05-02-2014, 14:40 | #1 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 702472 Status: Offline Thanks Meter: 18 | ERROR: SDC Total Size is Not Enough ERROR: SDC Total Size is Not Enough I try 2 ;4 ;8 ;16:32G sd card but same when trying to SDC to revive samsung |
05-02-2014, 15:53 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | you are doing something wrong, i9300 only needs 2GB Note 3 needs 16GB i think your adapter is not working and that it is not detecting your cards properly. that is why I told you to post logs... but you still did not post any logs |
05-05-2014, 08:40 | #5 (permalink) |
Member: 702472 Status: Offline Thanks Meter: 18 | here is log of 4G testing I9300 just buy adapter from gsmserver if any problem will buy another Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x00 Application ID : Product Name : Product Revision : 0.0 Serial Number : 00000000 Manufacture Date: January 2000 Card CID: 00000000000000000000000000000000 Card CSD: 00000000000000000000000000000000 Card SCR: 0000000000000000 Card OCR: 0000000000 SD Card Size : 8 Bytes SD Block Size: 2 Bytes Maximum Speed: 100000 Hertz Checking Lock Status... Micro SD Card is NOT Password Protected!!! ================================================== ==== ERROR: SDC Total Size is Not Enough! Insert an SD Card with a Larger Capacity ================================================== ==== Total Elapsed Time 00:00:39 ERROR: WRITE FAILED! |
05-05-2014, 11:23 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Your adapter isn't detecting card properly. Look at Manufacture ID: 0x00, as well as other data from card was not read properly. So change your adapter. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
05-05-2014, 11:35 | #7 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Romania, Fagaras Age: 46
Member: 34379 Status: Offline Thanks Meter: 101 | Got same error with two adapters from GPG Card Reset Done! Initializing Micro SD Card... Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0xFF Application ID : ÿÿ Product Name : ÿÿÿÿÿ Product Revision : F.F Serial Number : FFFFFFFF Manufacture Date: January 2255 Card CID: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Card CSD: 00000000000000000000000000000000 Card SCR: FFFFFFFFFFFFFFFF Card OCR: 8000000000 SD Card Size : 8 Bytes SD Block Size: 2 Bytes Maximum Speed: 100000 Hertz Checking Lock Status... Micro SD Card is Password Protected!!! |
05-06-2014, 11:26 | #8 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, still your adapter is faulty. I also have an adapter from GPG and for me is working fine. You can also use an adapter from Smart-gsm Team if GPG adapters are faulty. BR |
05-07-2014, 11:39 | #9 (permalink) |
Member: 34379 Status: Offline Thanks Meter: 101 | Adapter fixed. Pin 4 in rj45 connector wasn`t properly inserted Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x03 Application ID : SD Product Name : SU02G Product Revision : 8.0 Serial Number : 60999C73 Manufacture Date: September 2009 Card CID: 03534453553032478060999C7300992B Card CSD: 002600325F5A83AEFEFBCFFF928040DF Card SCR: 0225800000000000 Card OCR: 0080FF8000 SD Card Size : 1977614336 Bytes SD Block Size: 1024 Bytes Maximum Speed: 25000000 Hertz Checking Lock Status... Micro SD Card is NOT Password Protected!!! Erasing SDC... Samsung GT-I9300, I9500, N7100 UNBRICK Image Start Writing to SDC at 0x00000000... Number of Blocks: 0x0002B055 Process Done... ================================================== ==== 1. Insert Micro SD Card to Phone 2. Make Sure Battery is Fully Charged 3. Connect UART Cable (150K Resistor) 4. Wait upto 5 Minutes... 5. Remove Battery and Remove Micro SD Card 6. Flash Phone with ODIN ================================================== ==== Total Elapsed Time 00:01:36 Write Success! |
