02-05-2014, 13:00 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | HeLP, ATF NOT WORKING AFTER JTAG ACTIVATION - [SOLVED] HERE IS THE LOG: JTAG Module: NOT ACTIVATED JTAG Module Activation Cost: 39 Credits JTAG Credits Available: 39 Credits JTAG Module Activation Request Successful! JTAG Module: ACTIVATED ERROR: JTAG Activation Failed! |
02-05-2014, 13:23 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, do this: 1. Uninstall ATF Software 2. Install ATF Full Setup v11.00 from this link: http://forum.gsmhosting.com/vbb/10068252-post2.html 3. Run this batch file: C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 4. Reconnect ATF Box on USB 5. Install ATF BOX DRIVERS manually from here: C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS 6. Open AdvanceBox.exe and follow instrcutions to Update Box Firmware to latest v11.00. If you have updated before - skip this step... 7. Open ATFJ.exe from here: C:\AdvanceBox Turbo Flasher\ATFJ.exe Your box will be activated automatically. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
02-06-2014, 08:48 | #3 (permalink) |
Member: 1507693 Status: Offline Thanks Meter: 131 | bro Angel i did as you said, i unistalled old version and remove atf drivers, did a reboot but Atf is automatically installing drivers then on device manager shows this it only shows USB SERIAL CONVERTER A and USB SERIAL COVERTER B, but atf software shows no box connected |
02-06-2014, 08:54 | #4 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Restore the EEPROM ... All will OK Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
02-06-2014, 10:03 | #7 (permalink) |
Member: 1507693 Status: Offline Thanks Meter: 131 | bro Angel i did as you said, i unistalled old version and remove atf drivers, did a reboot but Atf is automatically installing drivers then on device manager shows this it shows USB SERIAL CONVERTER A and USB SERIAL CONVERTER B but Atf software still cant find box, pliz help, i remove all ftdi drivers from my machine |
02-07-2014, 04:01 | #10 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | 1. You need to install drivers for USB SERIAL CONVERTER A and USB SERIAL CONVERTER B Drivers can be found here: http://www.ftdichip.com/Drivers/CDM/...0Certified.zip ** After drivers are 100% ok, and device manager shows that it is properly installed, then that is the time you do: Product Support ---> Box Tools ---> Restore EEPROM After RESTORE EEPROM, disconnect ATF BOX, then reconnect it. It will be detected correctly now. To Activate JTAG , you just need to run latest version of ATFJ.exe. It will automatically activate your BOX if you already paid for activation. B.R. |
