Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 01-24-2014, 16:21   #1 (permalink)
tozbeka's Avatar
Member: 1651733
Thanks Meter: 21
lumnia 520 Dead after Flash
hellow bro pls help me this is my second 520 after flash goin dead pls help here is my log
Loading Flash Files Please Wait...
Windows Phone 8 Lumia Flasher
If the Phone is ALIVE
1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
1. Connect Phone to the USB Port
2. Press and Hold the VOLUME DOWN and POWER Buttons
3. Wait until the Phone Vibrates Shortly...
4. Stop Pressing the Buttons...
IMEI: 358352056399259
Version: 1.1.1.3
Product Code: 059S1T3
Module Code: 0205435
Boot Flash Mode Successful...
Phone Info Query Start...
Blocks Returned: 0x07 Blocks
Block ID 0x01 : 00241000
Block ID 0x02 : 00240000
Block ID 0x03 : 00E90000
Block ID 0x05 : Nokia.MSM8227.P6036.1.2
Block ID 0x0D : 0001
Block ID 0x0F : 0301010100000101FF
Block ID 0x10 : 0100030000
Checking SD Card Size...
Card Size: 0x00000000
Checking Platform Security Status...
Platform Secure Boot Status: Active
Secure FFU EFUSE Status: Active
Debug Status: Active
RDC Status: Not Active
Authentication Status: Not Active
UEFI Secure Boot Status: Active
Checking Secure FFU Mode...
Secure FFU Mode : SYNC + ASYNC
Query Flash App Information...
Flash App Information: 02010C011700
UEFI App: FLASH APP
Flash App Protocol Version: 1.12
Flash App Implementation Version: 1.23
Query ROOT KEY HASH...
ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD
Sending Image Signatures...
Image Signatures Accepted!
Erasing Data Partition...
Data Partition Erased Successfully
Preparing Buffers for DATA LOOP...
Allocating System RAM OK!
Start Sending DATA BLOCKS...
ERROR: LAST DATA BLOCK REJECTED!
Check your Flash File and Phone Connection
ERROR: Flashing Failed!
Old 05-01-2014, 10:03   #2 (permalink)
Crazy Poster
Member: 1682468
Thanks Meter: 6
plise solution sirr im similar cases for atf nitro
Old 05-01-2014, 11:49   #3 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Phone could be dead if (flash file used are for other rm-xxx / USB communication problem)
Error on last data block shouldn't make phone dead, check with other fully charged battery. It might be in Recovery mode / Red Nokia logo. If not, then you need to repair phone's boot with ATF.
I and many other users daily flashing lumia phone with ATF, and not a single phone was dead on flashing with me. So the problem must be from your side and not ATF software.
Check/Change USB Port or USB cable first
Double check your flash files, they are for correct rm-xxx as your phone you flashing
Sometime flash files are not fully downloaded. So download files once again to make sure if they are not corrupted.
Old 05-01-2014, 13:19   #4 (permalink)
Crazy Poster
Member: 1682468
Thanks Meter: 6
thank you for his response, but after flashing and have error at the end of the (failed) I now have a new problem nokia lumnia could not conect from usb lumnia 520 Dead after flash (no response at ATF nitro) lumnia 520 if I experience dead boot ...? whether the need is there jtag jtag and her ..? or jtag no other way than to be able to conect via USB or needs to repair the boot ...? please solution for this
thank U
br
david delta
Old 05-01-2014, 14:40   #5 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
You can repair boot via eMMC if you do not want to pay for JTAG activation.
ATF supports boot repair via eMMC since more than 1 year already.
Last block error does not result in dead phone. Phone will only die if:
1. Your flash file is corrupted
2. Flashing failed before 5% progress is reached
3. Battery became empty during flashing... and it is an internal battery.
Dead Lumia does not charge battery at all.
B.R.
Page generated in 0.13375 seconds with 8 queries
