08-01-2014, 15:29 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Cuba
Member: 1484663 Status: Offline Thanks Meter: 344 | Heil with ATF Jtag colors values! |
08-02-2014, 13:19 | #4 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Br allumts | |
08-03-2014, 15:34 | #5 (permalink) |
Member: 1484663 Status: Offline Thanks Meter: 344 | I just want to know what is the value of every color in the pinout so I can solder it in the lumias board. Is that so hard to understand? Why asking for unnecesary pictures. I´m trying to use a 5 in 1 adaptor. I know it´s useless for emmc but I need to unlock e few Lumias and I cannot wait for the 4 in 1 adapter from smartgsm to arrive. Please answer quick I got clients waiting. BR |
08-03-2014, 16:19 | #6 (permalink) | |
No Life Poster Join Date: Jun 2013
Member: 1963729 Status: Offline Thanks Meter: 132 | Quote:
The Following User Says Thank You to Gead For This Useful Post: |
08-03-2014, 18:05 | #7 (permalink) |
No Life Poster Join Date: May 2006 Location: heLL and beY0nd
Member: 281801 Status: Offline Sonork: 100.1608672 Thanks Meter: 158 | GPG are plastic maker not GSM Reverse Engineering Device producer. Buy ffrom smart-gsm.net only, They have correct Adapter and working perfectly |
10-30-2015, 14:30 | #8 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: türkey AKSARAY
Member: 897899 Status: Offline Thanks Meter: 36 | Quote:
here is die loog Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x12 Application ID : 4V Product Name : SD Product Revision : 0.0 Serial Number : 000003C7 Manufacture Date: August 2015 Card CID: 123456534420202000000003C700F84D Card CSD: 400E00325B5900003AE77F800A400095 Card SCR: 0235800100000000 Card OCR: 00C0FF8000 SD Card Size : 7906263040 Bytes SD Block Size: 512 Bytes Maximum Speed: 25000000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is NOT Password Protected!!! sdc write ================================================== ==== ================================================== ==== SDC Direct Access Connection Module ================================================== ==== ================================================== ==== Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x12 Application ID : 4V Product Name : SD Product Revision : 0.0 Serial Number : 000003C7 Manufacture Date: August 2015 Card CID: 123456534420202000000003C700F84D Card CSD: 400E00325B5900003AE77F800A400095 Card SCR: 0235800100000000 Card OCR: 00C0FF8000 SD Card Size : 7906263040 Bytes SD Block Size: 512 Bytes Maximum Speed: 25000000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is NOT Password Protected!!! Samsung GT-I9500 UNBRICK Android 4.3 Start Writing to SDC at 0x00000000... Number of Blocks: 0x00001000 Process Done... ================================================== ==== 1. Solder THIN WIRE to Test Point Location A and B 2. Connect Test Point A and B Together 3. Assemble Phone with LCD 4. Make Sure Battery is Fully Charged 5. Press Power Button and Wait for SDCARD MODE Menu 6. Press Volume DOWN KEY to Enter DOWNLOAD MODE 7. DISCONNECT Test Point A and B Connection 8. Flash the Phone with ODIN ================================================== ==== Total Elapsed Time 00:00:04 Write Success! lumia 625 boot repair with this adapter ================================================== ======== Phone Type : Lumia 625 RM-941 CPU Type : Qualcomm MSM8930 Storage Type: eMMC 8GB Boot Package: 3056.40000.1402.1005 (BIG BOOT) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x4F1F0F0F IR4 Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core with 100ms Delay...OK Initializing Device...OK Detecting eMMC #1 ID...1501004D3847325943003C564B13806F Flash Description: Samsung M8G2YC, 7.28 GiB, SN 3C564B13, Aug 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (3263 Op/Sec) Restoring MBR Data...OK Restoring GPT Data from AFP...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...OK Restoring Partition #10...OK Completed in 0h 10m 10s. Code Download Speed 289 KiB/sec. Boot Restore Done! Last edited by chromgsmunlock; 10-30-2015 at 14:35. | |
