03-21-2015, 18:37 | #63 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Why not read carefully All thread from 1 post?, loock what is you PCB and post screen and Log of what error have...if not understand good all you have need in this mode we can see where's the problem....w/o log and screenshoot how can help you only whith this: Quote:
03-22-2015, 22:50 | #65 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @petekere, what post here w/o read Sticky thread and most important previous post of this thread from #1 post?....here nothingh more give you pinout picture w/o post Photo in HD of Pcb from 2 side Anyway there one clear Sticky thread Here: http://forum.gsmhosting.com/vbb/f609...orial-1908984/ Use this... BR |
03-24-2015, 13:07 | #71 (permalink) | ||
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @asif-rashid and @cehajic What this: Quote:
You 2, please let me see that have used "PINOUT FINDER TP" posted in my above post #65 and can not work or what the problem.... BR | ||
03-26-2015, 07:52 | #72 (permalink) |
No Life Poster Join Date: Jun 2008
Member: 792254 Status: Offline Sonork: al_jadeed Thanks Meter: 171 | sorry for mistak . i have 2 set one ok and other dead after flash. log is same ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x5E5E5E5E |
