05-06-2011, 05:23 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | FREE RAPIDO 479Cxx, C70Cxx, B8C3xx --- SLOTS CLOSED... PROCESSING 51 LOGS... 479C6DDE3942E12C429C1D6ADED80371 C70CB07324056BC66A824347F40DB2D5 B8C3ADECFC997FCD8081D3DEAF870B8C Follow Instructions to get it FREE. People who don't follow Instructions, will not be processed. Restrictions: 1. Only the 3 NEW RAPIDO HASHES are supported for this FREE SERVICE 2. Only 1 phone per USER can be submitted for every BATCH 3. You must POST SUCCESSFUL UNLOCK LOGS in ATF Section otherwise you will not be able to JOIN this PROMOTION AGAIN and will be BLACKLISTED from future ATF Promotions as well!!! Intructions: 1. Authorize your RAPIDO NEW HASH using The ATF Network 2. Decrypt SL3 PM 120 HASHES using the ATF Software 7.40 3. Post FULL Logs of "Decrypt SL3 PM 120 HASHES" process 4. Attach ZIP or RAR file all the BF logs created by the ATF Software. More Information: 1. The Logs will be calculated within 24 hours for the first batch and within 48 hours for the second batch. 2. First come first serve + SINGLE SERVE basis 3. After the first 10 logs will be done, then more FREE Slots will be given away... So keep watching ATF Section for FREE Slots available! B.R. X-Shadow Last edited by Advance-Box; 05-06-2011 at 16:41. |
The Following 79 Users Say Thank You to Advance-Box For This Useful Post: |
05-06-2011, 05:42 | #2 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Just for clarification: 1. Do not send me logs through Sonork as I will not accept them. 2. Do not post Screenshots,, only FULL LOGS are needed. 3. Do not post LOGS from different BOX (Of course). 4. This is 100% FREE, NO HIDDEN Charges and NO TRICKS. 5. Only 1 phone PER USER for every Batch! (So you can join in as many batches as you want) Plain and Simple... FREE. |
The Following 28 Users Say Thank You to Advance-Box For This Useful Post: |
05-06-2011, 05:53 | #4 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1160909 Status: Offline Thanks Meter: 6 | MCU: V ICPR72_09w20.18 12-05-10 RM-356 (c) Nokia IMEI: 352012042297837 Model : Nokia 5800 XpressMusic Product Serial Number: MDK999850 Product Code : 0588613 Module Code : 0204538 Basic Production Code: 0592754 Default SN Type : 0 PPM Version : V ICPR72_09w20.18 12-05-10 RM-356 (c) Nokia HW Version : 1104 RFIC Version : 17141716 DSP Version : tube_ICPR72_09w19_1_p1 AHNE Version : 11 APE SW Core Version : V 20.7.006 APE Variant Version : V 20.7.006V 20.7.006 V 20.7.006 APE Test Version : eno_version Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 8000000000000000 PROVIDER KEY: 4500000088401881 Provider : Unknown Provider Counters : 0/3 , 0/10 Block [1] 1:Close SP Lock Status : Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : TEST MODE AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1C800018 ID DWORD 1 : 97950052 ID DWORD 2 : 909D84C4 ID DWORD 3 : D9832C52 ID DWORD 4 : 9498F732 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 7C SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 010.050.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 Checksum : 25 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g Algorithm File - Version 010.050.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Scanning Simlock Applet Type... OK ================================================= PA_SL3 Applet detected ================================================= Dumping RSA Modulus... OK ================================================= RSA Modulus OK ================================================= FlashInfo.RestartMode : 2 ================================================== = Decrypt SL3 PM 120 HASHES for Brute Force Unlock ================================================== = Decrypting PM 120... (This may take upto 30 Seconds on New RAPIDO HASH) PM 120 HASHES Extracted Successfully E12BC3B3AB1D8833BDA4DEA8B876A6416225D73A F645FF0D2F46702332DE301FFD46B25CCB9ADCA9 5F5A095AB26615E8B912AB06D473C08E27606809 3E07EBC27411262776A3D91BE00FA9CD52A8978F 37EE1D6C50B6840568BBF394CD4CB4E7E61CA1E8 A217308C5E486969BD5D7D6824CF46892D7E9B54 7B16DAC2C809AEF60B7837BD8346CC8A58F3409F B6EDE885FA53BA591DFEB82DA9464091E73C8086 Log Files for Local Brute Force Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\352012042297837\352012042 297837.log C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\352012042297837\352012042 297837.bcl C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\352012042297837\352012042 297837.sha Command Line for ighashgpu: ighashgpu -t:sha1 -salt:003520120422978300 -h:E12BC3B3AB1D8833BDA4DEA8B876A6416225D73A -uh:00010203040506070809 -min:15 -max:15 Saved as MS Batch File: 352012042297837_ighashgpu.bat Process Done! |
The Following User Says Thank You to wmli For This Useful Post: |
05-06-2011, 05:56 | #5 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Dubai
Member: 1334781 Status: Offline Sonork: 0010 Thanks Meter: 80 | Hi i buy ATF box tomorrow not activate yet i can unlock it's hash's 479C6DDE3942E12C429C1D6ADED80371 C70CB07324056BC66A824347F40DB2D5 with my box without any credits it's FREE? or need credits for this hashs |
The Following User Says Thank You to ilya_5665 For This Useful Post: |
05-06-2011, 05:56 | #7 (permalink) | ||
No Life Poster Join Date: Apr 2001 Location: Sun Age: 44
Member: 4021 Status: Offline Thanks Meter: 782 | here' my authorization logs... Quote:
here's my decrypt log Quote:
thank you so much!! hope this post of mine is good!! whehehehe | ||
The Following 3 Users Say Thank You to ryumahon For This Useful Post: |
05-06-2011, 06:06 | #9 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Saigonmobile.vn Age: 42
Member: 223718 Status: Offline Thanks Meter: 40 | Here my log: Code: MCU: V ICPR72_09w36.5 25-09-09 RM-588 (c) Nokia IMEI: 356051030165669 Model : Nokia 5230 Product Serial Number: MIK155283 Product Code : 0592376 Basic Production Code: 0582715 Default SN Type : 0 PPM Version : V ICPR72_09w36.5 25-09-09 RM-588 (c) Nokia HW Version : 0501 RFIC Version : 17141715 DSP Version : simon_ICPR72_09w36_p2 Content Pack Version : v 001_000 27-08-09 vanilla RM588 AHNE Version : 11 APE SW Core Version : V 10.0.067 APE Variant Version : V 10.0.067V 10.0.067 10.0.067.207.03 APE Test Version : rm588_ENO_x_09wk24v0.120 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2080100000000000 Provider : Orange + France Telecom Itineris;France Counters : 0/3 , 0/10 Block [1] 1:Close Block [2] 1:Close SP Lock Status : Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : TEST MODE AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0BB0010B ID DWORD 1 : A7810052 ID DWORD 2 : E5E5160C ID DWORD 3 : 163AFA71 ID DWORD 4 : 85DE4956 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 68 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 010.050.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 Checksum : 24 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR17_alg.fg Algorithm File - Version 010.050.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Scanning Simlock Applet Type... OK ================================================= PA_SL3 Applet detected ================================================= Dumping RSA Modulus... OK ================================================= RSA Modulus OK ================================================= FlashInfo.RestartMode : 2 =================================================== Decrypt SL3 PM 120 HASHES for Brute Force Unlock =================================================== Decrypting PM 120... (This may take upto 30 Seconds on New RAPIDO HASH) PM 120 HASHES Extracted Successfully DE62E3C84D61C364EA519D08530D4FA80965B2B0 5998FE5DE79C7F4707E9763D7AF85D1922988C35 721D47F01C69AC6EA4BB6D3F7B9766563A481B17 A5FE707AEEFF9F8277D83241E11FC0083FBD07D3 F200A75229BCBA91B0B5CB98091989B51E0775DB 330DC32A12F3EF78C6F967496D61C609A03FB068 97760DD2BC953AD1F3896884921BD11AC3FE5094 4215ADAC2C29D5C91C29B51F685C0460B98CE78B Log Files for Local Brute Force Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\356051030165669\356051030165669.log C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\356051030165669\356051030165669.bcl C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\356051030165669\356051030165669.sha Command Line for ighashgpu: ighashgpu -t:sha1 -salt:003560510301656600 -h:DE62E3C84D61C364EA519D08530D4FA80965B2B0 -uh:00010203040506070809 -min:15 -max:15 Saved as MS Batch File: 356051030165669_ighashgpu.bat Process Done! |
05-06-2011, 06:08 | #10 (permalink) |
No Life Poster Join Date: Sep 2006 Location: 102 quy nhơn BĐ Age: 14
Member: 347720 Status: Offline Sonork: xxx Thanks Meter: 204 | 2. Only 1 phone per USER can be submitted Users with clone nicks can get slot also ? Last edited by freedomqn; 05-06-2011 at 06:13. |
05-06-2011, 06:12 | #11 (permalink) |
No Life Poster Join Date: Mar 2002 Location: AnyClient Age: 44
Member: 10485 Status: Offline Sonork: 100.66876 Thanks Meter: 396 | Code: MCU: V ICPR72_09w20.18 12-05-10 RM-356 (c) Nokia IMEI: 353382045103335 Model : Nokia 5800 XpressMusic Product Serial Number: MNH892337 Product Code : 0588613 Module Code : 0204538 Basic Production Code: 0592754 Default SN Type : 0 PPM Version : V ICPR72_09w20.18 12-05-10 RM-356 (c) Nokia HW Version : 1104 RFIC Version : 17141716 DSP Version : tube_ICPR72_09w19_1_p1 Content Pack Version : v 001_000 30-06-10 vanilla RM356 AHNE Version : 11 APE SW Core Version : V 20.7.006 APE Variant Version : V 20.7.006V 20.7.006 V 20.7.006 APE Test Version : eno_version Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 8000000000000000 PROVIDER KEY: 4500000088401881 Provider : Unknown Provider Counters : 0/3 , 0/10 Block [1] 1:Close SP Lock Status : Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED PHONE_MODE : TEST MODE AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 07B00108 ID DWORD 1 : 159F0052 ID DWORD 2 : 56B6C752 ID DWORD 3 : C34D6836 ID DWORD 4 : 531D0090 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum B9 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 010.050.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0121 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 Checksum : 25 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.fg Algorithm File - Version 010.050.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Scanning Simlock Applet Type... OK ================================================= PA_SL3 Applet detected ================================================= Dumping RSA Modulus... OK ================================================= RSA Modulus OK ================================================= FlashInfo.RestartMode : 2 =================================================== Decrypt SL3 PM 120 HASHES for Brute Force Unlock =================================================== Decrypting PM 120... (This may take upto 30 Seconds on New RAPIDO HASH) PM 120 HASHES Extracted Successfully BF6FEFE325CFB2CEE1E8A0183A3E82BE8BF35942 3777B234A723DA0777E0A85ADC45E7D8BA93F088 20D4AA03CDE848BE2F8CCB83B1A6B8CCFAE26855 B4F7E11EB062D7317526550F73B9A4BC1F68C6C3 1B4B3C3D4E7C7E011F33BE58B48B20B52D5EF19E D6F5102D90937F0F9193DEA5D5FA1181C6855224 600DB22F8A0593FE10EEC35DAFEF3039C77F5631 B3D6F21A78B96A5A0642B1D058736E7059E1A688 Log Files for Local Brute Force Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\353382045103335\353382045103335.log C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\353382045103335\353382045103335.bcl C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\353382045103335\353382045103335.sha Command Line for ighashgpu: ighashgpu -t:sha1 -salt:003533820451033300 -h:BF6FEFE325CFB2CEE1E8A0183A3E82BE8BF35942 -uh:00010203040506070809 -min:15 -max:15 Saved as MS Batch File: 353382045103335_ighashgpu.bat Process Done! |
05-06-2011, 06:33 | #12 (permalink) |
No Life Poster Join Date: May 2005 Location: Vietnam Age: 50
Member: 149256 Status: Offline Thanks Meter: 285 | VBATT OFF... VBATT ON Setting VBATT Done!... MCU: V ICPR71_09w47.3 09-02-10 RM-437 (c) Nokia IMEI: 354329047742742 Model : Nokia E63 Product Serial Number: M2P669718 Product Code : 0599062 Basic Production Code: 0561985 Default SN Type : 0 PPM Version : V ICPR71_09w47.3 09-02-10 RM-437 (c) Nokia HW Version : 0904 RFIC Version : 17141716 DSP Version : sofie.ICPR71_09w40 AHNE Version : 11 APE SW Core Version : 410.21.010 APE Variant Version : 410.21.010410.21.010_v333.02 APE Test Version : RM437ENO874571920.a01 Retu Version : 16 Tahvo Version : 22 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 8000000000000000 PROVIDER KEY: 5050200000000000 Provider : Singtel Optus-Cable + Wireless Optus;Australia Counters : 0/3 , 0/10 Block [1] 1:Close SP Lock Status : Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 16300113 ID DWORD 1 : 74A50052 ID DWORD 2 : 4474A6E9 ID DWORD 3 : A9FF1281 ID DWORD 4 : 277B442A 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : C7 0C B0 73 24 05 6B C6 6A 82 43 47 F4 0D B2 D5 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum F2 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 010.050.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.5 Checksum : 55 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :0020 DevID :0040 ExtID :0000 RevID :0031 Flash Descriptor Manufacturer Code : 0020 Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g Algorithm File - Version 010.050.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Scanning Simlock Applet Type... OK ================================================= PA_SL3 Applet detected ================================================= Dumping RSA Modulus... OK ================================================= RSA Modulus OK ================================================= FlashInfo.RestartMode : 2 ================================================== = Decrypt SL3 PM 120 HASHES for Brute Force Unlock ================================================== = Decrypting PM 120... (This may take upto 30 Seconds on New RAPIDO HASH) PM 120 HASHES Extracted Successfully EA177CF0CF98CA7AFF0FEE9FCCB3EFC7376CF1F1 1D8DEBAE9EBDBFA9DDB7F3ABB7F546B36C65A147 D7027BF33E4451F536A46DF55E4380B30A195AD3 37BD9DFEBDAE7693C6740963010A6C93EAB3CB06 8745B57F36EC3650BC77D74B72F42A49D8C639A5 CFF5B122C6196E16BD25EFD17B85AEAB1185A94F DB7DE6961C6995892C2DFB216E8134C086773285 2BE2AB72B0AC10FA6C41A3A39726A595BBD7FA11 Log Files for Local Brute Force Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\354329047742742\354329047 742742.log C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\354329047742742\354329047 742742.bcl C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\354329047742742\354329047 742742.sha Command Line for ighashgpu: ighashgpu -t:sha1 -salt:003543290477427400 -h:EA177CF0CF98CA7AFF0FEE9FCCB3EFC7376CF1F1 -uh:00010203040506070809 -min:15 -max:15 Saved as MS Batch File: 354329047742742_ighashgpu.bat Process Done! |
The Following User Says Thank You to trieubk For This Useful Post: |
05-06-2011, 06:33 | #13 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: In my body
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Sir, my decryption log is here.. sorry i couldn't attach it my first post. Quote:
05-06-2011, 06:34 | #14 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 46
Member: 88996 Status: Offline Thanks Meter: 86 | nk 5230 Code: ****************************************************** TIME STARTS HERE ****************************************************** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01051103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000296 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 04500115 ID DWORD 1 : C2A40052 ID DWORD 2 : AC5E39B4 ID DWORD 3 : 649DEF3A ID DWORD 4 : 66F49E84 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 4B9B7510 CRC 1 : 3E691FF8 Checksum 93 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg Boot File - Version 010.050.00 Boot File - Revision 0x0002 (2) eBB5ProtocolType == New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C Transmission Type Request Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 06 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> KAT00F00RA Extended/Fixed ID : 0000 Revision ID : 0231 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : XSR 1.6 Checksum : 13 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0231 Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR17_alg.fg Algorithm File - Version 010.050.00 Algorithm File - Revision 0x0002 (2) eBB5ProtocolType == New Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok... VPP Enabled by Software Using Internal VPP VPP Enabled by Software FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Scanning Simlock Applet Type... OK ================================================= PA_SIMLOC30 Applet detected Use "Scan Phone" Button to Check if this Phone uses a 15-digit NCK or a 20-digit NCK... ================================================= Dumping RSA Modulus... OK ================================================= RSA Modulus OK ================================================= FlashInfo.RestartMode : 2 =================================================== Decrypt SL3 PM 120 HASHES for Brute Force Unlock =================================================== Decrypting PM 120... (This may take upto 30 Seconds on New RAPIDO HASH) PM 120 HASHES Extracted Successfully 405504F1EFA95C941F1398FAEA6A1C5B07CD0207 F8A874D85C102A8B31BB61AF7BE17022BA5C0F57 9C6D90BFF7196A3225AEB7FAC296B1666133BD35 33981D4AFA4657D6C157C56EEDFA5AB6EB5D8444 CA6F4047121210E5273C5F65B2EAD4E112C68C89 D6DEB403B16213EB4EA9F3BFAAD7A090BA35968A 143FF7842BCD8C776974374D99769F367AC964C6 FD460C34323B001A0954A921F402D7D3F694B5DF Log Files for Local Brute Force Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\355396044893280\355396044893280.log C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\355396044893280\355396044893280.bcl C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\355396044893280\355396044893280.sha Command Line for ighashgpu: ighashgpu -t:sha1 -salt:003553960448932800 -h:405504F1EFA95C941F1398FAEA6A1C5B07CD0207 -uh:00010203040506070809 -min:15 -max:15 Saved as MS Batch File: 355396044893280_ighashgpu.bat Process Done! |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
FREE UNLOCK SIM CARD FOR 20 PHILIPS DIGA PHONES ON CELLNET | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-17-2011 18:10 |
Need help to make a site for free software | hicom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-14-1999 22:57 |
2 FREE NOKIA SP SIM CARDS TO RELEASE FOR INFORMATION WE NEED | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-25-1999 03:34 |
