12-17-2014, 15:39 | #18 (permalink) |
Freak Poster Join Date: May 2007 Location: Mladenovac-Belgrade Serbia
Member: 503664 Status: Offline Thanks Meter: 61 | 5:30:13 : Task Selected: Normal Factory Erase 15:30:13 : ================================================== ==== 15:30:13 : For eMMC Revision 1.2 (for MMC v4.2) and LOWER 15:30:13 : --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB 15:30:13 : For eMMC Revision 1.3 (for MMC v4.3) and HIGHER 15:30:13 : --> This will ONLY ERASE USER AREA 15:30:13 : ================================================== ==== 15:30:13 : This eMMC is: Revision 1.6 (for MMC v4.5) 15:30:13 : 15:30:13 : Factory Erasing Supported FLASH AREA... 15:30:16 : Normal Factory Erase Done! 15:30:16 : 15:30:16 : ================================================== ==== 15:30:16 : WARNING - WARNING - WARNING - WARNING - WARNING 15:30:16 : ================================================== ==== 15:30:16 : 1. WRITE BOOT1 Image if Needed 15:30:16 : 2. WRITE BOOT2 Image if Needed 15:30:16 : 3. WRITE USER AREA Image if Needed 15:30:16 : ================================================== ==== 15:30:22 : ================================================== ==== 15:30:22 : ================================================== ==== 15:30:22 : eMMC Test Point Connection Module 15:30:22 : ================================================== ==== 15:30:22 : ================================================== ==== 15:30:22 : 15:30:22 : 1. DO NOT USE THE PHONE"S BATTERY 15:30:22 : 2. Connect the Soldered TP Connections to ATF Box 15:30:22 : 3. Disconnect the USB Cable and Wait until the 15:30:22 : the ATF Software will tell you to Connect the USB. 15:30:22 : 15:30:22 : 15:30:22 : Interface Reset OK! 15:30:22 : eMMC Access Type: SECTOR MODE 15:30:22 : eMMC Supported Voltage Range: 15:30:22 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 15:30:22 : 15:30:22 : CID : 1501004B3558594D420370DFDCC5 15:30:22 : CSD : D02701320F5903FFF6DBFFEF8E40400D 15:30:22 : 15:30:22 : eMMC Boot Information 15:30:22 : Revision 1.6 (for MMC v4.5) 15:30:22 : BOOT PARTITION : BOOT PARTITION 1 15:30:22 : PARTITION ACCESS : R/W USER PARTITION 15:30:22 : PERM_BOOT_CFG_PROT : DISABLED 15:30:22 : PWR_BOOT_CFG_PROT : DISABLED 15:30:22 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 15:30:22 : RESET BUS WIDTH : ENABLED 15:30:22 : eMMC FirmW UPDATE : DISABLED 15:30:22 : EMMC CACHE SIZE : 0 KB 15:30:22 : SUPER PAGE SIZE : 3072 KB 15:30:22 : HC ERASE GROUP SIZE: 512 KB 15:30:22 : USER AREA SIZE : 3909091328 BYTES 15:30:22 : BOOT PARTITION SIZE: 4096 KB 15:30:22 : RPMB PARTITION SIZE: 512 KB 15:30:22 : 15:30:22 : 15:30:22 : eMMC Device Information 15:30:22 : Manufacturer ID: SAMSUNG 15:30:22 : Device Type : Embedded BGA 15:30:22 : Application ID : 00 15:30:22 : Product Name : K5XYMB 15:30:22 : Product Rev : 0.3 15:30:22 : Product SN : 70DFDCC5 15:30:22 : Manufactured : January 1998 15:30:22 : 15:30:22 : Card Specific Data 15:30:22 : CSD_STRUCTURE : Extended 15:30:22 : SPEC_VERS : Version 4.1/4.2/4.3 15:30:22 : TAAC : 13 ns 15:30:22 : TRANS_SPEED : 4000000 KHz 15:30:22 : READ_BL_LEN : 512 Bytes 15:30:22 : C_SIZE : HIGH CAPACITY 15:30:22 : WP_GRP_ENABLE : YES 15:30:22 : WRITE_BL_LEN : 512 Bytes 15:30:22 : CONTENT_PROT_APP : NO 15:30:22 : PERM_WRITE_PROTECT: NO 15:30:22 : TMP_WRITE_PROTECT : NO 15:30:22 : 15:30:22 : Extended CSD Saved: 15:30:22 : 1501004B3558594D420370DFDCC5_F7F8F2D0.ext_csd 15:30:22 : Backup Directory: 15:30:22 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 15:30:22 : 15:30:24 : 15:30:24 : Task Selected: Samsung Factory Format 15:30:24 : ================================================== ==== 15:30:24 : For eMMC Revision 1.5 (for MMC v4.41) and LOWER 15:30:24 : --> This will ERASE USER AREA, BOOT1, BOOT2, RPMB and EXT_CSD R/W/E Entries 15:30:24 : For eMMC Revision 1.6 (for MMC v4.5) and HIGHER 15:30:24 : --> This will ONLY ERASE USER AREA 15:30:24 : ================================================== ==== 15:30:24 : This eMMC is: Revision 1.6 (for MMC v4.5) 15:30:24 : 15:30:24 : Samsung Factory Format Start... 15:30:24 : Format Done! 15:30:24 : 15:30:24 : ================================================== ==== 15:30:24 : WARNING - WARNING - WARNING - WARNING - WARNING 15:30:24 : ================================================== ==== 15:30:24 : 1. WRITE Back EXT_CSD Backup if Needed 15:30:24 : 2. WRITE BOOT1 Image if Needed 15:30:24 : 3. WRITE BOOT2 Image if Needed 15:30:24 : 4. WRITE USER AREA Image if Needed 15:30:24 : ================================================== ==== 15:30:30 : ================================================== ==== 15:30:30 : ================================================== ==== 15:30:30 : eMMC Test Point Connection Module 15:30:30 : ================================================== ==== 15:30:30 : ================================================== ==== 15:30:30 : 15:30:30 : 1. DO NOT USE THE PHONE"S BATTERY 15:30:30 : 2. Connect the Soldered TP Connections to ATF Box 15:30:30 : 3. Disconnect the USB Cable and Wait until the 15:30:30 : the ATF Software will tell you to Connect the USB. 15:30:30 : 15:30:30 : 15:30:30 : Interface Reset OK! 15:30:30 : eMMC Access Type: SECTOR MODE 15:30:30 : eMMC Supported Voltage Range: 15:30:30 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 15:30:30 : 15:30:30 : CID : 1501004B3558594D420370DFDCC5 15:30:30 : CSD : D02701320F5903FFF6DBFFEF8E40400D 15:30:30 : 15:30:30 : eMMC Boot Information 15:30:30 : Revision 1.6 (for MMC v4.5) 15:30:30 : BOOT PARTITION : BOOT PARTITION 1 15:30:30 : PARTITION ACCESS : R/W USER PARTITION 15:30:30 : PERM_BOOT_CFG_PROT : DISABLED 15:30:30 : PWR_BOOT_CFG_PROT : DISABLED 15:30:30 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 15:30:30 : RESET BUS WIDTH : ENABLED 15:30:30 : eMMC FirmW UPDATE : DISABLED 15:30:30 : EMMC CACHE SIZE : 0 KB 15:30:30 : SUPER PAGE SIZE : 3072 KB 15:30:30 : HC ERASE GROUP SIZE: 512 KB 15:30:30 : USER AREA SIZE : 3909091328 BYTES 15:30:30 : BOOT PARTITION SIZE: 4096 KB 15:30:30 : RPMB PARTITION SIZE: 512 KB 15:30:30 : 15:30:30 : 15:30:30 : eMMC Device Information 15:30:30 : Manufacturer ID: SAMSUNG 15:30:30 : Device Type : Embedded BGA 15:30:30 : Application ID : 00 15:30:30 : Product Name : K5XYMB 15:30:30 : Product Rev : 0.3 15:30:30 : Product SN : 70DFDCC5 15:30:30 : Manufactured : January 1998 15:30:30 : 15:30:30 : Card Specific Data 15:30:30 : CSD_STRUCTURE : Extended 15:30:30 : SPEC_VERS : Version 4.1/4.2/4.3 15:30:30 : TAAC : 13 ns 15:30:30 : TRANS_SPEED : 4000000 KHz 15:30:30 : READ_BL_LEN : 512 Bytes 15:30:30 : C_SIZE : HIGH CAPACITY 15:30:30 : WP_GRP_ENABLE : YES 15:30:30 : WRITE_BL_LEN : 512 Bytes 15:30:30 : CONTENT_PROT_APP : NO 15:30:30 : PERM_WRITE_PROTECT: NO 15:30:30 : TMP_WRITE_PROTECT : NO 15:30:30 : 15:30:30 : Extended CSD Saved: 15:30:30 : 1501004B3558594D420370DFDCC5_E91CD07F.ext_csd 15:30:30 : Backup Directory: 15:30:30 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 15:30:30 : 15:30:41 : 15:30:41 : Task Selected: Write EXT_CSD Backup 15:30:41 : Task Done! 15:30:41 : 15:31:01 : 15:31:01 : ================================================== ==== 15:31:01 : Loading ATF MMC File... (Please Wait) 15:31:01 : ================================================== ==== 15:31:01 : 15:31:01 : MMC File Version: v11.30 15:31:01 : MMC File Author: 963F2A3CB175EDB4B4358C42 15:31:01 : Date Created: 08/12/2014 (dd/mm/yyyy) 15:31:01 : Description: Samsung SM-G355H 4.4.2 [G355HXXU0****] 15:31:01 : 15:31:02 : Current Partition: Partition 1 15:31:02 : Start Writing Blocks... 15:31:02 : Writing Blocks Done! 15:31:02 : Current Partition: Partition 2 15:31:02 : Start Writing Blocks... 15:31:02 : Writing Blocks Done! 15:31:02 : Current Partition: Partition 3 15:31:02 : Start Writing Blocks... 15:31:02 : Writing Blocks Done! 15:31:02 : Current Partition: Partition 4 15:31:02 : Start Writing Blocks... 15:31:02 : Writing Blocks Done! 15:31:02 : Current Partition: Partition 5 15:31:02 : Start Writing Blocks... 15:31:05 : Writing Blocks Done! 15:31:05 : Current Partition: Partition 6 15:31:05 : Start Writing Blocks... 15:31:08 : Writing Blocks Done! 15:31:08 : Current Partition: Partition 7 15:31:08 : Start Writing Blocks... 15:31:09 : Writing Blocks Done! 15:31:09 : Current Partition: Partition 8 15:31:09 : Start Writing Blocks... 15:31:09 : Writing Blocks Done! 15:31:09 : 15:31:09 : 15:31:09 : Perform Firmware Update via USB Cable. 15:31:09 : 15:31:09 : 15:31:09 : Total Elapsed Time 00:00:08 15:31:09 : Write Success! 15:31:15 : ================================================== ==== 15:31:15 : ================================================== ==== 15:31:15 : eMMC Test Point Connection Module 15:31:15 : ================================================== ==== 15:31:15 : ================================================== ==== 15:31:15 : 15:31:15 : 1. DO NOT USE THE PHONE"S BATTERY 15:31:15 : 2. Connect the Soldered TP Connections to ATF Box 15:31:15 : 3. Disconnect the USB Cable and Wait until the 15:31:15 : the ATF Software will tell you to Connect the USB. 15:31:15 : 15:31:15 : 15:31:15 : Interface Reset OK! 15:31:15 : eMMC Access Type: SECTOR MODE 15:31:15 : eMMC Supported Voltage Range: 15:31:15 : 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V 15:31:15 : 15:31:15 : CID : 1501004B3558594D420370DFDCC5 15:31:15 : CSD : D02701320F5903FFF6DBFFEF8E40400D 15:31:15 : 15:31:15 : eMMC Boot Information 15:31:15 : Revision 1.6 (for MMC v4.5) 15:31:15 : BOOT PARTITION : BOOT PARTITION 1 15:31:15 : PARTITION ACCESS : R/W USER PARTITION 15:31:15 : PERM_BOOT_CFG_PROT : DISABLED 15:31:15 : PWR_BOOT_CFG_PROT : DISABLED 15:31:15 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED 15:31:15 : RESET BUS WIDTH : ENABLED 15:31:15 : eMMC FirmW UPDATE : DISABLED 15:31:15 : EMMC CACHE SIZE : 0 KB 15:31:15 : SUPER PAGE SIZE : 3072 KB 15:31:15 : HC ERASE GROUP SIZE: 512 KB 15:31:15 : USER AREA SIZE : 3909091328 BYTES 15:31:15 : BOOT PARTITION SIZE: 4096 KB 15:31:15 : RPMB PARTITION SIZE: 512 KB 15:31:15 : 15:31:15 : 15:31:15 : eMMC Device Information 15:31:15 : Manufacturer ID: SAMSUNG 15:31:15 : Device Type : Embedded BGA 15:31:15 : Application ID : 00 15:31:15 : Product Name : K5XYMB 15:31:15 : Product Rev : 0.3 15:31:15 : Product SN : 70DFDCC5 15:31:15 : Manufactured : January 1998 15:31:15 : 15:31:15 : Card Specific Data 15:31:15 : CSD_STRUCTURE : Extended 15:31:15 : SPEC_VERS : Version 4.1/4.2/4.3 15:31:15 : TAAC : 13 ns 15:31:15 : TRANS_SPEED : 4000000 KHz 15:31:15 : READ_BL_LEN : 512 Bytes 15:31:15 : C_SIZE : HIGH CAPACITY 15:31:15 : WP_GRP_ENABLE : YES 15:31:15 : WRITE_BL_LEN : 512 Bytes 15:31:15 : CONTENT_PROT_APP : NO 15:31:15 : PERM_WRITE_PROTECT: NO 15:31:15 : TMP_WRITE_PROTECT : NO 15:31:15 : 15:31:15 : Extended CSD Saved: 15:31:15 : 1501004B3558594D420370DFDCC5_810263C8.ext_csd 15:31:15 : Backup Directory: 15:31:15 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
The Following User Says Thank You to johnnyml For This Useful Post: |
12-17-2014, 15:43 | #19 (permalink) |
Member: 503664 Status: Offline Thanks Meter: 61 | normal factory erase,samsung factory format,write EXT bacup csd then select boot 1 and write your boot file and all ok scan all ok but phone is still dead phone was come to my friend with lost imei he root it and change imei after imei change phone is dead after repair with atf phone is still dead any idea or sugestion if i make something wrong? |
12-17-2014, 16:04 | #20 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Not sure why you needed to factory erase the emmc before writing the boot file. IMEI patch could have been fixed easily by writing back unpatched partitions. I will recheck boot file and make it work on blank emmc. In the mean time, charge your phone battery and make sure it is not just battery problem |
12-17-2014, 16:10 | #21 (permalink) |
Member: 503664 Status: Offline Thanks Meter: 61 | hm batery is ok and its full 4.2v i try on external power too but now i see 2 problems resistor on CLK and CMD are gone from board may i put jump on them(short 2 poind on plase where resistor was?|) |
12-17-2014, 20:48 | #22 (permalink) |
Freak Poster Join Date: Apr 2007 Location: turkey Age: 35
Member: 495542 Status: Offline Sonork: 100.1650191 Thanks Meter: 45 | sorry Advance-Box i upload wrong pic this the another board its Different plz give the pinout for it Simple File Sharing and Storage. Last edited by Advance-Box; 12-18-2014 at 00:23. |
12-17-2014, 23:51 | #23 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
You need to find 2 Resistors ... CMD Resistor should be 10K Ohms CLK Resistor should be 0 Ohms 10K resistor is easy to find from another dead mobile phone which can be used for chop-chop parts... you cannot bypass 10K resistor, it will never work... 0 Ohms can be bypassed with solder... but it DOES NOT ALWAYS WORK. You can try to bypass first and check if it works. | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
12-18-2014, 00:23 | #24 (permalink) | |
B.R. | |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
12-19-2014, 20:25 | #25 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: Abidjan Age: 38
Member: 1418143 Status: Offline Thanks Meter: 353 | my succees log but phone's still dead , thanks ATFTeam ... Quote:
12-20-2014, 18:13 | #27 (permalink) |
Member: 503664 Status: Offline Thanks Meter: 61 | jup i found it few days ago myself BLUE point (cmd) is on other side of that resistor on picture all other points are ok br zoran btw if you make your phone works send me backup of your emmc |
12-22-2014, 20:24 | #28 (permalink) |
Junior Member Join Date: Jul 2011
Member: 1611156 Status: Offline Sonork: 12 Thanks Meter: 8 | plz ...... this massage error ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC IS NOT Ready! (CMD1) Try to Adjust VCCIO Voltage CMD1 Reply: 0x6D2DB692 what this problem i check testpoint and soldered and voltage 3.3 ~ 1.8 plz i need Solution Last edited by srinibas; 05-05-2015 at 08:57. |
The Following 2 Users Say Thank You to mahmoud_maaz For This Useful Post: |
12-23-2014, 02:59 | #29 (permalink) |
Member: 503664 Status: Offline Thanks Meter: 61 | try to conect cmd data clk only form atf box on board than clik start and than put only usb cable for me that mwtod works you see my log |
01-01-2015, 17:50 | #30 (permalink) |
Member: 1611156 Status: Offline Sonork: 12 Thanks Meter: 8 | plz ........... ineed sdc file not work connect emmc on advance adapter plz gues not work sm-g355h/ds on emmc connect by advance plz i need any way i think way sdc file for this board but is not sdc file on internet plz i need sdc and testpoint for samsung core2 sm-g355h/ds thanks |
