Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 02-24-2011, 12:57   #1 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Thanks Meter: 29,572
First In the World ATF C2-01 RM-721 Fbus Flashing!! 16 SEC!!
ATF Software Version v6.65
ATF Box FBUS Flash Started...
Number of Image Files: 3
Processing Image File : C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-721\rm721__10.50.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed    : 3250000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 19500000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  158
Entry Point:  0x0259
Page Format : -1
MAX PAGE : 0x00040000
Changing MODE : FLASH
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
                  TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00000001
     ID DWORD    3 : 020C1921
     ID DWORD    4 : 02044100
  2  ROM_ID 15
     Block Length  : 5  (05)
     ID DWORD    0 : 00001051
  3  ROM_ID 15
     ID DWORD    0 : 00001060
  4  PUBLIC_ID 12
     ID DWORD    0 : 13200016
     ID DWORD    1 : C1F85540
     ID DWORD    2 : D6E04362
     ID DWORD    3 : DAC6D5F9
     ID DWORD    4 : 5A5E4404
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 67E82268
     CRC         1 : F29CEA60
Checksum           91
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg
Boot File - Version  010.050.00
Boot File - Revision 0x0003 (3)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> not detected
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Revision ID       : 0000
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> not used
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0030 -> K5W1G13ACB
   Revision ID       : 0431
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              : XSR 1.6
 Checksum   : 25
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0030 ExtID :0000 RevID :0431
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   Size              : 08000000 (128 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_XSR17_alg.fg
Algorithm File - Version  010.050.00
Algorithm File - Revision 0x0003 (3)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
   PAPUB_KEYS_HASH_RESP_BB5 2A
   BB Asic Index   : 00
CMT PAPUBKEYS HASH:
8443ECD57D2EDADDAADBAD248F1B3B559E14D184
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            BB ASIC Index     : 0x00 CMT
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00010000
            Spare             : FFFFFFFF
            Num Partitions    : 00000004
            Partition    1
              Attribute       : 00000002  RO
              Start Address   : 000A0000
            Partition    2
              ID              : 00000008  FILESYSTEM
              Attribute       : 00000001  RW
              Start Address   : 02CC0000
            Partition    3
              Start Address   : 077C0000
            Partition    4
              Start Address   : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0xE1  (225)
ERASE Blocks :  0x04  (4)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x4B (75)
            Device Index     : 0x00
               0             : 00020000-000203FF
               1             : 00060000-0009FFFF
               2             : 000A0000-0025FFFF
               3             : 003E0000-005DFFFF
               4             : 005E0000-010DFFFF
               5             : 01EC0000-01EDFFFF
               6             : 027C0000-02CBFFFF
               7             : 077C0000-07B3FFFF
               8             : 010E0000-01EBFFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x02000000
            Format Info      : 00000000000000080000000000000002000000640000000200000002000000010000000000000000
     2   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 000000000000000A0000000100000002000000640000000200000002000000010000000000000000
     3   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 000000000000000B0000000000000002000000640000000200000002000000010000000000000000
Erase_SendEraseBlock_BB5_NAND
Task in Progress... Please Wait...
Erase_SendFormatPartition_BB5_NAND
Successfully erased..
Time Taken to Erase : 00:00:00
Flashing Speed: 15.00 Mhz
Processing  : rm721__10.50.mcusw
Total blocks to write : 158
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : UPDAPP
>>  CMT Rootkey Hash CERT : DSP0
>>  CMT Rootkey Hash CERT : MCUSW
>>  CMT Rootkey Hash CERT : MCUSW1
>>  CMT Rootkey Hash CERT : GENIO_INIT
>>  CMT Rootkey Hash CERT : ISA+DYNSW
ContinueFlash_DCT5 Complete
Continue Flash Complete :  : No Error - 0 (0x00)
Time Taken to Flash  : 00:00:08
Processing Image File : C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-721\rm721__10.50.ppm_c
CMT Type : BB5
Number of Blocks :  27
Entry Point:  0x011D
Page Format : -1
Partition Info
            Device Index      : 0x00
            Spare             : FFFFFFFF
            Partition    1
            Partition    2
            Partition    3
            Partition    4
StartErase_DCT5...
BlockLength  :  0x0E  (14)
ERASE Blocks :  0x01  (1)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 01EE0000-027BFFFF
Processing  : rm721__10.50.ppm_c
Total blocks to write : 27
Time Taken to Flash  : 00:00:02
Processing Image File : C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-721\rm721__10.50.image_c_059G3Q9_001
CMT Type : BB5
Number of Blocks :  61
Entry Point:  0x0154
Page Format : -1
Partition Info
            Device Index      : 0x00
            Spare             : FFFFFFFF
            Partition    1
            Partition    2
            Partition    3
            Partition    4
StartErase_DCT5...
BlockLength  :  0x3F  (63)
ERASE Blocks :  0x02  (2)
            Device Index     : 0x00
               0             : 02CC0000-077BFFFF
            Device Index     : 0x00
Processing  : rm721__10.50.image_c_059G3Q9_001
Total blocks to write : 61
Time Taken to Flash  : 00:00:04
Total Flash Write Time (Flashing Only) : 00:00:14
Total Flashing Time (Booting + Erase + Flashing) : 00:00:16
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  05
          Device Type       :  0F
          Num Bad Blocks    :  00000000
          Additional Bad    :  00000000
          Correctable ECC   :  00000000
FlashInfo.RestartMode : 2
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
MCU: V 10.50 07-01-11 RM-721 (c) Nokia
IMEI: 355940043280435
Model : Nokia C2-01
Product Serial Number: DNR093445
Product Code         : 059G1L7
Module Code          : 0204769
Basic Production Code: 059C872
Default SN Type      : 0
MCU SW Version       : V 10.50 07-01-11 RM-721 (c) Nokia             C
BT MCM Version       : 1673-46038
PPM Version          : V 10.50 07-01-11 RM-721 (c) Nokia
HW Version           : 1000
RFIC Version         : |Vapaus_6.5 | Mikki_1.1
DSP Version          : SPR91_09w09_10w50
LCD Version          : SEIKO
Content Pack Version : Content: c_059G3Q9 V 10.50 07-01-11 RM-721 (c) Nokia
AHNE Version         : 41
Retu Version         : 51
Tahvo Version        : 00
   ********   Reading SimLock   ********
CONFIG KEY:  0000000000000000
PROVIDER KEY:  2440700000000000
Provider  :  AT&T;U.S.A. (3650)
Counters  :  0/3  ,  0/10
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status :  Not Locked
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SECURITY_CODE          : 12345
PHONE_MODE              : TEST MODE
          Dynamic Camera Configuration
DCC ID  : NI00IIIIRR0301035602
DCC Ver: 001002
Status   : OK
Thanks for smart-gsm provide C2-01 cable.
The Following 20 Users Say Thank You to gsmfun For This Useful Post:
Old 02-24-2011, 12:58   #2 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 1,651
Great news
now i m feeling too more power
Old 02-24-2011, 13:06   #3 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 473
Feel the power!!!!!!!!!!!!!!
Atf rules gsm world
Old 02-24-2011, 13:08   #4 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 8,586
Great News Dear ATF Team............................
Old 02-24-2011, 13:08   #5 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Atf rules gsm world
Thanks
Now is faster than USB.
C2-01 usb need: 1 min 2 sec!! Fbus only need 16 sec!!
USB Total Flashing Time (Erase + Flashing) : 00:01:02
Thomas
The Following 3 Users Say Thank You to gsmfun For This Useful Post:
Old 02-24-2011, 13:25   #6 (permalink)
bk.gsm's Avatar
Member: 869809
Sonork: 100.1585798
Thanks Meter: 550
great news from speedy gonzalez box
really good work ATF team
best regards
Old 02-24-2011, 14:23   #7 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 7,881
Really good work ATF team Feel the power!!!!!!!!!!!!!!
The Following User Says Thank You to kabul For This Useful Post:
Old 02-24-2011, 14:28   #8 (permalink)
gsm junction's Avatar
Member: 1229072
Sonork: 100.1624007
Thanks Meter: 1,641
Thankssssssssssssssssssss
Old 02-24-2011, 16:23   #9 (permalink)
nolimitkenya2's Avatar
Member: 1341599
Thanks Meter: 114
Good info guys i like da way you are changing da gsm world,go go go go............
The Following User Says Thank You to nolimitkenya2 For This Useful Post:
Old 02-24-2011, 16:51   #10 (permalink)
Member: 1461041
Thanks Meter: 39
First in the world from ATF Team...............
Old 02-25-2011, 14:35   #11 (permalink)
sadek2011's Avatar
Member: 1481925
Sonork: N/A
Thanks Meter: 302
Good Job ATF Team..........
Old 02-25-2011, 14:39   #12 (permalink)
Member: 580338
Thanks Meter: 4
Good update thanks.....
Old 02-25-2011, 18:46   #13 (permalink)
boss-m's Avatar
Member: 1177430
Thanks Meter: 19
Thanks to him, wonderful updates
Thanks to him, team atf
Old 02-26-2011, 00:57   #14 (permalink)
GsmUniversal's Avatar
Member: 649528
Sonork: 100.1590443
Thanks Meter: 6,953
it is also 1st in world that fbus supports more faster than usb..
Old 02-26-2011, 01:26   #15 (permalink)
Member: 1371622
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 09:41
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 18:04
fbus-mbus ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-05-1999 14:46
Page generated in 0.48520 seconds with 8 queries
