Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 11-27-2014, 03:00   #1 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
Galaxy Core Max SM-G5108Q SDC Tests
ATF Now Support 64-BIT Qualcomm CPU MSM8916 for SDC BOOT Repair.
Here is a Galaxy Core Max SM-G5108Q booting via SDC and entering Download Mode:
Instructions:
1. Download SDC File From ATF Support Site:
ATF Offcial Support Area / file-support / Samsung SDC Files
2. Write SDC File to a 8GB SDHC Micro SD Card via ATF Software SDC Tool
3. Insert micro SD Card to Phone
4. Insert USB Cable to Phone and wait...
You will get Download Mode Shortly
5. Flash Phone with a Firmware same version as SDC File or Higher
The Following 28 Users Say Thank You to Advance-Box For This Useful Post:
Old 11-27-2014, 07:30   #2 (permalink)
kjava's Avatar
Member: 846616
Sonork: 100.1675590
Thanks Meter: 581
for step number 4 insert USB Cable or USB JIG
Old 11-27-2014, 07:38   #3 (permalink)
Member: 651945
I just inserted ordinary USB cable.
I did not use USB JIG
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 11-27-2014, 08:54   #4 (permalink)
worldlinkmobil's Avatar
Member: 1275418
Thanks Meter: 432
if phone is dad that we do like this mothard
The Following User Says Thank You to worldlinkmobil For This Useful Post:
Old 11-27-2014, 09:44   #5 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
all of them getting boot repaired without disassembling?
The Following User Says Thank You to huzein For This Useful Post:
Old 11-27-2014, 10:28   #6 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Yes, only via Micro SD card and ATF Box - NO NEED TO DISASSEMBLE PHONE, NO SOLDERING
The Following 3 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 11-27-2014, 12:44   #7 (permalink)
.:Zulfiqar:.'s Avatar
Member: 1224733
Thanks Meter: 158
thanks for this nice update,and how to write SDC File with ATF?
The Following User Says Thank You to .:Zulfiqar:. For This Useful Post:
Old 11-27-2014, 13:21   #8 (permalink)
Member: 2216518
Sonork: www.sonork.com
ok broth thnk for info atf is the best
Old 11-27-2014, 13:23   #9 (permalink)
Member: 643472
Sonork: 100.96901
http://forum.gsmhosting.com/vbb/f609...oader-1885507/
Old 11-28-2014, 08:34   #10 (permalink)
Member: 138234
Thanks Meter: 79
what about no Product name problem ?
Old 11-30-2014, 01:19   #11 (permalink)
huzein's Avatar
Member: 396421
Thanks Meter: 87
this is mostly a hardware issue and irreparable.
Old 11-04-2015, 15:51   #12 (permalink)
Member: 128322
Thanks Meter: 13
Dear support service ... please tell me the files to restore A500FU 5.0.2 is not planned?
Old 11-05-2015, 22:09   #13 (permalink)
Member: 643472
Sonork: 100.96901
Cannot you make SDC from Android 5.0.2 firmware for yourself?
Old 11-10-2016, 11:32   #14 (permalink)
Member: 2425027
Sonork: frind
Samsung A5 dead after flash
Samsung A500fu dead after flash
Page generated in 0.19081 seconds with 8 queries
