02-23-2015, 07:55 | #1 (permalink) |
Insane Poster Join Date: Nov 2009 Location: INDIA
Member: 1155334 Status: Offline Sonork: 100.1647978 Thanks Meter: 39 | EMMC info ok but cant write samsung(G355H) ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004B3558594D4203F342D096 CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Boot Information Revision 1.0 (for MMC v4.0) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 0 KB HC ERASE GROUP SIZE: 0 KB USER AREA SIZE : 0 BYTES BOOT PARTITION SIZE: 0 KB RPMB PARTITION SIZE: 0 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : K5XYMB Product Rev : 0.3 Product SN : F342D096 Manufactured : January 1998 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004B3558594D4203F342D096_10D8857D.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ WRITING ERROR ================================================== ==== Loading ATF MMC File... (Please Wait) ================================================== ==== MMC File Version: v11.30 MMC File Author: 963F2A3CB175EDB4B4358C42 Date Created: 08/12/2014 (dd/mm/yyyy) Description: Samsung SM-G355H 4.4.2 [G355HXXU0****] Current Partition: Partition 1 Start Writing Blocks... R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! R1b Timeout Error! i tried with all speeds but stilll same |
