08-22-2015, 19:43 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Error no connect Lumia 710 ERROR: Qualcomm MMC Storage Mode is NOT FOUND Windows Phone Flashing Started OSBL File Found: RM809_OSBL_QUALCOMM.esco WARNING: MODEM AMSS File is not Loaded WARNING: MODEM ADSP File is not Loaded WARNING: WPOS File is not Loaded WARNING: UA ERASE File is not Loaded Factory Reset Skipped! ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 452 Bytes Status : WRITE OSBL CERTIFICATE SUCCESS Sending OSBL Data Blocks [BLOCK 1 0x00000000~0x000D5227] Data Size: 0x000D5228 Bytes SHA-256 : C603E58395ED18036FAE54480980C874 ---------- : 730B725073658C1DA8123C9B639F625A Status : OSBL WRITE SUCCESS Flashing Done! Total Flashing Time (Erase + Flashing) : 00:00:01 ERROR: Qualcomm MMC Storage is NOT FOUND Make sure your are running AdvanceBox.exe with Administrator Priviledges ================================================== ==== How To Run AdvanceBox.exe "as administrator" ================================================== ==== 1. Close ATF Software 2. Goto C:\AdvanceBox Turbo Flasher\ 3. Right-Click Mouse on File AdvanceBox.exe 4. Select "Run as administrator" Maybe your Phone is not running QCOM OSBL ================================================== ==== How To Enter Qualcomm MMC Storage Mode ================================================== ==== 1. Power OFF the Phone 2. Press and HOLD Volume UP Button on the Phone 3. Connect USB Cable to Phone Maybe your Phone is does not have QCOM OSBL ??? ================================================== ==== How To Put QCOM OSBL into the Phone ================================================== ==== 1. Lumia 710 - VIA USB Flashing 2. Lumia 800 - VIA TP Boot Repair 3. Other Lumia Models are NOT SUPPORTED |
