Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > Advance-Box
Old 06-13-2010, 10:11   #1 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
help 1616 dead phone with phoenix - [Problem Solved - June-15-2010]
hi i have 1616 dead with phonix and flash it advanced still dead.
help.
VBATT OFF ...
VBATT ON
Setting VBATT Done!...
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 37888 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: c:\Program Files\Nokia\Phoenix\Products\RH-125\rh125_003.610
FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 03
FIRMWARE Erase Block: 0x00800000~0x00A0FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 2162688 bytes
Data Checksum: FC7C
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 03
FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE
Start Erasing...
Block Erase Done...
Data Size: 2074112 bytes
Data Checksum: 18E7
Processing Section 03 of 03
FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: c:\Program Files\Nokia\Phoenix\Products\RH-125\rh125_003.61ij
PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x00210000~0x004170BE
Start Erasing...
Block Erase Done...
Data Size: 2126016 bytes
Data Checksum: 1039
PPM Data Blocks uploaded to phone...
Processing Image File: c:\Program Files\Nokia\Phoenix\Products\RH-125\rh1250_nai03.61ij
CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00EB0000~0x00F060FE
Start Erasing...
Block Erase Done...
Data Size: 352512 bytes
Data Checksum: 19C1
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:02:15
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
MCU: V 03.61 29-01-10 RH-125 (c) Nokia
IMEI: 358234036693136
Product code : 0590495
Model : ð
Mastercode : 3455007773
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000030002
Asic : 11
Provider : Default Test Operator
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
Old 06-13-2010, 10:26   #2 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Model : ð
Asic : 11
I think phone is not DEAD.
br
Old 06-13-2010, 10:29   #3 (permalink)
shakeel145's Avatar
Member: 510445
brother changed lcd your lcd problem phone alive
Old 06-13-2010, 10:34   #4 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
help.
VBATT OFF ...
VBATT ON
Booting Phone...
TIME STARTS HERE
Start Erasing...
Block Erase Done...
Data Checksum: FC7C
Start Erasing...
Block Erase Done...
Data Checksum: 18E7
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
PPM Image Found...
Start Erasing...
Block Erase Done...
Data Checksum: 1039
Start Erasing...
Block Erase Done...
Data Checksum: 19C1
5, 4, 3, 2, 1...
Model : ð
Asic : 11
Try to cross flashing with 1800 files then check............
Guljee
Old 06-13-2010, 10:34   #5 (permalink)
Member: 777729
Sonork: 100.1616470
hi-
LCD OK
AND PHONE OK BEFORE IT.AND I WANT ONLY CHANGE LANGUAGE.
Old 06-13-2010, 10:41   #6 (permalink)
Member: 777729
Sonork: 100.1616470
Try to cross flashing with 1800 files then check.........TELL ME WHERE DOWNLOAD 1800
CANT FIND IN ATF
Old 06-13-2010, 11:00   #7 (permalink)
ktkwajid's Avatar
Member: 625961
Sonork: 100.1590447
change lcd its tested solution,
otherways try cross flashing
here is the 1800 flash file (torrent file)
4shared.com - online file sharing and storage - download RM-653_dp_v_03_50_MCUSW04_10.exe.torrent
The Following User Says Thank You to ktkwajid For This Useful Post:
Old 06-13-2010, 11:02   #8 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
check before then ask any question............
Uploaded with ImageShack.us
Guljee
The Following User Says Thank You to guljee786 For This Useful Post:
Old 06-13-2010, 11:03   #9 (permalink)
Member: 777729
Sonork: 100.1616470
Thanks test and report!!!
Old 06-13-2010, 11:08   #10 (permalink)
Member: 777729
Sonork: 100.1616470
uploaded with imageshack.us
guljee
thanks how to access to this page?
Old 06-13-2010, 11:22   #11 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Product support>>>flash file download>>>Full package flash file download Support........
Guljee
Old 06-14-2010, 09:33   #12 (permalink)
Advance-Box's Avatar
Member: 651945
@sirnavid2010
Your Logs show that you "unchecked" Factory Settings...
You see this:
You will have more problems if you do not Factory Reset.
B/R
The Following 4 Users Say Thank You to Advance-Box For This Useful Post:
Old 06-14-2010, 16:56   #13 (permalink)
Member: 777729
Sonork: 100.1616470
Thanks.i solve it.and thanks very much a-t-f box!!!!
Best in infineon nokia!!!
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
Powered by Searchlight © 2012 Axivo Inc.
- GSM Hosting Ltd. - 1999-2011
Page generated in 0.84730 seconds with 10 queries
