G532G Dead boot repair not done? ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 90014A48384734759201192BC49FB49F CSD : D02701320F5903FFFFFFFFE78A40002B eMMC Boot Information Revision 1.7 (for MMC v5.0, v5.01) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3072 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 4096 KB eMMC Device Information Manufacturer ID: HYNIX Device Type : Embedded BGA Application ID : 4A Product Name : H8G4u Product Rev : 0.1 Product SN : 192BC49F Manufactured : January 2001 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 90014A48384734759201192BC49FB49F.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Start Writing Flash Images... Flash Image: preloader.img Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Operation Cancelled... Whats problem dear team ?:mad::mad::mad: |
mmmmm, bad emmc? backup if it's possible and try replacing emmc. |
