Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 06-09-2015, 16:39   #1 (permalink)
Member: 1974399
Sonork: 100.1625527
Thanks Meter: 5
hello atf team plzz help
my nokia lumia 520 error unable to find boot dead after samsung firmware update only.... now here is previous emmc info 21:06:00 :
21:06:00 : eMMC Boot Information
21:06:00 : Revision 1.5 (for MMC v4.41)
21:06:00 : BOOT PARTITION : USER AREA
21:06:00 : PARTITION ACCESS : R/W USER PARTITION
21:06:00 : PERM_BOOT_CFG_PROT : DISABLED
21:06:00 : PWR_BOOT_CFG_PROT : DISABLED
21:06:00 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
21:06:00 : RESET BUS WIDTH : ENABLED
21:06:00 : eMMC FirmW UPDATE : DISABLED
21:06:00 : EMMC CACHE SIZE : 0 KB
21:06:00 : SUPER PAGE SIZE : 3584 KB
21:06:00 : HC ERASE GROUP SIZE: 512 KB
21:06:00 : USER AREA SIZE : 7818182656 BYTES
21:06:00 : BOOT PARTITION SIZE: 4096 KB
21:06:00 : RPMB PARTITION SIZE: 512 KB
21:06:00 :
21:06:00 :
21:06:00 : eMMC Device Information
21:06:00 : Manufacturer ID: SAMSUNG
21:06:00 : Device Type : Embedded BGA
21:06:00 : Application ID : 00
21:06:00 : Product Name : M8G2YC
21:06:00 : Product Rev : 0.0
21:06:00 : Product SN : 89DE538D
21:06:00 : Manufactured : September 1997
21:06:00 :
21:06:00 : Card Specific Data
21:06:00 : CSD_STRUCTURE : Extended
21:06:00 : SPEC_VERS : Version 4.1/4.2/4.3
21:06:00 : TAAC : 13 ns
21:06:00 : TRAN_SPEED : 4000000 KHz
21:06:00 : READ_BL_LEN : 512 Bytes
21:06:00 : C_SIZE : HIGH CAPACITY
21:06:00 : WP_GRP_ENABLE : YES
21:06:00 : WRITE_BL_LEN : 512 Bytes
21:06:00 : CONTENT_PROT_APP : NO
21:06:00 : PERM_WRITE_PROTECT: YES
21:06:00 : TMP_WRITE_PROTECT : NO
21:06:00 :
21:06:00 : Extended CSD Saved:
21:06:00 : 1501004D38473259430089DE538D9037.ext_csd
21:06:00 : Backup Directory:
21:06:00 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ nd here is now
21:35:40 : eMMC Boot Information
21:35:40 : Revision 1.5 (for MMC v4.41)
21:35:40 : BOOT PARTITION : NOT BOOT ENABLED
21:35:40 : PARTITION ACCESS : R/W USER PARTITION
21:35:40 : PERM_BOOT_CFG_PROT : DISABLED
21:35:40 : PWR_BOOT_CFG_PROT : DISABLED
21:35:40 : BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
21:35:40 : RESET BUS WIDTH : ENABLED
21:35:40 : eMMC FirmW UPDATE : DISABLED
21:35:40 : EMMC CACHE SIZE : 0 KB
21:35:40 : SUPER PAGE SIZE : 4096 KB
21:35:40 : HC ERASE GROUP SIZE: 512 KB
21:35:40 : USER AREA SIZE : 8587837440 BYTES
21:35:40 : BOOT PARTITION SIZE: 512 KB
21:35:40 : RPMB PARTITION SIZE: 128 KB
21:35:40 :
21:35:40 :
21:35:40 : eMMC Device Information
21:35:40 : Manufacturer ID: SAMSUNG
21:35:40 : Device Type : Embedded BGA
21:35:40 : Application ID : 00
21:35:40 : Product Name : 000000
21:35:40 : Product Rev : 5.6
21:35:40 : Product SN : 20110726
21:35:40 : Manufactured : January 2005
21:35:40 :
21:35:40 : Card Specific Data
21:35:40 : CSD_STRUCTURE : Version 1.2
21:35:40 : SPEC_VERS : Version 4.1/4.2/4.3
21:35:40 : TAAC : 13 ns
21:35:40 : TRAN_SPEED : 4000000 KHz
21:35:40 : READ_BL_LEN : 512 Bytes
21:35:40 : C_SIZE : HIGH CAPACITY
21:35:40 : WP_GRP_ENABLE : YES
21:35:40 : WRITE_BL_LEN : 512 Bytes
21:35:40 : CONTENT_PROT_APP : NO
21:35:40 : PERM_WRITE_PROTECT: NO
21:35:40 : TMP_WRITE_PROTECT : NO
21:35:40 :
21:35:40 : Extended CSD Saved:
21:35:40 : 1501003030303030305620110726589D.ext_csd
21:35:40 : Backup Directory:
21:35:40 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
21:35:40 :
21:35:52 : ============================================
Old 06-12-2015, 16:47   #2 (permalink)
Member: 1974399
Sonork: 100.1625527
Thanks Meter: 5
hello atf supporters where r u plzz help me to recover this phone customer irritating me.......plzz help...
Old 06-16-2015, 13:52   #3 (permalink)
Member: 1974399
Sonork: 100.1625527
Thanks Meter: 5
dear atf supporters is there any solution of my problem plzz reply me yes or no......
Old 06-16-2015, 14:34   #4 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
http://forum.gsmhosting.com/vbb/11103011-post3.html
Old 06-16-2015, 16:56   #5 (permalink)
Member: 1974399
Sonork: 100.1625527
Thanks Meter: 5
Originally Posted by ..::Angel::.. View Post
thanx fr reply sir bt my problem is that my emmc firmware not in the list i hv 512 mb backup dump then what can i do plzzz help....
Old 06-17-2015, 03:12   #6 (permalink)
joel_3mo's Avatar
Member: 2061381
Sonork: 100.1673769
Thanks Meter: 129
I think this is your problem.
21:06:00 :
21:06:00 :
21:06:00 :
21:06:00 :
21:35:40 :
21:35:40 :
21:35:40 :
21:35:40 :
21:35:40 :
Try doing what @Angel says. Also try flashing it via USB.
Old 06-17-2015, 07:51   #7 (permalink)
Member: 1974399
Sonork: 100.1625527
Thanks Meter: 5
yes u r absolutely right bro i tried usb flashing also no luck nd from angel sir point of view 3rd option firmware update+format needs emmc firmware bt my emmc part no. not in atf list nd emmc 512 mb dump backup when i write it says rib timeout error i tried speed 2.5 mhz also bt no luck so what can i do now plzz help thanks in advance.....
Old 06-17-2015, 16:07   #8 (permalink)
Member: 1974399
Sonork: 100.1625527
Thanks Meter: 5
plzzz help me dear supporters i think this is not a big issue from ur side so plzz help...
Old 06-20-2015, 07:37   #9 (permalink)
Member: 1974399
Sonork: 100.1625527
Thanks Meter: 5
plzz help me dear supportwes i m in big problem customer claming for new set.....
Old 06-20-2015, 09:04   #10 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
@RAHUL BARASIA
Contact Me In Private
If You Have 512MB Dump Backup Before Doing Any Thing
I Will Try To Help You
Old 06-20-2015, 09:33   #11 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
21:06:00 :
21:06:00 :
21:06:00 :
21:06:00 :
21:35:40 :
21:35:40 :
21:35:40 :
21:35:40 :
21:35:40 :
I think your problem is Lumia 520 "Unable to Find a Bootable option"
you have Z3X Easy Jtag?
Old 06-20-2015, 16:12   #12 (permalink)
Member: 1974399
Sonork: 100.1625527
Thanks Meter: 5
hello supporters i m in new problem now after the help of shoaibrao i do firmware update+format there i select m8g2yc then software asking for part number then i write part number as shown on emmc ic k4p4g324eq-pgc2 bt after that software says ur answer is incorrect....what can i do know plzz help thanks to shoaibrao fr giving me his valuable time....
Old 06-20-2015, 16:50   #13 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Hello
Try To Write In Capital Words Like This
K4P4G324EB-PGC2
Old 06-20-2015, 17:05   #14 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Also Try Just Like This
K4P4G324EQ-PGC2
Or
K4P4G324EQ
Or
K4P4G324EQPGC2
Old 06-20-2015, 17:25   #15 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
Mr.Rahul Barasia,If your problem is "Unable to Find Bootable Option" ;try to Remove write protection....and flash it again....100% OK
Page generated in 0.27268 seconds with 8 queries
