1 (permalink) |
Freak Poster Join Date: Dec 2012 Location: UFI#Wellcome Worlwide UFiXers
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | Easy Repair Dead Emmc M8G2Y Lumia 520 with ATF 12.11 With Auto Update ATF 12.11, now repair Error even Dead EMMC M8G2Y this is common emmc in Lumia 520 that have WP lock error too, become so easy... Just like 123... My lucky day, I've got two this type of Emmc, so here's the step how to repair it using Amazing ATF 12.11: This is My error emmc "$ is not valid integer" and cause ATF stop responding: 1. Make a jumper wire from TP to GND pinout Emmc type C 2. I'm using e-mate Box, now connect it to ATF 12.11, in EMMC Tool do "Scan Emmc". You will see 00000 in the name of Emmc 3. Now "cut" the jumper wire Select "Samsung eMMC Firmware Update" in -- SELECt Advanced eMMC Procedured--- tab, and click "EXECUTED" 4. Now, emmc upgrade procedure will asking Part Number of your Emmc, just type name from emmc firmware in ATF Folder (C:\\AdvanceBox Turbo Flasher\eMMC\Firmware) 5. After that, emmc will upgrading firmware. It just took in 45 second to finish.... And your Done!!! Now, to check the result, click on "Scan eMMC" again to see the Magic of ATF 12.11 See, now the name of Emmc show up... and the rest you can do write, resize, restore, etc... Gud Luck, and don't forget to Thank's to ATF Team for Amazing Product BR |
The Following 27 Users Say Thank You to madgoeslim For This Useful Post: |
04-14-2015, 19:59 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @madgoeslim: Nice Tutorial :-) Thread stick now! |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
04-15-2015, 14:17 | #5 (permalink) |
Freak Poster Join Date: May 2011 Location: Himachal Pradesh,Kangra,India
Member: 1587904 Status: Offline Thanks Meter: 59 | Finally ATF Team made solution for this type EMMc My Question to Product supporter Is this method support emmc tp on pcb or To Need new emmc chip |
The Following User Says Thank You to love864 For This Useful Post: |
04-15-2015, 15:54 | #6 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Basirhat
Member: 1134419 Status: Offline Sonork: 100.1621725 Thanks Meter: 452 | After repair EMMC and after full flash if set not show imei then what should do ! If don't have backup. Bassically dead emmc don't backup rpl or other security section. |
The Following 2 Users Say Thank You to mridulnandy For This Useful Post: |
04-18-2015, 10:13 | #7 (permalink) |
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | When your Emmc is on "Write Protected" condition, then you can make a backup. But, if your emmc is totally dead before repair, then there are no chance to recover it... For now I guess... |
The Following User Says Thank You to madgoeslim For This Useful Post: |
04-20-2015, 03:53 | #8 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2205304 Status: Offline Thanks Meter: 52 | Is there a solution for Not For Resale device ? My phone is alive now, but with not for sale condition. It is a retail phone. |
The Following User Says Thank You to Suraj#1 For This Useful Post: |
09-26-2015, 01:33 | #9 (permalink) |
Junior Member Join Date: May 2014
Member: 2183245 Status: Offline Thanks Meter: 2 | "not for resale" lumia 520 any solution for "not for resale" lumia 520? it's frustrating that you spend so much time trying to revive one phone and in the end you spend your time for free. |
The Following User Says Thank You to razvan2you For This Useful Post: |
09-26-2015, 06:19 | #10 (permalink) |
No Life Poster Join Date: Sep 2014 Location: Technology town
Member: 2252481 Status: Offline Sonork: 1660352 Thanks Meter: 206 | change firmware....bro with same product code for lumia 520 |
The Following User Says Thank You to Techsky For This Useful Post: |
09-29-2015, 08:17 | #12 (permalink) |
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | You can find all nokia firmware here, just type product code, n done.. |
The Following 2 Users Say Thank You to madgoeslim For This Useful Post: |
12-05-2015, 16:21 | #14 (permalink) |
No Life Poster Join Date: Apr 2007 Location: India
Member: 481609 Status: Offline Sonork: 100.1659889 Thanks Meter: 367 | i can't find 520 K4PG324EQ-PGC2 EMMC file in atf emmc/firmware folder can any one have this file ? |
The Following User Says Thank You to ali_imran For This Useful Post: |
01-08-2016, 08:11 | #15 (permalink) |
No Life Poster Join Date: May 2006 Age: 44
Member: 278546 Status: Offline Thanks Meter: 145 | after full repair emmc i meam firmaware update , how ro restore security ara i man imei. etcf.. |
The Following User Says Thank You to yalamandareddy For This Useful Post: |
