05-19-2015, 10:30
#1 (permalink)
Member: 172448
Thanks Meter: 5 | Help , Gt-i9060 dead hi supporter
my gt-i9060 dead after write bootloader part
i have no download mode and device manager show me a unknown device !!
how repair this phone ???
this is my log : Quote:
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 1501004B3758564D420359D6D8C28129
CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Boot Information
Revision 1.6 (for MMC v4.5, v4.51)
BOOT PARTITION : BOOT PARTITION 1
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 3072 KB
HC ERASE GROUP SIZE: 512 KB
USER AREA SIZE : 7818182656 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 512 KB
eMMC Device Information
Manufacturer ID: SAMSUNG
Device Type : Embedded BGA
Application ID : 00
Product Name : K7XVMB
Product Rev : 0.3
Product SN : 59D6D8C2
Manufactured : January 1998
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 13 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
1501004B3758564D420359D6D8C28129.ext_csd
Backup Directory:
E:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
Start Writing Flash Images...
Flash Image: MBR + PGPT
Start Writing 0x00000032 Blocks at 0x00000000
Partition Selected: USER AREA
Total Elapsed Time 00:00:00
Write Success!
Flash Image: PIT
Start Writing 0x00000007 Blocks at 0x00000022
Write Success!
Flash Image: SGPT
Start Writing 0x00000021 Blocks at 0x00E8FFDF
Write Success!
Flash Image: bcmboot.img
Start Writing 0x00000200 Blocks at 0x00000000
Partition Selected: BOOT 1
Write Success!
Flash Image: sboot.bin
Start Writing 0x00000600 Blocks at 0x00000200
Total Elapsed Time 00:00:01
Write Success!
Flash Image: param.lfs
Start Writing 0x00004000 Blocks at 0x0000EE00
Total Elapsed Time 00:00:13
Write Success!
Total Images Written: 3
Process Done! | Quote:
Interface Reset OK!
BOOT PARTITION : NOT BOOT ENABLED
Application ID : 00
Product Rev : 0.3
Card Specific Data
TAAC : 13 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
Setting Boot Partition to BOOT1
Task Done! | |
