12-26-2015, 20:52 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Indonesia-D.K.I Jaya
Member: 1104396 Status: Offline Sonork: 290480 Thanks Meter: 19 | the firmware update + format step is right?? I have bought atf jtag 2 days ago, i try to update firmware and format. Here is the log : eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004E355530304D00342064924F91 CSD : D02701320F5903FFF6DBFFE78A404057 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 2560 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 3896508416 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 2048 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : N5U00M Product Rev : 0.0 Product SN : 34206492 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004E355530304D00342064924F91.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Samsung eMMC Firmware Update ================================================== ==== --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB --> This will RESET EXT_CSD Programming Such as BOOT Options, Bus Characteristics and Partition Sizes.. ================================================== ==== Please Manually Select the Correct Part Number of your eMMC Device. ================================================== ==== If you select a WRONG PART NUMBER, then YOU WILL PROBABLY KILL THE EMMC !!! ================================================== ==== ================================================== ==== Loading ATF eMMC Firmware File... (Please Wait) ================================================== ==== File Author: ATF Team @ X-Shadow Date Created: 21/02/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KMNJS000ZM-B205 eMMC Product Name: NJS00M eMMC Product Rev: 0.0 Preparing eMMC for Firmware Update... Sending eMMC Firmware Blocks... All Blocks Sent! NAND Write Delay: 1 Second (Please Wait) Applying eMMC Firmware Update... Waiting for Device Re-Initialization... Firmware Write Protect Delay: 1 Second (Please Wait) Checking eMMC Firmware Update Status... Applying Final Patches... eMMC Firmware Update Successful! ================================================== ==== Your eMMC is now a Brand New BLANK Device!!! ================================================== ==== Resize BOOT and RPM Partitions if needed... ReWrite BOOT1, BOOT2 and USER Partitions if needed... ReWrite EXT_CSD File if needed... Make sure eMMC BOOT Options are Correct for your Phone ================================================== ==== Total Elapsed Time 00:01:02 What sholud I do next??? It’s done or the other next step ??? |
12-27-2015, 03:51 | #2 (permalink) |
Freak Poster Join Date: Apr 2007 Location: malang indonesia
Member: 480385 Status: Offline Thanks Meter: 16 | on aplying final patch select no. than write axt csd backup no need write b1 b2 for mtk cpu .just flash with corrrect firmware . |
The Following User Says Thank You to ribut budiono For This Useful Post: |
