09-04-2013, 16:35 | #1 (permalink) |
Insane Poster Join Date: Apr 2008
Member: 758627 Status: Offline Thanks Meter: 14 | Help ATF BusCheck error & Scan OK Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... ERROR: Phone did not Boot !!! Make sure that you plugged the cable to the RJ-45 Port Marked << EXTENSION >> ======================================= || FLASHBUS EXTENSION || || ======= ======= || || | | |\ /| || || | | (O) (O) (O) | CABLE | || || | | |/ \| || || ======= ======= || || || ======================================= ^ ^ ^ | | | | | | PLUG IN CABLE HERE Try booting this phone with "Live Phone" option Check the option beside the "Scan Phone" button Flashing ERROR MCU: V 07.00 11-09-12 RM-647 (c) Nokia IMEI: 356340050301100 Product Serial Number: FC1C5E5AH Product Code : 0593094 Module Code : 0204496 Basic Production Code: 059R059 PPM SW Version : V 07.00 11-09-12 RM-647 (c) Nokia MR ADSP Version : p V 07.00\n11-09-12\nRM-647\n(c) NMP\nmr MCU SW Version : V 07.00 11-09-12 RM-647 (c) Nokia HW Version : 1005 UEM Version : 1328 UPP Version : 8850 LCD Version : WIN:SERI:91 NT7542 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED |
09-04-2013, 16:45 | #3 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | ATF Nitro on 1616 RH-125 via ATF Software 10.11 and LogiCore 10.3.80 Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** START INFINEON BUS CHECK ****************************************************** Sending PBL 37888 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v ****************************************************** INFINEON BUS CHECK DONE ****************************************************** MCU: V 06.53 14-09-11 RH-125 (c) Nokia IMEI: 352723046433042 Product Serial Number: 00A0438AI Product Code : 059B7C7 Module Code : 0204343 Basic Production Code: 059B7Z8 PPM SW Version : V 06.53 14-09-11 RH-125 (c) Nokia UA ADSP Version : p V 06.53\n14-09-11\nRH-125\n(c) NMP\nua MCU SW Version : V 06.53 14-09-11 RH-125 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 8850 LCD Version : TPO:BOHAIv80 HX5081 ********** SIMLOCK INFO ********** CONFIG_DATA : 2340000100000000 PROFILE_BITS : 8000000000030002 ASIC : 11 PROVIDER : British Telecom;UK [GSM] Block [1] 1:Close 2:Close ST_LCD_TEST : PASSED Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... |
09-04-2013, 16:46 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | ATF Turbo (BIG METAL CHROME BOX) Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** START INFINEON BUS CHECK ****************************************************** Sending PBL 37888 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v ****************************************************** INFINEON BUS CHECK DONE ****************************************************** MCU: V 06.53 14-09-11 RH-125 (c) Nokia IMEI: 352723046433042 Product Serial Number: 00A0438AI Product Code : 059B7C7 Module Code : 0204343 Basic Production Code: 059B7Z8 PPM SW Version : V 06.53 14-09-11 RH-125 (c) Nokia UA ADSP Version : p V 06.53\n14-09-11\nRH-125\n(c) NMP\nua MCU SW Version : V 06.53 14-09-11 RH-125 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 8850 LCD Version : TPO:BOHAIv80 HX5081 ********** SIMLOCK INFO ********** CONFIG_DATA : 2340000100000000 PROFILE_BITS : 8000000000030002 ASIC : 11 PROVIDER : British Telecom;UK [GSM] Block [1] 1:Close 2:Close ST_LCD_TEST : PASSED Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... What type of cable are you using? |
09-04-2013, 16:56 | #5 (permalink) | |
Member: 758627 Status: Offline Thanks Meter: 14 | Quote:
Fbus2 and Fbus n1616 GPG. | |
09-04-2013, 18:12 | #10 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | ATF 10.11 Big Chrome Metal Box Test Nokia 1616 126 with fbus TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RH-126\rh126_005.800 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 822C Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1783808 bytes Data Checksum: 5F10 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RH-126\rh126_005.80ub PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x003D5D7E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1858944 bytes Data Checksum: E268 Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RH-126\rh1260_nai05.80ub CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00F003BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 328640 bytes Data Checksum: 1C8F Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:02:28 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 05.80 08-06-10 RH-126 (c) Nokia IMEI: 012821000343603 Product Serial Number: GFW738891 Product Code : 059C1R3 Module Code : 0204344 Basic Production Code: 059C7B9 PPM SW Version : V 05.80 08-06-10 RH-126 (c) Nokia UB ADSP Version : p V 05.80\n08-06-10\nRH-126\n(c) NMP\nub MCU SW Version : V 05.80 08-06-10 RH-126 (c) Nokia HW Version : 4003 UEM Version : 1328 UPP Version : 8850 LCD Version : UNKWN: IDs: 00:00:00 ********** SIMLOCK INFO ********** CONFIG_DATA : 7223100000000000 PROFILE_BITS : 800000000003000B ASIC : 11 PROVIDER : AMX Argentina S.A;Argentina [GSM] Block [1] 1:Close Block [2] 1:Close Block [3] 1:Close ST_LCD_TEST:OK FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Br Polaco |
09-04-2013, 18:12 | #11 (permalink) |
09-05-2013, 04:35 | #12 (permalink) |
Member: 758627 Status: Offline Thanks Meter: 14 | Rehot the legs -ATF on PC Code: ============================================== ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drivers.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ****************************************** INIT : FAILED , CHECK YOUR BOX FIRMWARE ****************************************** [/QUOTE] |
