05-24-2015, 14:26 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Bahawal Nagar
Member: 793565 Status: Offline Sonork: 100.1611436 Thanks Meter: 356 | Guide to Factry Reset N7100 EMMC :) Phone have many problems . hang on startup . not wrting firmware proper sometiems ok but some times fail.... need help to larn ATF EMMC Functions .... factry format guide needed ...as we rest all android phone to fatry reset :P please guide ATF Team Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010056545530304DF1299902898FA7 CSD : D02701320F5903FFF6DBFFFF8E406009 eMMC Boot Information Revision 1.6 (for MMC v4.5, v4.51) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 15758000128 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : VTU00M Product Rev : 15.1 Product SN : 29990289 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: YES TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010056545530304DF1299902898FA7.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ |
05-24-2015, 14:52 | #3 (permalink) | |
Member: 793565 Status: Offline Sonork: 100.1611436 Thanks Meter: 356 | boot1,boot2 and user files same? Quote: BOOT1 BOOT2 USER AREA .BIN These files will work for N7100 ? | |
05-25-2015, 04:54 | #6 (permalink) |
Junior Member Join Date: Jul 2013 Location: Indonesia
Member: 1988010 Status: Offline Thanks Meter: 20 | Look the red text... Use the remove write protection menu.. Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: YES TMP_WRITE_PROTECT : NO |
05-25-2015, 05:24 | #7 (permalink) | |
Member: 793565 Status: Offline Sonork: 100.1611436 Thanks Meter: 356 | wht its is necessery to switch no ? Quote:
why we need to change protetion YES to NO ? PERM_WRITE_PROTECT: YES | |
05-25-2015, 05:31 | #8 (permalink) | |
Member: 793565 Status: Offline Sonork: 100.1611436 Thanks Meter: 356 | OK As u said i remove this Quote:
Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO | |
05-25-2015, 07:05 | #9 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @gulzarjan Man, all you want to know is already on post #2 which I put link: http://forum.gsmhosting.com/vbb/f609...tures-1945278/ All files, all pictures, all procedure already very clear there... Now if you still asking how to do it, it means you did not look at that link. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
