04-26-2012, 16:15 | #6 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | 13.12.09 : ================================================ 13.12.09 : Extended Phone Information 13.12.09 : ================================================ 13.12.09 : Product Serial Number: 0 13.12.09 : Product Code : 059D607 13.12.09 : Long Production SN : 0 13.12.10 : MCU SW Version : V 92PS1_10w46.9 01-03-11 RM-596 (c) Nokia 13.12.10 : RFIC Version : |Alli_4.3.4 13.12.10 : DSP Version : TB92PS1_10w46.4 13.12.11 : AHNE Version : 11 13.12.11 : RETU Version : 35 13.12.11 : TAHVO Version : 00 13.12.11 : Wireless LAN ID : 78:2E:EF:FB:FA:6F 13.12.11 : Bluetooth ID : 78:2E:EF:FA:C1:EF 13.12.11 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII 13.12.11 : 13.12.11 : ================================================ 13.12.11 : Simlock Information 13.12.11 : ================================================ 13.12.11 : Unable to read SP Data.. Your Phone does not have Simlock Data. Do you have PM 120 Backup? (Backup of FULL PM 0-400 Before you Downgraded the Phone) |
04-26-2012, 16:46 | #8 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @trn I can see on your Logs that you did not flash the phone correctly and you do not even have the Complete set of correct Flash Files for your phone.. You Manually loaded the flash files, and even tried to flash a VPL file to your phone.. But the biggest problem was, you did not make Simlock Backup of your fully working N8-00 before you tried to flash it with the wrong flash files... By default, simlock backup and rpl backup is checked in ATF software... You unchecked it before you flashed your phone :O((( |
04-26-2012, 17:44 | #10 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | C:\AdvanceBox Turbo Flasher\Nokia\backup\356988045701154\3569880457011 54_93415.rpl But you did not backup simlocks.... so this will not fix phone fully, unless you buy RPL from nokia |
04-26-2012, 18:09 | #12 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | I have seen the log files you sent me,,, You did not backup simlocks,, These backups you made have no simlocks inside them because they were done after you full erased the phone... |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
