02-25-2010, 18:18 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | error while flashing any phone 22:15:35 : AdvanceBox Turbo Flasher Found 22:15:35 : Initialize Device.... 22:15:35 : Init TRY : 1 22:15:35 : Changing Clock to 15mhz.. 22:15:35 : Box Name : AdvanceBox Turbo 22:15:35 : Box Firmware : LogiCore 1.16.10 22:15:35 : Software Version : v2010.0.1.21 22:15:35 : AdvanceBox SN : FF3EEB66FCAB09D5DB8D254B 22:15:35 : BOX Status : ACTIVATED 22:15:35 : DDR DELAY : 01 22:15:36 : INIT : OK 22:15:36 : 22:15:36 : VBATT OFF ... 22:15:36 : VBATT ON 22:15:37 : Setting VBATT Done!... 22:17:02 : AdvanceBox Turbo Flasher Found 22:17:02 : Initialize Device.... 22:17:02 : Init TRY : 1 22:17:02 : Changing Clock to 15mhz.. 22:17:02 : Box Name : AdvanceBox Turbo 22:17:02 : Box Firmware : LogiCore 1.16.10 22:17:02 : Software Version : v2010.0.1.21 22:17:02 : AdvanceBox SN : FF3EEB66FCAB09D5DB8D254B 22:17:02 : BOX Status : ACTIVATED 22:17:02 : DDR DELAY : 01 22:17:03 : INIT : OK 22:17:03 : 22:17:03 : Changing MODE : UART 22:17:03 : Changing MODE : UART 22:17:03 : Reading Phone Information... 22:17:03 : MCU: V ICPR82_09w36.5 09-10-09 RM-491 (c) Nokia 22:17:03 : IMEI: 354201032546588 22:17:03 : Simlock Version : SIMLOCK SERVER 22:17:03 : CONFIG KEY: 0000000000000000 22:17:03 : PROVIDER KEY: 2440700000000000 22:17:03 : Provider : AT&T;U.S.A. (3650) 22:17:04 : Counters : 0/3 , 0/10 22:17:04 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 22:17:04 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 22:17:04 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 22:17:04 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 22:17:04 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 22:17:04 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 22:17:04 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 22:17:04 : SP Lock Status : Not Locked 22:17:04 : Product code : 0576768 22:17:04 : SL2 Phone Detected... 22:17:10 : Certificate saved to : C:\AdvanceBox\AdvanceBox_BETA_V3\Nokia\Backup\sl2_ certificate_V ICPR82_09w36.5 09-10-09 RM-491 (c) Nokia_354201032546588_Not Locked_101704.pm 22:17:11 : Changing MODE : FLASH 22:17:11 : ================================================== = 22:17:11 : AdvanceFBox SendBootCodeEx 22:17:11 : InitialiseBootstrap_DCT5 DIR 22:17:11 : BootFlashMode_DCT5 22:17:11 : AdvanceBox Turbo Flasher Found 22:17:11 : Initialize Device.... 22:17:11 : Init TRY : 1 22:17:11 : Changing Clock to 15mhz.. 22:17:12 : Box Name : AdvanceBox Turbo 22:17:12 : Box Firmware : LogiCore 1.16.10 22:17:12 : Software Version : v2010.0.1.21 22:17:12 : AdvanceBox SN : FF3EEB66FCAB09D5DB8D254B 22:17:12 : BOX Status : ACTIVATED 22:17:12 : DDR DELAY : 01 22:17:12 : INIT : OK 22:17:12 : 22:17:12 : VBATT OFF ... 22:17:15 : VBATT ON 22:17:16 : Setting VBATT Done!... 22:17:16 : AdvanceFBox SendBootCodeEx 22:17:16 : InitialiseBootstrap_DCT5 DIR 22:17:16 : BootFlashMode_DCT5 22:17:16 : BootFlashModeDCT5Ex Failed 22:17:16 : Failed to complete RPL backup.. 22:17:16 : ================================================== = 22:17:16 : Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-491\rm491_022.013_prd.core.fpsx 22:17:16 : CMT Type : BB5 22:17:16 : CMT Algorithm : XSR 1.6 22:17:16 : CMT Supported Hardwares : 22:17:16 : > 4003192102001104 22:17:16 : > 400C192102001104 22:17:16 : > 6003192102001104 22:17:16 : > 600C192102001104 22:17:16 : > 6003192102011104 22:17:17 : > 600C192102011104 22:17:17 : > 6003192102021104 22:17:17 : > 600C192102021104 22:17:17 : Secondary Sending Speed : 650000Hz 22:17:17 : Algorithm Sending Speed : 6500000Hz 22:17:17 : Program Sending Speed : 6500000Hz 22:17:17 : Message Reading Speed : 98000Hz 22:17:17 : Number of Blocks : 464 22:17:17 : Entry Point: 0x01DA 22:17:17 : Page Format : -1 22:17:17 : MAX PAGE : 0x00040000 22:17:17 : AdvanceFBox SendBootCodeEx 22:17:17 : InitialiseBootstrap_DCT5 DIR 22:17:17 : BootFlashMode_DCT5 22:17:17 : AdvanceFBox SendBootCodeEx 22:17:17 : InitialiseBootstrap_DCT5 DIR 22:17:17 : BootFlashMode_DCT5 22:17:17 : AdvanceBox Turbo Flasher Found 22:17:17 : Initialize Device.... 22:17:17 : Init TRY : 1 22:17:17 : Changing Clock to 15mhz.. 22:17:18 : Box Name : AdvanceBox Turbo 22:17:18 : Box Firmware : LogiCore 1.16.10 22:17:18 : Software Version : v2010.0.1.21 22:17:18 : AdvanceBox SN : FF3EEB66FCAB09D5DB8D254B 22:17:18 : BOX Status : ACTIVATED 22:17:18 : DDR DELAY : 01 22:17:18 : INIT : OK 22:17:18 : 22:17:18 : VBATT OFF ... 22:17:21 : VBATT ON 22:17:22 : Setting VBATT Done!... 22:17:22 : AdvanceFBox SendBootCodeEx 22:17:22 : InitialiseBootstrap_DCT5 DIR 22:17:22 : BootFlashMode_DCT5 22:17:22 : BootFlashModeDCT5Ex Failed 22:17:22 : Operations Failed.... 22:17:34 : AdvanceBox Turbo Flasher Found 22:17:34 : Initialize Device.... 22:17:34 : Init TRY : 1 22:17:34 : Changing Clock to 15mhz.. 22:17:34 : Box Name : AdvanceBox Turbo 22:17:34 : Box Firmware : LogiCore 1.16.10 22:17:34 : Software Version : v2010.0.1.21 22:17:34 : AdvanceBox SN : FF3EEB66FCAB09D5DB8D254B 22:17:34 : BOX Status : ACTIVATED 22:17:35 : DDR DELAY : 01 22:17:35 : INIT : OK 22:17:35 : 22:17:35 : Changing MODE : UART 22:17:35 : Changing MODE : UART 22:17:35 : Reading Phone Information... 22:18:01 : MCU: V ICPR82_09w36.5 09-10-09 RM-491 (c) Nokia 22:18:01 : IMEI: 354201032546588 22:18:01 : Simlock Version : SIMLOCK SERVER 22:18:01 : CONFIG KEY: 0000000000000000 22:18:01 : PROVIDER KEY: 2440700000000000 22:18:01 : Provider : AT&T;U.S.A. (3650) 22:18:01 : Counters : 0/3 , 0/10 22:18:01 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 22:18:01 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 22:18:01 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 22:18:01 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 22:18:01 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 22:18:01 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 22:18:01 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 22:18:01 : SP Lock Status : Not Locked 22:18:02 : Product code : 0576768 22:18:02 : SL2 Phone Detected... 22:18:09 : Certificate saved to : C:\AdvanceBox\AdvanceBox_BETA_V3\Nokia\Backup\sl2_ certificate_V ICPR82_09w36.5 09-10-09 RM-491 (c) Nokia_354201032546588_Not Locked_101802.pm 22:18:09 : Changing MODE : FLASH 22:18:09 : ================================================== = 22:18:10 : AdvanceFBox SendBootCodeEx 22:18:10 : InitialiseBootstrap_DCT5 DIR 22:18:10 : BootFlashMode_DCT5 22:18:10 : AdvanceBox Turbo Flasher Found 22:18:10 : Initialize Device.... 22:18:10 : Init TRY : 1 22:18:10 : Changing Clock to 15mhz.. 22:18:11 : Box Name : AdvanceBox Turbo 22:18:11 : Box Firmware : LogiCore 1.16.10 22:18:11 : Software Version : v2010.0.1.21 22:18:12 : AdvanceBox SN : FF3EEB66FCAB09D5DB8D254B 22:18:12 : BOX Status : ACTIVATED 22:18:12 : DDR DELAY : 01 22:18:12 : INIT : OK 22:18:12 : 22:18:12 : VBATT OFF ... 22:18:15 : VBATT ON 22:18:15 : Setting VBATT Done!... 22:18:16 : AdvanceFBox SendBootCodeEx 22:18:16 : InitialiseBootstrap_DCT5 DIR 22:18:16 : BootFlashMode_DCT5 22:18:16 : BootFlashModeDCT5Ex Failed 22:18:16 : Failed to complete RPL backup.. 22:18:16 : ================================================== = 22:18:16 : Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-491\rm491_022.013_prd.core.fpsx 22:18:16 : CMT Type : BB5 22:18:16 : CMT Algorithm : XSR 1.6 22:18:16 : CMT Supported Hardwares : 22:18:16 : > 4003192102001104 22:18:16 : > 400C192102001104 22:18:16 : > 6003192102001104 22:18:16 : > 600C192102001104 22:18:16 : > 6003192102011104 22:18:16 : > 600C192102011104 22:18:16 : > 6003192102021104 22:18:16 : > 600C192102021104 22:18:16 : Secondary Sending Speed : 650000Hz 22:18:16 : Algorithm Sending Speed : 6500000Hz 22:18:16 : Program Sending Speed : 6500000Hz 22:18:16 : Message Reading Speed : 98000Hz 22:18:16 : Number of Blocks : 464 22:18:16 : Entry Point: 0x01DA 22:18:16 : Page Format : -1 22:18:16 : MAX PAGE : 0x00040000 22:18:17 : AdvanceFBox SendBootCodeEx 22:18:17 : InitialiseBootstrap_DCT5 DIR 22:18:17 : BootFlashMode_DCT5 22:18:17 : AdvanceFBox SendBootCodeEx 22:18:17 : InitialiseBootstrap_DCT5 DIR 22:18:17 : BootFlashMode_DCT5 22:18:17 : AdvanceBox Turbo Flasher Found 22:18:17 : Initialize Device.... 22:18:17 : Init TRY : 1 22:18:17 : Changing Clock to 15mhz.. 22:18:18 : Box Name : AdvanceBox Turbo 22:18:18 : Box Firmware : LogiCore 1.16.10 22:18:18 : Software Version : v2010.0.1.21 22:18:18 : AdvanceBox SN : FF3EEB66FCAB09D5DB8D254B 22:18:18 : BOX Status : ACTIVATED 22:18:18 : DDR DELAY : 01 22:18:18 : INIT : OK 22:18:18 : 22:18:18 : VBATT OFF ... 22:18:21 : VBATT ON 22:18:22 : Setting VBATT Done!... 22:18:22 : AdvanceFBox SendBootCodeEx 22:18:22 : InitialiseBootstrap_DCT5 DIR 22:18:22 : BootFlashMode_DCT5 22:18:22 : BootFlashModeDCT5Ex Failed 22:18:22 : Operations Failed.... |
02-26-2010, 05:48 | #3 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | check with 3 different cables and tried with 3 (3110,e52,6710)phones later i flash with hwk ok,and without conecting phone same error when i click on buscheck logs 10:15:55 : AdvanceBox Turbo Flasher Found 10:15:55 : Initialize Device.... 10:15:55 : Init TRY : 1 10:15:56 : Init TRY : 2 10:15:56 : Changing Clock to 15mhz.. 10:15:56 : Box Name : AdvanceBox Turbo 10:15:56 : Box Firmware : LogiCore 1.16.10 10:15:56 : Software Version : v2010.0.1.21 10:15:56 : AdvanceBox SN : FF3EEB66FCAB09D5DB8D254B 10:15:56 : BOX Status : ACTIVATED 10:15:56 : DDR DELAY : 01 10:15:56 : INIT : OK 10:15:56 : 10:15:56 : VBATT OFF ... 10:15:57 : VBATT ON 10:15:57 : Setting VBATT Done!... 10:16:03 : AdvanceBox Turbo Flasher Found 10:16:03 : Initialize Device.... 10:16:03 : Init TRY : 1 10:16:03 : Changing Clock to 15mhz.. 10:16:04 : Box Name : AdvanceBox Turbo 10:16:04 : Box Firmware : LogiCore 1.16.10 10:16:04 : Software Version : v2010.0.1.21 10:16:04 : AdvanceBox SN : FF3EEB66FCAB09D5DB8D254B 10:16:04 : BOX Status : ACTIVATED 10:16:04 : DDR DELAY : 01 10:16:04 : INIT : OK 10:16:04 : 10:16:04 : Changing MODE : FLASH 10:16:04 : AdvanceBox Turbo Flasher Found 10:16:04 : Initialize Device.... 10:16:04 : Init TRY : 1 10:16:05 : Changing Clock to 15mhz.. 10:16:05 : Box Name : AdvanceBox Turbo 10:16:05 : Box Firmware : LogiCore 1.16.10 10:16:05 : Software Version : v2010.0.1.21 10:16:05 : AdvanceBox SN : FF3EEB66FCAB09D5DB8D254B 10:16:05 : BOX Status : ACTIVATED 10:16:05 : DDR DELAY : 01 10:16:05 : INIT : OK 10:16:05 : 10:16:05 : VBATT OFF ... 10:16:08 : VBATT ON 10:16:09 : Setting VBATT Done!... 10:16:09 : BootFlashModeDCT5Ex Failed 10:16:09 : Process Done! |
03-02-2010, 05:01 | #8 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: India Age: 46
Member: 129258 Status: Offline Thanks Meter: 105 | Quote:
Dear friends, This box have hardware problem please contact your reseller for repair it. Br. Aruna Export Jignesh Mobile: 9898182899 | |
03-02-2010, 09:30 | #9 (permalink) | |
Freak Poster Join Date: Jan 2010 Location: ? Age: 57
Member: 1198691 Status: Offline Sonork: 1589060 Thanks Meter: 148 | Quote:
Error while flashing PDA! PHONE STATE: "UNKNOWN" [00000000] | rundll-exe | SETool2 | 0 | 03-26-2009 21:40 |
Buffer Overrun detected: error while flashing phone | Sam-TheMaster | UST Pro II | 2 | 12-03-2008 07:53 |
Funny Error While Flashing Dct4 Phones | Black-Axe | Nokia Digital Core Technology 4 ( DCT-4 ) | 10 | 07-25-2005 17:48 |
MYX1 error while flashing! now unable to connect the phone to the soft??? | AE177 | SagMaster Team OLD Products | 7 | 09-20-2004 21:14 |
