04-11-2013, 12:50 | #1 (permalink) |
Insane Poster Join Date: Mar 2007
Member: 472350 Status: Offline Thanks Meter: 5 | Error: can't access file F42032899CBBB94CC64096C3 - (SOLVED) my ftdi ic already working whay sir my box not update ?????????????????????????? |
04-11-2013, 12:54 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @gulshir This is when some other software is preventing ATF to access this file. Most of the time, it is because you are not logged in as administrator in windows. B.R> |
04-11-2013, 16:21 | #5 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Tips for Advance-box :) There are several possibilities .. 1.- Avira Antivirus UP 2.- This running 2 times while the soft atf, or must pass the mouse over the small icons (next to the Windows OS clock) always fails when there are 2 small icons (there should be only one, when ATF is running) 3.- This Using ftd.dll and its variants with its box Vulcano 4.- This using ftd.dll and exe files packaged version (best Dongle) and generates a lot of problems if you try to use JAF as Interface Br Polaco |
