Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 08-18-2012, 12:12   #16 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
F.A.Q - SL3 SIMLock Recovery!
Q: How to Recover SIMLock from Full Flash Dump ???
A: Go to IMEI and LOCKS->SL3 Recovery->Level 1 - Recover from Dump File
Press "Start Recovery" button, Select your DUMP File
Recovered SIMLock will be saved: "\Nokia\Recovered\FLASH_DUMP.bin.pm"
Q: How to Recover SIMLock Direct from connected Phone ???
A: Authorize Phone first from ATF Network tab (Activation Required)
Go to IMEI and LOCKS->SL3 Recovery->Level 2 - Recover from Phone
Press "Start Recovery" button and follow instructions
Recovered SIMLock will be saved: "\Nokia\Backup\357xxxx\357xxxx
RECOVERED_12D108A9.pm"
Q: "Level 3 Recovery is NEEDED for this Phone" ???
A: Go to IMEI and LOCKS->LOGIN->Sumbit SRP File (Activation Required + 25 ATF BF/SRP Credit)
Select SIMLock Recover Profile: "\Nokia\Backup\354xxxx\354xxxx_D8DF60B
0B3C8F289AA89C220.srp
Check after few hours ATF Support Site login from Software
"SL3 SIMLock Recovery" - there your simlock file can be downloaded
P.S. Phone which was unlocked before using BF/Network code will RE-LOCKED again
after SL3 Recovery Level 3. Your previous code from BF/Network code will work to unlock
phone again or you'll need to BF/buy code for it again.
How to upload SRP File to ATF Server (for Level 3 only)
The Following 20 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 09-18-2012, 10:44   #17 (permalink)
Member: 643472
Sonork: 100.96901
ATF Box Credits:
There are few types of credit system...
- ATF Network credit - uses for Box activations only - can't be converted to ANY other credit,
they are "AS IS".
- ATF BF credit - uses for upload SL3 Unlock Files via ATF BF Server - can be converted to ONLY SRP credit,
if user wish to, else can buy direct SRP
- ATF SRP credit - uses for upload SRP Files (Simlock Recovery Profile) - can't be converted to ANY other credit, they are "AS IS".
- ATF iCredit - uses for iDevices IMEI Network Information, Network SIM Unlock for Specific Networks and IMEI Un-Barring Request for Specific Networks - can't be converted to ANY other credit, they are "AS IS".
Old 10-04-2012, 10:26   #18 (permalink)
Member: 643472
Sonork: 100.96901
How to Put Nokia DLOAD Boot-loader to Lumia phones:
Lumia 800 flash problem <<< SOLVED - SOLUTION INSIDE >>>
Old 10-22-2012, 10:27   #19 (permalink)
Member: 643472
Sonork: 100.96901
How to UNLOCK Lumia phones:
lumia 800 unlock pls help.......
Old 11-26-2012, 10:20   #20 (permalink)
Member: 643472
Sonork: 100.96901
How to Decrypt XG213 HASHES for BF unlock:
Send Unlock Codes over USB cable:
Last edited by ..::Angel::..; 11-27-2012 at 12:30. Reason: added unlock codes tut.
The Following 22 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 12-16-2012, 09:38   #21 (permalink)
Member: 643472
Sonork: 100.96901
Hi, small F.A.Q on Lumia...
Q: Which Lumia phones we could unlock with ATF ?
A: Lumia 710 and 800 - all varient... different rm-xxx supported via TP unlock.
Q: Which Lumia phones we could repair boot-loaders with ATF ?
A: All Lumia Windows Phone 7 are supported for boot-loader repair via TP.
Q: Where can I find lumia Test Points ?
A: Here: "C:\AdvanceBox Turbo Flasher\Nokia\Lumia\TP_PIX"
Q: Can I unlock Lumia phones via USB cable with ATF ?
A: Yes, 710 is fully supported via USB cable unlock. For Lumia 800, it MUST
have OSBL QUALCOMM boot-loader inside in order to make USB unlock...
otherwise, TP unlock will only work.
Q: Is unlocking of lumia permanently ?
A: No. Its a patch-unlock, so after flashing firmware phone will be again locked.
Q: My lumia phone have "0" counter left, can I unlock this phone ?
A: Yes, counters can be back to "10" left, after flashing firmware. So you can
also unlock.
Q: I have dead lumia phone, can I repair it with ATF ?
A: Yes, can repair it. ATF supports boot-loader repairing and flashing afterwards.
Q: Do I need ANY activation for Lumia unlock, repair boot-loader ?
A: No. The update is FREE for ALL ATF BOX users....
BR, ATF Team.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 01-23-2013, 14:37   #22 (permalink)
Member: 643472
Sonork: 100.96901
How to Decrypt XGOLD 1xx PM120 HASHES for BF Unlock:
The Following 5 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 02-09-2013, 21:17   #23 (permalink)
Member: 643472
Sonork: 100.96901
Just to merge all threads from sticky,, they are moved to F.A.Q:
Video Tutorials:
Video tutorials for AdvanceBox Turbo Flasher
Supported models for SL3 unlock, repair etc.
*** Supported SL3 phones for UNLOCK/SD Repair/SX4 Auth by ATF Network ***
How to use ATF AUTO UPDATE feature - Tutorial:
How to use ATF AUTO-UPDATE Feature [Tutorial]
How to upload SRP file to ATF Server:
Important info before you TP unlock lumia:
<<<<<<<<IMPORTANT INFORMATION BEFORE YOU TP UNLOCK LUMIA 800 RM-801 or RM-819>>>>>>>>
ATF Windows 8/7/XP/32 bit/64 bit signed usb drivers:
ATF Official Windows 8/7/XP 32-bit/64-bit Signed USB Drivers
Repair XGOLD phones SIMLOCKS caused by wrong counter reset:
Repair SIMLocks for FREEE on all XGold phones
Nokia N9: ERROR: MEEGO Device Flashing Failed!
Firmware Version Downgrade NOT ALLOWED
N9 downgrade not allowed - ultimate guide inside !!!
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 02-10-2013, 19:00   #24 (permalink)
Member: 643472
Sonork: 100.96901
How to repair dead Lumia phones:
  • Solder Test Point wires to Lumia
  • Select Model from Windows Phone tab
  • Make sure Correct Phone Type is selected on "TP Services" tab
  • Click on "Test Connection" button to check TP connection
  • And wait until the ATF Software will tell you to Connect the USB cable
  • Once your Lumia is Detected
  • Check to: M.B.R. (Master Boot Record), SEC_BOOT and OSBL DLOAD (Nokia)
  • Click on "REPAIR BOOT" button
How to unlock Lumia 710 and 800:
  • Select Model from "Windows Phone" tab
  • Press "SP Unlock" button
How to change Lumia boot-loader from OSBL DLOAD to OSBL QUALCOMM and vice versa:
  • Check OSBL QCOM (QUALCOMM) or OSBL DLOAD (NOKIA)
Old 02-10-2013, 19:10   #25 (permalink)
Member: 643472
Sonork: 100.96901
Possible errors during lumia phones unlock and it's solutions:
Error log from software:
ERROR: Dump Aborted, Too Much Read Failures!
Solution:
1. Check for short circuit on TP area
2. Try with ATF Nitro/Lightning, this error mostly with ATF Big Box
3. Using ATF Big Box change boot-loader to OSBL QCOM and unlock via USB cable from eMMC Direct tab
X. for boot-loader change, check previous post!
WARNING: Patch Bit NOT FOUND!
Maybe Phone is already UNLOCKED!
Solution:
Flash your lumia phone with latest available version and unlock again
Old 03-19-2013, 11:06   #26 (permalink)
Member: 643472
Sonork: 100.96901
How to repair dead Lumia 505, 510 and 610 phones:
  • Check to: M.B.R. (Master Boot Record), SEC_BOOT, OSBL DLOAD (Nokia) and QCSBL
  • If phone still dead, then need to flash the phone via USB cable
Old 03-25-2013, 11:09   #27 (permalink)
Member: 643472
Sonork: 100.96901
How to Restore OSBL DLOAD for Lumia 710 only:
  • Go to "eMMC Direct" tab
  • Press VOL UP and connect USB cable to powered off phone
  • Click on "Scan Partitions"
  • Click on "Restore DLOAD"
Now phone will be able to take flashing by ATF or any othe Nokia software....
Old 05-03-2013, 12:15   #28 (permalink)
Member: 643472
Sonork: 100.96901
Lumia supported models for Dead Boot Repair via Test Points:
WP7x:
  • Lumia 505 (RM-923)
  • Lumia 510 (RM-889, RM-898)
  • Lumia 610 (RM-835, RM-849)
  • Lumia 610C (RM-836)
  • Lumia 710 (RM-803, RM-809)
  • Lumia 800 (RM-801, RM-819)
  • Lumia 800C (RM-802)
  • Lumia 900 (RM-808, RM-823)
WP8:
  • Lumia 520T (RM-913)
  • Lumia 520 (RM-914)
  • Lumia 520 (RM-915)
  • Lumia 521 (RM-917)
  • Lumia 620 (RM-846)
  • Lumia 720 (RM-885)
  • Lumia 720T (RM-887)
Lumia supported models for Unlock via USB/Test Points:
  • Lumia 710 (RM-803, RM-809) via USB/Test Points
  • Lumia 800 (RM-801, RM-819) via Test Points
  • Lumia 800C (RM-802) via Test Points
Old 05-08-2013, 11:30   #29 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
How to know what version inside a dead phone ???
From ATF V9.83 it is available to know the firmware version even in a dead / semi dead phone
See this - Some Phones Tested with ATF 9.83 (Showing Firmware Version)
Now there is ZERO possibility of accidentally downgrade for Nokia BB5 SL3 phone
Use ATF & feel the power
Br - srinibas
The Following 8 Users Say Thank You to srinibas For This Useful Post:
Old 05-21-2013, 14:45   #30 (permalink)
Member: 643472
Sonork: 100.96901
How to repair Lumia WP8 dead boot:
Questions about Dejan's flasher interface SashaM Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 9 01-15-2001 08:31
8890 questions spongebob Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 01-10-2001 00:04
I have that soft if smb need ask for testing.. Nec Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-01-2000 22:47
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-26-1999 14:31
Question about 51xx/61xx Comic Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-06-1999 23:47
vBulletin Optimisation provided by vB Optimise (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting. ()
Page generated in 2.27206 seconds with 8 queries
