05-13-2014, 22:00 | #1 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Bucharest,Romania Age: 46
Member: 5204 Status: Offline Thanks Meter: 35 | eMMC direct question I am trying to connect to a San disk eMMC SDIN8DE4 16G from a LG Nexus 5 but the memory just doesn't get recognized by ATF. With any other samsung eMMC I have no issues. The question: is this eMMC supporeted and if it's not can you add it ? |
05-13-2014, 22:24 | #2 (permalink) |
Member: 5204 Status: Offline Thanks Meter: 35 | in my haste i forgot to read the specs. "VDDi Connections The VDDi (K2) ball must only be connected to an external capacitor that is connected to VSS. This signal may not be left floating." I'll try tomorrow and post feedback Ps sorry for double posting ....can not find the edit button |
05-14-2014, 09:59 | #3 (permalink) |
Member: 5204 Status: Offline Thanks Meter: 35 | Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 45010053454D313647072523C6D3 CSD : D00F00320F5903FFFFFFFFFF8A40407F eMMC Boot Information Revision 1.6 (for MMC v4.5) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: 45 Device Type : Embedded BGA Application ID : 00 Product Name : SEM16G Product Rev : 0.7 Product SN : 2523C6D3 Manufactured : November 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 45010053454D313647072523C6D3_D3A26C89.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
05-14-2014, 13:20 | #4 (permalink) |
Member: 5204 Status: Offline Thanks Meter: 35 | still need some help. After dumping 512Mb from the damaged eMMC SDIN8DE4 16G and writing it to the samsung eMMC KMVTU000LM B503 I still can't get the phone to boot. In the san disk eMMC BOOT PARTITION : NOT BOOT ENABLED but in samsung's BOOT PARTITION : BOOT PARTITION 1 If this is the case how to reconfigure the samsung eMMC |
05-16-2014, 14:53 | #6 (permalink) |
Member: 5204 Status: Offline Thanks Meter: 35 | CID : 15010056545530304DFC2B132E95 CSD : D02701320F5903FFF6DBFFFF8E40406D eMMC Boot Information Revision 1.6 (for MMC v4.5) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : VTU00M Product Rev : 15.12 Product SN : 2B132E95 Manufactured : October 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO for anyone who needs its offset 0x00000057 in csd |
The Following User Says Thank You to geosan1638 For This Useful Post: |
02-07-2015, 08:11 | #7 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2342261 Status: Offline Thanks Meter: 0 | Can the emmc be fixed after getting these error messages?? E: Failed to mount/cache (Invalid argument) E: Can't mount /cache/ recovery/log E: Can't open/cache/ recovery/ log E: Failed to mount/cache (Invalid argument) E: Can't mount /cache/ recovery/last_log E: Can't open/cache/ recovery /last_log E: Failed to mount/cache (Invalid argument) E: Can't mount /cache/ recovery/last_install E: Can't open/cache/ recovery/ last_install |
02-07-2015, 16:43 | #8 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 931282 Status: Offline Thanks Meter: 19 | If you have previously been used EMMC (B503 KMVTU000LM programmed) in another model, you can use it only to the previous model, to repair the phone, what do you need to have a new clean (blank) EMMC, remember that your EMMC even after a full wipe erases only the content partition, and sectors remain unchanged, each model has a different arrangement of the sectors |
