Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 10-28-2010, 13:59   #1 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
F.A.Q - Frequently Asked Questions !
Kaspersky detects as virus - Advancebox.exe
There's no risk if you download from official support area: ATF DOWNLOAD SITE - powered by Advance Team
How to solve this if Kaspersky detects as virus ?
Disable antivirus,
Goto > Kaspersky setting > Options > Thereats and Exclusion > Exclusions Setting > Add Advancebox.exe to 'Exclusion list'
The Following 26 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 01-22-2011, 10:11   #2 (permalink)
Member: 643472
Sonork: 100.96901
How to 5800 solve 'half LCD' problem after flash with, v50.xx - v51.xx - v52.xx
5800 problem
The Following 3 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 01-22-2011, 10:34   #3 (permalink)
Member: 643472
Sonork: 100.96901
*** How to EraseFlash BB5 phones ***
1. Backup RPL - NPC, CCC and HWC certificates.
2. Go to EraseFlash tab, select your phone flash size, how to know flash size: F.A.Q - Frequently Asked Questions !
3. Select your phone ASIC and Flash type, how to know flash_type and asic: F.A.Q - Frequently Asked Questions ! - and erase phone afterwards.
4. Flash phone with your desire version. Better, same product code file.
5. Write RPL backup
6. Repair SIMLocks from IMEI and Locks tab. 'Repair SIMLocks (Online Method)'
7. Repair SD and make SX4 auth from PM tab. 'Customized SX4 auth with SD repair' SW will ASK you to load PM 1 and 309 to complete the process.
If you will follow the steps correctly. Phone will be OK
Video tutorials for more help: http://forum.gsmhosting.com/vbb/f609...e-box-1126748/
The Following 13 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 02-02-2011, 09:47   #4 (permalink)
Member: 643472
Sonork: 100.96901
*** ATF lighting and ATF box ***
Q: ATF lighting and ATF box which one better?
A: Both are better and original one. It's up to you which one you want to buy, for 'Desktop' - we will suggest to buy ATF box, for 'Laptops' - we will suggest you buy ATF lighting. It is still depends on you though.
Q: What is the difference between ATF lighting and ATF box?
A: No changes in hardware, just ATF lighting is small where ATF box is big.
Q: What about support of ATF lighting?
A: Support and software is same for both boxes.
Q: Is there any price differences in both boxes?
A: Yes, ATF lighting - you can get in bit cheaper price than ATF box, because of ATF lite size, is small and it's shipping cost is less than ATF box.
Q: There is no 'Extension port' in ATF lighting, How can we flash 'Nokia infineon' phones?
A: You can use that RJ45 socket in order to flash 'Nokia infineon' and all rest supported phones.
Q: Can we use JAF/UFS cables with ATF lighting?
A: Yes, they are compatible also but we recommend to use 'good quality' FBUS cables.
Hope that little FAQ helps.
The Following 28 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 03-02-2011, 16:14   #5 (permalink)
Member: 643472
Sonork: 100.96901
SuperDongle Repair for Nokia SL3 phones:
Q: New box comes with pre-activated?
A: No, You have to activate this feature byself.
Q: ATF box is damaged somehow now can i transfer activation to other new box?
A; Yes, in that case. We can do that.
Q: Can i transfer my activation from one to another box sn?
A: No, activations cannot be transfered.
Q: Can i repair damaged SIMLocks - ST_Security_failed?
A: No, It cannot be repaired. This feature is for reparing SuperDongle data in all Nokia SL3 phones.
Q: What is price for ATF Network activation?
A: 99usd ONLY
Q: How many credits for each SD RPL?
A: 5 credits for each SD RPL after You activated box for ATF Network function
Q: Where to buy activations and credits?
A: You can buy online from software:
1. Go to ATF Store tab - it next to 'Product Support'
2. Click 'Visit the ATF Store'
3. Select quentity of credits. You want from combobox
4. Add your AdvanceBox SN into textbox
5. Click BUY ONLINE NOW and follow rest paypal process
6. You can also buy credits and activations from Authorized Distributors and Resellers
Hope that helps.
The Following 8 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 03-21-2011, 17:47   #6 (permalink)
Member: 643472
Sonork: 100.96901
Direct unlocking 47xx HASH
How to Direct unlock 47xx HASH phones:
1. Go to ATF Network tab
2. Authorize phone
3. Go to IMEI and Locks
4. Click to SIMLock repair SL1/SL2
5. Phone is unlocked ;O) without to Brute force unlock codes
First in the world ONLY with ATF Network
Tested phones: 6120c with 47xx and 6760s with 47xx
Last edited by ..::Angel::..; 05-07-2011 at 16:02. Reason: removed credits - is free now
The Following 25 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 03-29-2011, 21:12   #7 (permalink)
Member: 643472
Sonork: 100.96901
How to 'Decrypt PM120 Hashes - any BB5 HASH without credits:
- Box must be activated for ATF Network account.
1. Go to ATF Network page
2. Click to 'Authorizea a BB5 Phone [NEW HASH]'
3. Go to 'IMEI and Locks' tab
4. Tick to 'Decrypt PM120 hashes'
5. Click 'Execute Selected Task' button
...now you are done. ATF software will make 4 differ files.
You can use those files to make LBF or upload xxxx.job file to ATF Server for Fastest BF unlock ..
Related thread: How to upload JOB files for BF unlock
How to Authorize and Decrypt BB5 phones via USB cable:
Problem reading c3-00 hash
The Following 12 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 05-24-2011, 16:25   #8 (permalink)
Member: 643472
Sonork: 100.96901
Problems:
* No ATF Box Found
* USB Serial Converter A + USB Serial Converter B - in 'Device Manager'
* Repair box EEPROM
How to solve, check here with screen shots:
No ATF Box Found(Solution Here)
thnx to @SHIJILFONOTLY
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 05-24-2011, 16:30   #9 (permalink)
Member: 643472
Sonork: 100.96901
ATF drivers probelm - Show only Turbo Nitro on main screen. How to solve, check here with screen shots:
Atf box connection problem solved here
thnx to @..::AppleLinks::..
Old 06-04-2011, 14:59   #10 (permalink)
Member: 643472
Sonork: 100.96901
How to add AdvanceBox.exe into Windows firewall Exception list:
DDR Transmission Error
Thnx to @SHIJILFONOTLY
Old 08-26-2011, 12:17   #11 (permalink)
Member: 643472
Sonork: 100.96901
Frequently Asked Questions:
Q: What is cost for per SL3 unlock?
A: 30USD = 30 Credits
Q: How to check estimated time for next uploaded IMEI on server?
A: It can be checked at our webiste: Advance Turbo Flasher - By Advance Team and software will show also you ETA when you upload a job on server
on website:
Q: Where can I buy credits for SL3 BF unlock?
A: You can buy directly from ATF Store in software, or you can buy it from authorized distributors and resellers
Q: Can I use ATF Network activation credits for SL3 BF unlock?
A: No, they are differ credits and cannot be used for SL3 BF unlock
Q: Can I use ATF BF credits for ATF Network activation?
A: No, these credits cannot be used for box activations
Q: I got my codes like this: IMEI: 35xxxxxxxxxx and Master code: 010203040506xxxxxxxxxx - how to get 15-digits NCK?
A: Check here: How to calc 15-digit NCK from BF Result !! - [Standalone, without phone connected!]
Q: Can I unlock Nokia SL3 telcel network phones?
A: No, telcel phones does NOT accept NCK codes. However, they are correct ones. Just do NOT upload any telcel phone on server, as there will be no refund
Q: Can I upload SL3 20-digit phones?
A: No, do NOT upload phones with 20-digit codes. There will be no refund for it
Q: Any list of supported phones by ATF BF server?
A: Yes, here: http://forum.gsmhosting.com/vbb/f609...twork-1221917/
Happy unlocking !
The Following 22 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 10-02-2011, 10:20   #12 (permalink)
Member: 643472
Sonork: 100.96901
How to Downgrade SL3 phones:
How to downgrade PA_SL3/PA_SIMLOC30 phones
Old 11-11-2011, 11:00   #13 (permalink)
Member: 643472
Sonork: 100.96901
How to transfer ATF Network credits:
*****How to transfer ATF Network credits from one box to another*****
Old 02-18-2012, 09:15   #14 (permalink)
Member: 643472
Sonork: 100.96901
How to unlock SL3 phones with ATF Server:
1. Check ETA before upload: ✚✚✚✚✚✚✚✚✚✚✚✚✚ ATF SL3 BruteForce Server Time Inside ✚✚✚✚✚✚✚✚✚✚✚✚✚
2. Read PM120 HASH. How to: F.A.Q - Frequently Asked Questions !
3. Upload xxxxx.job file to server. How to: How to upload JOB files for BF unlock
4. Get MasterCode from server and calc NCK from it. How to: How to calc 15-digit NCK from BF Result !! - [Standalone, without phone connected!]
20 ATF BF Credits are required for each SL3 phone unlock via ATF Server.
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 04-11-2012, 13:49   #15 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Sonork: 100.1581941
Atf Not Detected PC(Solution Here) NEW BOX
Look here:
Atf Not Connect PC(Solution Here)
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Questions about Dejan's flasher interface SashaM Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 9 01-15-2001 08:31
8890 questions spongebob Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 01-10-2001 00:04
I have that soft if smb need ask for testing.. Nec Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-01-2000 22:47
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-26-1999 14:31
Question about 51xx/61xx Comic Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-06-1999 23:47
Page generated in 0.86045 seconds with 11 queries
