08-12-2012, 23:28 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 319827 Status: Offline Thanks Meter: 3 | Help The following error C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__07.21.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM Secondary Sending Speed : 3250000 Hz Algorithm Sending Speed : 6500000 Hz Program Sending Speed : 6500000 Hz Message Reading Speed : 98000 Hz Number of Blocks : 944 Entry Point : 0x44FC Page Format : 128K Maximum Page Size : 0x00004000 Changing MODE : FLASH Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 28A00015 ID DWORD 1 : 51B46F56 ID DWORD 2 : 221A85B3 ID DWORD 3 : 16C818B6 ID DWORD 4 : 100E3D23 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum CA SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg Boot File - Version 010.042.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 002F -> 72NS256N Extended/Fixed ID : 0000 Revision ID : 6921 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : FFFFFFFFFFFFFFFFFFFF 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : F6 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :002F ExtID :0000 RevID :6921 Flash Descriptor Manufacturer Code : 0001 Device ID : 002F Extended/Fixed ID : 0000 Revision ID : 0000 Size : 02000000 (32 MB) VPP Info : 0009 Erase10s : 28 Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg Algorithm File - Version 010.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request No PAPUBKeysHash Returned Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : VARIANT ASIC Index : CMT 0 Certificate 3 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 03 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 A2 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x4E (78) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x4B (75) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00020000-0007FFFF 3 : 00080000-000DFFFF 4 : 00100000-001FFFFF 5 : 00200000-0031FFFF 6 : 00320000-0105FFFF 7 : 01060000-01067FFF 8 : 01068000-0107FFFF Erase_SendEraseBlock_BB5_NOR Task in Progress... Please Wait... STATUS_REQUEST_BB5... 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:04 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Flashing Speed: 5.00 Mhz Processing : rm217__07.21.mcusw Total blocks to write : 944 ================================================ FBUS Cable RX2 PIN Diagnostics ================================================ STATUS_REQUEST_BB5... 1 Sub Block ID : 16 PROGRAMMING_ERROR_BB5 Block Length : 0F BB ASIC Index : 00 Error Type : 05 Error Spec : 08 Of*****ng Address : 00000400 Expected Content : 0000933D Detected Content : 00009300 Reconnect your Cable Properly because RX2 PIN is NOT getting any DATA from the Box!!! ================================================ ERROR: RX2 PIN is NOT CONNECTED PROPERLY !!! ================================================ Flashing FAILED BB5_WRITE_FlashFile_0 Go to Settings --> Nokia Settings --> FBUS DDR&2TX Synchronization Timeout Change the current value selected to a higher value and Restart AdvanceBox.exe software to apply it Operations Failed.... |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
