Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 02-16-2011, 11:08   #1 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Thanks Meter: 29,578
First In the World ATF C2-01 RM-721 USB Flashing!!
Number of Image Files: 3
Processing Image File :
 rm721__10.50.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed    : 3250000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 19500000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  158
Entry Point:  0x0259
Page Format : -1
MAX PAGE : 0x00040000
 rm721__10.50.ppm_c
CMT Type : BB5
Number of Blocks :  27
Entry Point:  0x011D
Page Format : -1
 rm721__10.50.image_c_059G3Q9_001
CMT Type : BB5
Number of Blocks :  61
Entry Point:  0x0154
Page Format : -1
[]: Found 1 active devices.
[Nokia USB Phonet]: Opening Connection
[Nokia USB Phonet]: Port opened OK!
SW: V 10.50 07-01-11 RM-721 (c) Nokia
IMEI: 355940043280435
CONFIG KEY:  0000000000000000
PROVIDER KEY:  2440700000000000
Provider  :  AT&T;U.S.A. (3650)
Counters  :  0/3  ,  0/10
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status :  Not Locked
 START FULL PM BACKUP
Please Wait...
Reading : PM 0~400... OK!
 FULL PM Backup Saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355940043280435\USB_FULL_BACKUP_V 10.50 07-01-11 RM-721 (c) Nokia_355940043280435_Not Locked_44941.pm
Reading battery value  : 4068 mV
Rebooting Phone...
AUTO SELECTED DEAD USB FLASHING...
 If Flashing DOES NOT Start in 5 Seconds,
 Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly..
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
 BootRom Verified!
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00000001
     ID DWORD    3 : 020C1921
     ID DWORD    4 : 02044100
  2  ROM_ID 15
     Block Length  : 5  (05)
     ID DWORD    0 : 00001051
  3  ROM_ID 15
     ID DWORD    0 : 00001060
  4  PUBLIC_ID 12
     ID DWORD    0 : 13200016
     ID DWORD    1 : C1F85540
     ID DWORD    2 : D6E04362
     ID DWORD    3 : DAC6D5F9
     ID DWORD    4 : 5A5E4404
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 67E82268
     CRC         1 : F29CEA60
START FLASHING
RawLoaderExtract: Processing rm721__10.50.mcusw
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_2nd.fg
Secondary Loader Sent...
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> not detected
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Revision ID       : 0000
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> not used
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0030 -> K5W1G13ACB
   Revision ID       : 0431
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              :
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   Size              : 08000000 (128 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
CMT Algorithm Loader:C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_XSR17_alg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
 START READING RPL DATA
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355940043280435\355940043280435_44951.rpl
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
  PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index   : 00
    PAPUB Keys Hash : 8443ECD57D2EDADDAADBAD248F1B3B559E14D184
ImagePath: C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\RM-721\
ImadeFilename: rm721__10.50.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            BB ASIC Index     : 0x00 CMT
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00010000
            Spare             : FFFFFFFF
            Num Partitions    : 00000004
            Partition    1
              Attribute       : 00000002  RO
              Start Address   : 000A0000
            Partition    2
              ID              : 00000008  FILESYSTEM
              Attribute       : 00000001  RW
              Start Address   : 02CC0000
            Partition    3
              Start Address   : 077C0000
            Partition    4
              Start Address   : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0xE1  (225)
ERASE Blocks :  0x04  (4)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x4B (75)
            Device Index     : 0x00
               0             : 00020000-000203FF
               1             : 00060000-0009FFFF
               2             : 000A0000-0025FFFF
               3             : 003E0000-005DFFFF
               4             : 005E0000-010DFFFF
               5             : 01EC0000-01EDFFFF
               6             : 027C0000-02CBFFFF
               7             : 077C0000-07B3FFFF
               8             : 010E0000-01EBFFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x02000000
            Format Info      : 00000000000000080000000000000002000000640000000200000002000000010000000000000000
     2   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 000000000000000A0000000100000002000000640000000200000002000000010000000000000000
     3   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 000000000000000B0000000000000002000000640000000200000002000000010000000000000000
ERASE_REQUEST_BB5 : 5009120B00030000020000000203FF120B000300000600000009FFFF120B000300000A00000025FFFF120B000300003E0000005DFFFF120B000300005E0000010DFFFF120B00030001EC000001EDFFFF120B000300027C000002CBFFFF120B000300077C000007B3FFFF120B000300010E000001EBFFFF3D
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000800000000000000020000006400000002000000020000000100000000000000003E
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A00000001000000020000006400000002000000020000000100000000000000003B
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B00000000000000020000006400000002000000020000000100000000000000003B
Successfully erased..
Total blocks to write : 158
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : UPDAPP
>>  CMT Rootkey Hash CERT : DSP0
>>  CMT Rootkey Hash CERT : MCUSW
>>  CMT Rootkey Hash CERT : MCUSW1
>>  CMT Rootkey Hash CERT : GENIO_INIT
>>  CMT Rootkey Hash CERT : ISA+DYNSW
ImadeFilename: rm721__10.50.ppm_c
StartErase_DCT5...
BlockLength  :  0x0E  (14)
ERASE Blocks :  0x01  (1)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 01EE0000-027BFFFF
ERASE_REQUEST_BB5 : 5001120B00030001EE0000027BFFFF74
Total blocks to write : 27
ImadeFilename: rm721__10.50.image_c_059G3Q9_001
StartErase_DCT5...
BlockLength  :  0x3F  (63)
ERASE Blocks :  0x02  (2)
            Device Index     : 0x00
               0             : 02CC0000-077BFFFF
            Device Index     : 0x00
ERASE_REQUEST_BB5 : 5001120B00030002CC0000077BFFFF90
Total blocks to write : 61
ContinueFlash_DCT5 Complete
Continue Flash Complete :  : No Error - 0 (0x00)
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00000002
          Additional Bad    :  00000002
          Correctable ECC   :  00000000
FlashInfo.RestartMode : 2
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:01:02
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 100 seconds)
If Windows is Installing Drivers...
Phone Polling MIGHT Exit Automatically.
Elapsed Time:  5 Seconds...
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SUPER_DONGLE_TEST  : PASSED
SECURITY_CODE          : 12345
               SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FACTORY SET TO : Factory Set Full
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Production Tune
 OK
FACTORY SET TO : Production Tuning
 OK
FACTORY SET TO : Reset User Code
 OK
FACTORY SET TO : Service Centre
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : User Data
 OK
RESET LIFE TIMER TO : 0000:00
 OK
The Following 26 Users Say Thank You to gsmfun For This Useful Post:
Old 02-16-2011, 11:22   #2 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 1,834
nice information
thanks ATF team
Old 02-16-2011, 11:32   #3 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 8,713
Relay Good Info Special Thanks To gsmfun
Old 02-16-2011, 12:10   #4 (permalink)
nolimitkenya2's Avatar
Member: 1341599
Thanks Meter: 114
thaxx for de info keep us tuned.......
Old 02-20-2011, 05:48   #5 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 406
Fentastic information/......
Old 02-20-2011, 05:53   #6 (permalink)
Ducdung76's Avatar
Member: 731321
Thanks Meter: 52
Thank Mr gsmfun for share.
Old 02-20-2011, 05:57   #7 (permalink)
abheejeet's Avatar
Member: 811063
Thanks Meter: 203
atf leader of flashing....................
Old 02-20-2011, 10:47   #8 (permalink)
Member: 1055935
Sonork: --------A
Thanks Meter: 5
keep it up nice job............
Old 12-12-2011, 15:40   #9 (permalink)
Member: 199814
Thanks Meter: 1,914
rm721__11.10.mcusw
CMT Type : BB5
Entry Point: 0x0259
Page Format : -1
rm721__11.10.ppm_meac
CMT Type : BB5
Number of Blocks : 24
Entry Point: 0x011D
Page Format : -1
rm721__11.10.image_meac_059G290_005
CMT Type : BB5
Number of Blocks : 66
Entry Point: 0x0154
Page Format : -1
2. Insert USB.
4. Please Power on phone shortly...
BootFlashMode_DCT5
BootRom Verified!
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
ID DWORD 0 : 17D0010D
ID DWORD 1 : 91E35840
ID DWORD 2 : B935CEA2
ID DWORD 3 : 7D0C416A
ID DWORD 4 : A8F6B8EA
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 67E82268
CRC 1 : F29CEA60
START FLASHING
RawLoaderExtract: rm721__11.10.mcusw
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_2 nd.fg
Secondary Loader Sent....
MessageID : C1
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0431
Block Length : 09
Data :
Flash Descriptor
Device ID : 0030
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAP3Gv40_X SR17_alg.fg
Booting/Flashing Failed...
Please Try Again...
im facing this error ? what could be reason
Old 12-12-2011, 15:45   #10 (permalink)
Member: 199814
Thanks Meter: 1,914
my problem solved after changing the file chose any other product code
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 04:41
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Lock 2 in nokia 51xx/61xx Pablo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-31-1999 04:35
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.39007 seconds with 8 queries
