05-24-2016, 00:19 | #1 (permalink) |
Junior Member Join Date: May 2016
Member: 2574353 Status: Offline Thanks Meter: 0 | ERROR: Failed to Initialize SDC Module 0x55 I have few MicroSD's that i want to find the password and unlock. But i get this error, ERROR: Failed to Initialize SDC Module 0x55 ERROR: Failed to Initialize SDC Module Faulty MicroSD Reader or i'm doing something wrong? From Logs 17:20:16 : ================================================ 17:20:16 : Box Successfully Initialized 17:20:16 : ================================================ 17:20:16 : 17:20:16 : VBATT Powering Down <<<< 17:20:20 : VBATT Powering Up >>>> 17:20:20 : SET VCCIO Level Done 17:20:20 : SET BSI Load Done 17:20:20 : 17:20:34 : ================================================ 17:20:34 : Advance Turbo Flasher Found 17:20:34 : ================================================ 17:20:34 : Driver Version : 00021206 17:20:34 : Library Version : 00030210 17:20:36 : Box Type : AdvanceBox Turbo 17:20:36 : Box Firmware : LogiCore 8.15.10 17:20:36 : Software Version : v12.67 |
05-26-2016, 01:02 | #5 (permalink) |
Member: 2574353 Status: Offline Thanks Meter: 0 | I was able to update firmware but still the same error. 16:53:57 : ================================================ 16:53:57 : Box Successfully Initialized 16:53:57 : ================================================ 16:53:57 : 16:53:59 : 2010_000006y 16:56:51 : ================================================ 16:56:51 : Advance Turbo Flasher Found 16:56:51 : ================================================ 16:56:51 : Driver Version : 00021206 16:56:51 : Library Version : 00030210 16:56:53 : Box Type : AdvanceBox Turbo 16:56:53 : Box Firmware : LogiCore 10.3.12 16:56:53 : Software Version : v12.67 -------------------------- I insert MicroSD Card in the box. Pressing "Connection Manager" then "Read Card Info" I get error message ERROR: Failed to Initialize SDC Module 0x55 ERROR: Failed to Initialize SDC Module |
05-26-2016, 05:01 | #6 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
"QUERY RESULT - NOT FOUND" ??? - OLD version of ATF, Uninstall ATF , delete ATF folder , then install "Full Install 12.60" and continue update firmware Br - srinibas | |
05-26-2016, 16:28 | #7 (permalink) |
Member: 2574353 Status: Offline Thanks Meter: 0 | Removed 12.67 , Deleted Folder, Downloaded Full Install 12.60 Installed on my Windows 7 Computer as well as Windows 10 Computer Still Same Error "QUERY RESULT - NOT FOUND" Is there any way that i can Update my Firmware manually? Do you think the Machine is defective? I just purchased a week ago. I have no idea at this point on how can i update to Firmware 11.0.10 and make my MicroSD Reader working. |
05-26-2016, 23:02 | #8 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Use this procedure and re-Try to Update fw, later post screenshoot of you Atf nokia tabulate and "Connection Manager" tabulate. Tested from many user for Update Fw: http://forum.gsmhosting.com/vbb/f609...-here-2090299/ Br allumts |
The Following User Says Thank You to allumts For This Useful Post: |
06-07-2016, 02:35 | #9 (permalink) |
Member: 2574353 Status: Offline Thanks Meter: 0 | I tried this method as well, Updated host files accordingly. But still no luck. Any other ideas? [QUOTE=allumts;11840672]Use this procedure and re-Try to Update fw, later post screenshoot of you Atf nokia tabulate and "Connection Manager" tabulate. Tested from many user for Update Fw: |
