Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 01-25-2020, 15:41   #1 (permalink)
Member: 770229
Sonork: 29050
Thanks Meter: 97
G532G Dead boot repair not done?
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 90014A48384734759201192BC49FB49F
CSD : D02701320F5903FFFFFFFFE78A40002B
eMMC Boot Information
Revision 1.7 (for MMC v5.0, v5.01)
BOOT PARTITION : BOOT PARTITION 1
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 3072 KB
HC ERASE GROUP SIZE: 512 KB
USER AREA SIZE : 7818182656 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 4096 KB
eMMC Device Information
Manufacturer ID: HYNIX
Device Type : Embedded BGA
Application ID : 4A
Product Name : H8G4u’
Product Rev : 0.1
Product SN : 192BC49F
Manufactured : January 2001
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 13 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
90014A48384734759201192BC49FB49F.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Start Writing Flash Images...
Flash Image: preloader.img
Start Writing 0x00002000 Blocks at 0x00000000
Partition Selected: BOOT 1
Operation Cancelled...
Whats problem dear team ?
Old 01-25-2020, 19:15   #2 (permalink)
Member: 2058871
Sonork: 100.1664591
Thanks Meter: 196
mmmmm, bad emmc? backup if it's possible and try replacing emmc.
Page generated in 1.33554 seconds with 7 queries
