04-19-2014, 09:15 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | Help 610 Unlock JTAG Interface Connected, S/N 0xF8C43196 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 12/1/2013 4:18:00 PM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 15 Seconds after First Vibration <--- Very Important 4. Disconnect USB Cable from Phone 5. Click RESTORE BOOT Button Again OK i have flash the phone still same i have also delete ATFJ.ini file 100 times still same i have desolder tps 5 times still same any solution for it now please? |
04-19-2014, 10:17 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Solution: 1. Use ATFJ.exe v1.0.7 2. Use AFP file: C:\AdvanceBox Turbo Flasher\Phones\UNLOCK\LUMIA_610_610C_UNLOCK.afp 3. Triple check your JTAG connection and follow ATFJ.exe instructions. BR |
04-19-2014, 10:30 | #3 (permalink) |
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | Default language ID 0x0409 JTAG Interface Connected, S/N 0xF8C43196 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106210E1 IR4 Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:48:00 AM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...Timeout During Operation! Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:48:00 AM ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...Timeout During Operation! |
04-19-2014, 11:55 | #5 (permalink) | |
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | Quote:
Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...Unknown EFS2 Format Detected. Service Provider Codes Not Found. Is It Mean Already Unlocked? | |
04-19-2014, 12:03 | #6 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | You are using long cooper wires, pls shorten your copper wire length. Also, power on phone and then power it off properly: swipe your finger down the screen. After it, Read Codes again. BR |
04-19-2014, 12:47 | #7 (permalink) |
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | not too much long bro i already unlocked many lumia 610 with this cable, its almost 3 inches coper wires, i will short them more and post result my cable is 6 inch long only, copper wire 1 inch enough?, total will be 7 inch? |
04-19-2014, 20:23 | #8 (permalink) |
No Life Poster Join Date: Jan 2003 Location: GMT +5 Age: 49
Member: 19737 Status: Offline Thanks Meter: 133 | hi 1. flash phone using battery 2. after flash power on phone with battery 3. complete setup the phone with battery 4. after complete the setup and widows screen show 5. press power button and slide down to power off phone and wait 30 seconds 6. then pull out battery and unlock. 7. enjoy. br |
04-20-2014, 09:29 | #9 (permalink) |
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | i have get another lumia 610 and i have unlock it without any problem with the same cable here is screen shot why the 1st one make me crazy? |
04-20-2014, 10:34 | #10 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
BR | |
04-20-2014, 15:34 | #12 (permalink) | |
Freak Poster Join Date: Nov 2006
Member: 399239 Status: Offline Thanks Meter: 20 | Solution Quote:
B Metchure Before Posting ScreenShot Just remove Ur Box Serial Number Default language ID 0x0409 JTAG Interface Connected, S/N 0xF8C43196 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 12/1/2013 4:18:00 PM???? | |
04-22-2014, 17:40 | #13 (permalink) | |
Member: 19737 Status: Offline Thanks Meter: 133 | Quote:
Is your brain in your head ? Or not. I talking about lumia not any china. Is you have any problem with me or any china mobile then contact me via pm. I know i can solve your all problem. And please shut your ***** off next time in my posting to comments. | |
