11-05-2014, 18:42 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: ***DUBAI*** Age: 38
Member: 1579234 Status: Offline Sonork: Not user Thanks Meter: 342 | ERROR: SDC Total Size is Not Enough hellp me I try 2--4-- sd card but same ERROR: SDC Total Size is Not Enough! Insert an SD Card with a Larger Capacity im Write ( SM-G7102_4.4.2_8GB_G7102XXUBNG8 ) [IMG][/IMG] hello me im Waiting Thanks --------------------- |
11-05-2014, 18:49 | #2 (permalink) | |
Registered User Join Date: Dec 2004 Location: largest democratic country
Member: 100376 Status: Offline Sonork: 100.1591842 Thanks Meter: 150 | Quote:
http://forum.gsmhosting.com/vbb/10584791-post8.html | |
The Following User Says Thank You to sabby_singh For This Useful Post: |
11-05-2014, 19:02 | #3 (permalink) | |
Member: 1579234 Status: Offline Sonork: Not user Thanks Meter: 342 | Quote:
11-05-2014, 19:25 | #4 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
SM-G7102_442_8GB_G7102XXUBNH6 Also read Here: http://forum.gsmhosting.com/vbb/f609.../#post10612575 P.d. Use Odin for Flash One package same Fw Version of Sdc File, if get Error, flash Only BL+PIT first. NOT FORGOT of take out Sd Card first of Flash. Br allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
11-05-2014, 19:29 | #5 (permalink) |
Member: 1579234 Status: Offline Sonork: Not user Thanks Meter: 342 | Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x84 Application ID : TF Product Name : MS Product Revision : 1.0 Serial Number : 193009F3 Manufacture Date: May 2014 Card CID: 8454464D5320202010193009F300E5D3 Card CSD: 400E00325B5900003ACD7F800A400097 Card SCR: 0235800300000000 Card OCR: 00C0FF8000 SD Card Size : 7892631552 Bytes SD Block Size: 512 Bytes Maximum Speed: 25000000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is NOT Password Protected!!! Erasing SDC... Samsung SM-G7102 UNBRICK Android 4.4.2 Start Writing to SDC at 0x00000000... Number of Blocks: 0x00040000 Process Done... ================================================== ==== 1. Insert Micro SD Card to Phone 2. Make Sure Battery is Fully Charged 3. Press Volume Down + Home + Power Button 4. Flash the Phone with ODIN ================================================== ==== Total Elapsed Time 00:01:20 Write Success! Thankss i use 8 GB card Done |
11-05-2014, 20:22 | #9 (permalink) | |
Have repaired in 5 min. 50 pieces of these, read link above and only after can see what you problem. Also read HERE: http://forum.gsmhosting.com/vbb/10566163-post52.html and Here: http://forum.gsmhosting.com/vbb/10584925-post67.html So, if you not are good, not write to other members of "NO WASTE TIME". BR | |
11-05-2014, 20:25 | #10 (permalink) | |
i not tell you sorry bro you not woring | |
11-05-2014, 20:29 | #11 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @I_PHONE, ok no problem all clear now, try only with ORIGINAL sd Card Samsung or San Disk, read about procedures in link above and you'll see that Unbrick easy this phone, Br allumts |
11-05-2014, 20:31 | #12 (permalink) |
Member: 1579234 Status: Offline Sonork: Not user Thanks Meter: 342 | thanksss bro done use 8 GB card Done -------------------------------------------- i downlod 4 file the Link http://susutun1.********.ae/2014/07/...sung-full.html Last edited by I_PHONE; 11-05-2014 at 20:36. |
11-05-2014, 21:11 | #13 (permalink) |
Member: 1579234 Status: Offline Sonork: Not user Thanks Meter: 342 | boot repair Done Bro Mobile downlod Mod done ----------------------------------------------------- bro i need file File PIT + BL + AP + CP and CSC ----------------------------------------------------- plz send me Link thanks im waitng |
11-05-2014, 21:18 | #14 (permalink) | |
Open link above and you'll see from where can download one package same version of sdc file. If have used sd card done with this fw: SM-G7102_4.4.2_8GB_G7102XXUBNH6 must need of download and Flash this same Fw version, can see in this site: "Samsung update . com" remove space from link. Post here Odin Log flash when have done. NOT FORGOT OF TAKE OUT SD CARD FIRST OF FLASH FW, NOT FLASH WITH CARD IN SLOT !!!!! | |
11-05-2014, 21:30 | #15 (permalink) | |
G7102XXUANE2/G7102XXUANE2/G7102XXUAML5 is 4.3 version you has used 4.4.2_8GB_G7102XXUBNH6 more High version. Download: 4.4.2_8GB_G7102XXUBNH6 | |
