03-06-2010, 16:05 | #1 (permalink) | |||
No Life Poster Join Date: Oct 2006 Location: Chennai - India Age: 37
Member: 372320 Status: Offline Sonork: 100.113211 Thanks Meter: 2,661 | Few tries later Sucessfully Flashed 5220 01:43 Try 1 Quote:
try3 Quote:
Try 4 Sucessfully Flashed after Flash fbus Check ... it say security test failed .. but phone working good Br Ram | |||
03-06-2010, 16:11 | #2 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | @Chennairam When the flashing stops during errors... Does it hang for a while then give error message or does it stop and show error message immediately ? B.R. X-Shadow |
03-07-2010, 03:57 | #4 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | The time taken in 4th try is so less b'coz the phone was already erased in 1st try. ATF pattern of flashing is just like usb flashing. Erase required flash area first and then flash it. So if phone is erased in 1st try and one gets error in flashing, then in next try if flashing is successful, naturally the flash time taken is lesser. Actual flash time for 5220 & 7210c is around 5-8 mins and that too depends. |
03-07-2010, 04:02 | #5 (permalink) | |
Member: 372320 Status: Offline Sonork: 100.113211 Thanks Meter: 2,661 | Quote:
Still i am very confused br Ram | |
03-07-2010, 04:13 | #6 (permalink) |
Product Supporter Join Date: Sep 2004 Location: PHILIPPINES Age: 46
Member: 81952 Status: Offline Sonork: 1597268 Thanks Meter: 2,364 | hi! can you attach the full log file so we can check whats the problem why it stop during flashing.. Some reason why flashing stop caused by driver. Simlock test problem will be fixed in next and pro version. br ulymar |
03-07-2010, 04:19 | #7 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 55
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | du u feel any speed difference while using ext power from ATF to cable ? I tested on 3110c N70 3500 etc... satisfied with its performance in flashing.... Total Flashing Time (Booting + Erase + Flashing) : 00:04:17 |
03-07-2010, 04:25 | #8 (permalink) |
Member: 871 Status: Offline Thanks Meter: 602 | Some phones like 7210c takes longer time to flash when VPP is connected and External VPP is selected. Maybe this is the same case with 5220. zeel_zeel is correct. Only erasing time takes too long on the 5220. The flashing time will change only if you select 7.5Mhz or 15Mhz. However the erasing time for 3Mhz is still the same time in 15Mhz. We are really tempted to put side by side videos comparing flashing times of ATF vs another 3rd party box but I think it is really unfair for the other boxes as they only have 12 mbps USB connection (ATF has 480 mbps USB connection). For slow phones like 7210 and 5220, maybe you will see a small difference like ATF will be 1-3 minutes faster... But for all other non SLOW phones,,, the other boxes really don't have a fighting chance... It is brutally unfair to compare. Last edited by X-Shadow; 03-07-2010 at 04:30. |
The Following User Says Thank You to X-Shadow For This Useful Post: |
03-07-2010, 04:54 | #9 (permalink) | |
No Life Poster Join Date: Jun 2008 Location: Wish i was on Mars Age: 40
Member: 789089 Status: Offline Sonork: 100.1617*** Thanks Meter: 267 | Quote:
LOG: Code: 19:15:02 : ****************************************************** 19:15:02 : TIME START HERE 19:15:02 : ****************************************************** 19:15:02 : 19:15:02 : BootFlashModeDCT5Ex Succeeded First Time 19:15:02 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 19:15:02 : Number of Sub Blocks 7 (0x07) 19:15:02 : 1 SYSTEM_ASIC_ID 01 19:15:02 : Block Length : 21 (15) 19:15:02 : BB ASIC Index : 0 (00) CMT 19:15:02 : ID DWORD 0 : 00000001 19:15:03 : ID DWORD 1 : 00000226 19:15:03 : ID DWORD 2 : 00010006 19:15:03 : ID DWORD 3 : 030C1921 19:15:03 : ID DWORD 4 : 01033000 19:15:03 : 2 ROM_ID 15 19:15:03 : Block Length : 5 (05) 19:15:03 : BB ASIC Index : 0 (00) CMT 19:15:03 : ID DWORD 0 : 00000295 19:15:03 : 3 ROM_ID 15 19:15:03 : Block Length : 5 (05) 19:15:03 : BB ASIC Index : 0 (00) CMT 19:15:03 : ID DWORD 0 : 00000B22 19:15:03 : 4 PUBLIC_ID 12 19:15:03 : Block Length : 21 (15) 19:15:03 : BB ASIC Index : 0 (00) CMT 19:15:03 : ID DWORD 0 : 1E300217 19:15:03 : ID DWORD 1 : B11B0354 19:15:03 : ID DWORD 2 : 6743E139 19:15:03 : ID DWORD 3 : 483B7653 19:15:03 : ID DWORD 4 : A8C89017 19:15:03 : 5 ASIC_MODE_ID 13 19:15:03 : Block Length : 2 (02) 19:15:03 : BB ASIC Index : 0 (00) CMT 19:15:03 : Mode Id : 00 19:15:03 : 6 ROOT_KEY_HASH 14 19:15:03 : Block Length : 17 (11) 19:15:03 : BB ASIC Index : 0 (00) CMT 19:15:03 : Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 19:15:03 : 7 ROM_ID 15 19:15:03 : Block Length : 9 (09) 19:15:03 : BB ASIC Index : 0 (00) CMT 19:15:03 : CRC 0 : 273F6D55 19:15:03 : CRC 1 : DFAAF68F 19:15:03 : Checksum F5 19:15:03 : BootCodeLen : 61 19:15:03 : SearchForBootstrap_DCT5.. 19:15:03 : CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg 19:15:03 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 19:15:04 : MCU_CONFIGURATION_RESPONSE_BB5: 19:15:04 : MessageID : C1 19:15:04 : SubBlocks : 03 19:15:04 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 19:15:04 : Block Length : 0B 19:15:04 : BB ASIC Index : CMT 00 19:15:04 : Device Type : NOR 00 19:15:04 : Device Index : 00 19:15:04 : Manufacturer Code : 0089 -> 19:15:04 : Device ID : 8982 -> Type not in database 19:15:04 : Extended/Fixed ID : 0000 19:15:04 : Revision ID : 8A31 19:15:04 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 19:15:04 : Block Length : 13 19:15:04 : BB ASIC Index : CMT 00 19:15:04 : Device Type : NOR 00 19:15:04 : Device Index : 00 19:15:04 : Device Contents : 00000000000000000000 19:15:04 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 19:15:04 : Block Length : 0B 19:15:04 : BB ASIC Index : CMT 00 19:15:04 : Device Type : MMC 04 19:15:04 : Device Index : 00 19:15:04 : Manufacturer Code : FFFF -> Flash 19:15:04 : Device ID : 0000 -> BAD FLASH TYPE 19:15:04 : Extended/Fixed ID : 0000 19:15:04 : Revision ID : 0000 19:15:04 : Checksum : 51 19:15:04 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 19:15:04 : FLS1SendAlgoCodeEx.. 19:15:04 : SendAlgoCode_DCT5.. 19:15:04 : SearchForAlgorithm_DCT5.. 19:15:04 : Looking for ALL Devices... 19:15:04 : Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 19:15:04 : Flash Descriptor 19:15:04 : Manufacturer Code : 0089 19:15:04 : Device ID : 8982 19:15:04 : Extended/Fixed ID : 0000 19:15:04 : Revision ID : 0000 19:15:04 : Size : 00400000 (4194304) 19:15:04 : VPP Info : 0009 19:15:04 : Erase10s : 28 19:15:04 : Block1s : 64 19:15:04 : BErase1s : 02 19:15:04 : Reserved0 : 00 19:15:04 : Reserved1 : 00 19:15:04 : Reserved2 : 00 19:15:04 : VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK 19:15:04 : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg 19:15:04 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 19:15:04 : TransmissionTypeRequest_DCT5... 19:15:04 : SuggestedType : 01 16BIT 19:15:04 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 19:15:04 : ReturnedType : 01 16BIT 19:15:04 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 19:15:04 : 19:15:04 : Uploading ALGO File... 19:15:04 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 19:15:04 : No partition info.... 19:15:04 : VPP Enabled by Software 19:15:04 : Using Internal VPP 19:15:04 : StartErase_DCT5... 19:15:04 : BlockLength : 0x000E (14) 19:15:04 : ERASE Blocks : 0x0001 (1) 19:15:04 : 0 ERASE_AREA_BB5 0x12 19:15:04 : Block Length : 0x0B (11) 19:15:05 : BB ASIC Index : 0x00 CMT 19:15:05 : Device Type : 0x00 NOR 19:15:05 : Device Index : 0x00 19:15:05 : 0 : 01520000-01DBFFFF 19:15:05 : ERASE_REQUEST_BB5 : 5001120B0000000152000001DBFFFFB4 19:15:05 : Please wait ERASING......... 19:15:36 : Status_BB5 STATUS_REQUEST_BB5.. 19:15:36 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 19:15:36 : Block Length : 01 19:15:36 : BB ASIC Index : 00 19:15:36 : Successfully erased.. 19:15:36 : Time Taken to Erase : 00:00:31 19:15:36 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 19:15:36 : ReturnedType : 04 DDRand2TX 19:15:36 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 19:15:36 : 19:15:37 : Is Flashing CLOCK AUTO : -1 19:15:37 : Processing : rm411__07.23.ppm_a 19:15:37 : Total blocks to write : 435 19:15:54 : ContinueFlash_DCT5 Complete 19:15:54 : Status_BB5 STATUS_REQUEST_BB5.. 19:15:54 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 19:15:54 : Block Length : 01 19:15:54 : BB ASIC Index : 00 19:15:54 : FlashInfo.RestartMode : 2 19:15:54 : Continue Flash Complete : : No Error - 0 (0x00) 19:15:54 : Time Taken to Flash : 00:00:17 19:15:54 : Making delay between files for 1000ms 19:15:55 : AdvanceBox Turbo Flasher Found 19:15:55 : Driver Version : 00020422 19:15:55 : Library Version : 00030119 19:15:55 : Initialize Device.... 19:15:56 : Init TRY : 1 19:15:56 : Changing Clock to 15mhz.. 19:15:56 : Box Name : AdvanceBox Turbo 19:15:56 : Box Firmware : LogiCore 1.16.10 19:15:56 : Software Version : v2010.0.1.21 19:15:56 : AdvanceBox SN : E20B7CC5BA1A6FE0F0D092A5 19:15:56 : BOX Status : ACTIVATED 19:15:56 : DDR DELAY : 01 19:15:56 : INIT : OK 19:15:56 : 19:15:56 : Processing Image File : C:\Documents and Settings\clifford\Desktop\New Folder\rm411__07.23.image_a_a_green 19:15:56 : CMT Type : BB5 19:15:56 : CMT Algorithm : BB5 ALGORITHM 19:15:56 : CMT Supported Hardwares : 19:15:56 : > 010C192101013000 19:15:56 : > 0103192101003000 19:15:56 : > 030C192101033000 19:15:56 : Secondary Sending Speed : 3250000Hz 19:15:56 : Algorithm Sending Speed : 6500000Hz 19:15:57 : Program Sending Speed : 6500000Hz 19:15:57 : Message Reading Speed : 98000Hz 19:15:57 : Number of Blocks : 688 19:15:57 : Entry Point: 0x00C2 19:15:57 : Page Format : -1 19:15:57 : MAX PAGE : 0x00004000 19:15:57 : AdvanceFBox SendBootCodeEx 19:15:57 : InitialiseBootstrap_DCT5 DIR 19:15:57 : BootFlashMode_DCT5 19:15:57 : AdvanceFBox SendBootCodeEx 19:15:57 : InitialiseBootstrap_DCT5 DIR 19:15:57 : BootFlashMode_DCT5 19:15:57 : AdvanceBox Turbo Flasher Found 19:15:57 : Driver Version : 00020422 19:15:57 : Library Version : 00030119 19:15:57 : Initialize Device.... 19:15:57 : Init TRY : 1 19:15:57 : Changing Clock to 15mhz.. 19:15:58 : Box Name : AdvanceBox Turbo 19:15:58 : Box Firmware : LogiCore 1.16.10 19:15:58 : Software Version : v2010.0.1.21 19:15:58 : AdvanceBox SN : E20B7CC5BA1A6FE0F0D092A5 19:15:58 : BOX Status : ACTIVATED 19:15:58 : DDR DELAY : 01 19:15:58 : INIT : OK 19:15:58 : 19:15:58 : VBATT OFF ... 19:16:01 : VBATT ON 19:16:01 : Setting VBATT Done!... 19:16:02 : AdvanceFBox SendBootCodeEx 19:16:02 : InitialiseBootstrap_DCT5 DIR 19:16:02 : BootFlashMode_DCT5 19:16:02 : 19:16:02 : ****************************************************** 19:16:02 : TIME START HERE 19:16:02 : ****************************************************** 19:16:02 : 19:16:02 : BootFlashModeDCT5Ex Succeeded First Time 19:16:02 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned 19:16:02 : Number of Sub Blocks 7 (0x07) 19:16:02 : 1 SYSTEM_ASIC_ID 01 19:16:02 : Block Length : 21 (15) 19:16:02 : BB ASIC Index : 0 (00) CMT 19:16:02 : ID DWORD 0 : 00000001 19:16:02 : ID DWORD 1 : 00000226 19:16:02 : ID DWORD 2 : 00010006 19:16:02 : ID DWORD 3 : 030C1921 19:16:02 : ID DWORD 4 : 01033000 19:16:02 : 2 ROM_ID 15 19:16:02 : Block Length : 5 (05) 19:16:02 : BB ASIC Index : 0 (00) CMT 19:16:02 : ID DWORD 0 : 00000295 19:16:02 : 3 ROM_ID 15 19:16:02 : Block Length : 5 (05) 19:16:02 : BB ASIC Index : 0 (00) CMT 19:16:02 : ID DWORD 0 : 00000B22 19:16:02 : 4 PUBLIC_ID 12 19:16:02 : Block Length : 21 (15) 19:16:02 : BB ASIC Index : 0 (00) CMT 19:16:02 : ID DWORD 0 : 1E300217 19:16:02 : ID DWORD 1 : B11B0354 19:16:02 : ID DWORD 2 : 6743E139 19:16:02 : ID DWORD 3 : 483B7653 19:16:02 : ID DWORD 4 : A8C89017 19:16:02 : 5 ASIC_MODE_ID 13 19:16:02 : Block Length : 2 (02) 19:16:02 : BB ASIC Index : 0 (00) CMT 19:16:02 : Mode Id : 00 19:16:02 : 6 ROOT_KEY_HASH 14 19:16:02 : Block Length : 17 (11) 19:16:02 : BB ASIC Index : 0 (00) CMT 19:16:02 : Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 19:16:02 : 7 ROM_ID 15 19:16:02 : Block Length : 9 (09) 19:16:02 : BB ASIC Index : 0 (00) CMT 19:16:02 : CRC 0 : 273F6D55 19:16:02 : CRC 1 : DFAAF68F 19:16:02 : Checksum F5 19:16:02 : BootCodeLen : 61 19:16:03 : SearchForBootstrap_DCT5.. 19:16:03 : CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg 19:16:03 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 19:16:03 : MCU_CONFIGURATION_RESPONSE_BB5: 19:16:03 : MessageID : C1 19:16:03 : SubBlocks : 03 19:16:03 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 19:16:03 : Block Length : 0B 19:16:03 : BB ASIC Index : CMT 00 19:16:03 : Device Type : NOR 00 19:16:03 : Device Index : 00 19:16:03 : Manufacturer Code : 0089 -> 19:16:03 : Device ID : 8982 -> Type not in database 19:16:03 : Extended/Fixed ID : 0000 19:16:03 : Revision ID : 8A31 19:16:03 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 19:16:03 : Block Length : 13 19:16:03 : BB ASIC Index : CMT 00 19:16:03 : Device Type : NOR 00 19:16:03 : Device Index : 00 19:16:03 : Device Contents : 00000000000000000000 19:16:03 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 19:16:04 : Block Length : 0B 19:16:04 : BB ASIC Index : CMT 00 19:16:04 : Device Type : MMC 04 19:16:04 : Device Index : 00 19:16:04 : Manufacturer Code : FFFF -> Flash 19:16:04 : Device ID : 0000 -> BAD FLASH TYPE 19:16:04 : Extended/Fixed ID : 0000 19:16:04 : Revision ID : 0000 19:16:04 : Checksum : 51 19:16:04 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 19:16:04 : FLS1SendAlgoCodeEx.. 19:16:04 : SendAlgoCode_DCT5.. 19:16:04 : SearchForAlgorithm_DCT5.. 19:16:04 : Looking for ALL Devices... 19:16:04 : Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31 19:16:04 : Flash Descriptor 19:16:04 : Manufacturer Code : 0089 19:16:04 : Device ID : 8982 19:16:04 : Extended/Fixed ID : 0000 19:16:04 : Revision ID : 0000 19:16:04 : Size : 00400000 (4194304) 19:16:04 : VPP Info : 0009 19:16:04 : Erase10s : 28 19:16:04 : Block1s : 64 19:16:04 : BErase1s : 02 19:16:04 : Reserved0 : 00 19:16:04 : Reserved1 : 00 19:16:04 : Reserved2 : 00 19:16:04 : VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK 19:16:04 : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg 19:16:04 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 19:16:04 : TransmissionTypeRequest_DCT5... 19:16:04 : SuggestedType : 01 16BIT 19:16:04 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 19:16:04 : ReturnedType : 01 16BIT 19:16:04 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 19:16:04 : 19:16:04 : Uploading ALGO File... 19:16:04 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 19:16:05 : No partition info.... 19:16:05 : VPP Enabled by Software 19:16:05 : Using Internal VPP 19:16:05 : StartErase_DCT5... 19:16:05 : BlockLength : 0x0016 (22) 19:16:05 : ERASE Blocks : 0x0001 (1) 19:16:05 : 0 ERASE_AREA_BB5 0x12 19:16:05 : Block Length : 0x13 (19) 19:16:05 : BB ASIC Index : 0x00 CMT 19:16:05 : Device Type : 0x00 NOR 19:16:05 : Device Index : 0x00 19:16:05 : 0 : 01DC0000-0215FFFF 19:16:05 : 1 : 02160000-03FBFFFF 19:16:05 : ERASE_REQUEST_BB5 : 5001121300000001DC00000215FFFF0216000003FBFFFFD3 19:16:05 : Please wait ERASING......... 19:19:50 : Status_BB5 STATUS_REQUEST_BB5.. 19:19:50 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 19:19:50 : Block Length : 01 19:19:50 : BB ASIC Index : 00 19:19:50 : Successfully erased.. 19:19:50 : Time Taken to Erase : 00:03:45 19:19:50 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 19:19:51 : ReturnedType : 04 DDRand2TX 19:19:51 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 19:19:51 : 19:19:51 : Is Flashing CLOCK AUTO : -1 19:19:51 : Processing : rm411__07.23.image_a_a_green 19:19:51 : Total blocks to write : 688 19:20:17 : ContinueFlash_DCT5 Complete 19:20:17 : Status_BB5 STATUS_REQUEST_BB5.. 19:20:17 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 19:20:17 : Block Length : 01 19:20:17 : BB ASIC Index : 00 19:20:17 : FlashInfo.RestartMode : 2 19:20:17 : Continue Flash Complete : : No Error - 0 (0x00) 19:20:17 : Time Taken to Flash : 00:00:26 19:20:17 : Making delay between files for 1000ms 19:20:18 : 19:20:18 : Total Flashing Time (Booting + Erase + Flashing) : 00:06:16 19:20:18 : | |
04-16-2010, 18:12 | #10 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | strange i also need about 8min more to flash 5220 but when flashing 6303 only need 1min more, 3110c need about 4min more. Or maybe for 5220 alike need VPP from extension port? br, s1emens |
FEW Nokia dct4 latast flash file | ::..s@uddin..:: | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 08-19-2009 21:28 |
i have prb when i tried to unlock nokia 5220 | FADILALI | Universalbox | 2 | 05-21-2009 16:00 |
Please Help, just need few flashing/unlocking answers - P520 | lomna | Samsung Flashers, Software, Firmware. | 3 | 02-03-2009 23:42 |
6280 after few trys now is dead | ayubalikhan | BB5BOX | 13 | 12-20-2007 22:44 |
- ! HeLp ! - 3330 Not Working Few Days Later After Flash - ! HeLp ! - | DSB2069 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-01-2001 19:03 |
