11-24-2014, 06:45 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | ERROR: TRANSMISSION_TYPE_REQUEST_BB5 FAILED In X2-01 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_XSR16_usbalg .fg ERROR: TRANSMISSION_TYPE_REQUEST_BB5 FAILED Algorithm Loader Sent... Flashing Failed.... Booting/Flashing Failed... Please Try Again... Code: Number of Image Files: 3 Processing Image File : rm709__08.71.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 504 Entry Point: 0x01F2 Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm709__08.71.ppm_mh1 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 120 Entry Point: 0x0113 Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm709__08.71.image_mh1_059D363 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 438 Entry Point: 0x0147 Page Format : -1 MAX PAGE : 0x0000E000 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 86 (0x56) bytes returned Number of Sub Blocks 6 (0x06) 1 SYSTEM_ASIC_ID 01 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000000 ID DWORD 1 : 00000000 ID DWORD 2 : 22000509 ID DWORD 3 : 200C0000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00005361 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000000 ID DWORD 1 : 00CF7049 ID DWORD 2 : 87E875DC ID DWORD 3 : C42412B9 ID DWORD 4 : 7BCFFB8C 4 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 5 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E 6 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : DE56D582 CRC 1 : BDDE7A3A CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_usb2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0010 -> Device ID : 0011 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0030 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0431 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0030 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 08000000 (128 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_XSR16_usbalg.fg ERROR: TRANSMISSION_TYPE_REQUEST_BB5 FAILED Algorithm Loader Sent... Flashing Failed.... Booting/Flashing Failed... Please Try Again... |
11-24-2014, 07:50 | #3 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Sir i Try This Method But Again-2 This Error Show CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_XSR16_usbalg .fg ERROR: TRANSMISSION_TYPE_REQUEST_BB5 FAILED Algorithm Loader Sent... Flashing Failed.... Booting/Flashing Failed... Please Try Again... |
