Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 04-13-2011, 13:48   #1 (permalink)
irish_4's Avatar
Member: 79870
Error in intalling Drivers.... - [Problem Fixed]
Hi advance team i have purchsed new ATF lightning and when i install the drivers it always give me this error.
Please help me how to fixed this problem.
By the way i use latest installer v7.40
Thanks in advance!
Old 04-13-2011, 13:54   #2 (permalink)
Advance-Box's Avatar
Member: 651945
@irish_4
What windows is this???
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 04-13-2011, 13:55   #3 (permalink)
Member: 464543
Sonork: 100.1622465
HI
i sloud your problem
add my yahoo messenger id p_sai67@yahoo.com
Old 04-14-2011, 00:58   #4 (permalink)
irish_4's Avatar
Member: 79870
Originally Posted by Advance-Box View Post
@irish_4
Hi,
boz x-shadow im using win xp sp3.
Old 04-14-2011, 01:01   #5 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
This error is in all new hardware FTD
Not ATF Only. Install all drivers again. maybe a virus found
B/R
The_Polack
Old 04-14-2011, 01:23   #6 (permalink)
irish_4's Avatar
Member: 79870
B/R
The_Polack
I've already uninstall and install again but its always give this error.
Old 04-14-2011, 08:17   #7 (permalink)
irish_4's Avatar
Member: 79870
Up!
Anybody from advance team please help me to solve this problem.
Old 04-14-2011, 08:21   #8 (permalink)
Member: 464543
Sonork: 100.1622465
h
Originally Posted by irish_4 View Post
Up!
HI
Old 04-14-2011, 08:29   #9 (permalink)
md.giousuddinso's Avatar
Member: 888599
Sonork: 100.1600952
first unplug your box.
Then Remove atf Driver from C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers. Reboot pc now
after that reinstall the driver.
Change the usb port. Don't use usb extension cable. Use direct usb2.0 port at the back part of the cpu.
Finally plug your box & try to update driver.
I think it could be helpful for you.
Thanks in advance
Old 04-14-2011, 13:11   #10 (permalink)
irish_4's Avatar
Member: 79870
Up!
still i cant install the driver properly..
anyone from advance team please help me solve this problem.
Old 04-14-2011, 13:50   #11 (permalink)
Member: 651945
@irish_4
This problem is caused by your Windows...
Try to login as Administrator.
Your windows priviledges might not be enough with your current user group.
As far as I can remember, you are the only one with this kind of unique problem.
Try Admin and test.
Old 04-14-2011, 13:56   #12 (permalink)
irish_4's Avatar
Member: 79870
As far as i know i didn't put any administrator password protection in my pc.
All my box is running properly when i installed its driver im only having problem installing ATF box driver.
Old 04-14-2011, 14:00   #13 (permalink)
Member: 651945
Try to delete or move these 2 files somewhere else...
ftdibus.cat
ftdiport.cat
Make sure there are no longer found here:
C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS\
Old 04-14-2011, 14:12   #14 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
I have this problem 2 time.
I solved Re-installing Windows XP.
Try deleteing all Ft*.* / restart pc / reinstal SP3 Again.
You have this problem with ATF or With all new Device FTD?
B/R
The_Polack
Old 04-14-2011, 14:15   #15 (permalink)
irish_4's Avatar
Member: 79870
Same problem sir...here is another error when i remove those two files.
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-12-2012 12:26
DES key Driver black Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-19-2012 05:32
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-28-1999 14:56
Page generated in 0.58022 seconds with 11 queries
