Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 05-03-2015, 22:53   #1 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 84
help with huawei g730 emmc
hi
i got g730 u10 dead
i found pinouts and connection is ok
but emmc is sandisk and i dont have boot files dump
now my question is can i make dump from official flash file??? or flash file via emmc??? like samsung tar/md5
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 45010053454D30344728059CF08B315B
CSD : D00F00320F5903FFFFFFFDFF8A4040A7
eMMC Boot Information
Revision 1.6 (for MMC v4.5, v4.51)
BOOT PARTITION     : BOOT PARTITION 1
PARTITION ACCESS   : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT  : DISABLED
BOOT MODE          : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH    : ENABLED
eMMC FirmW UPDATE  : DISABLED
EMMC CACHE SIZE    : 0 KB
SUPER PAGE SIZE    : 4096 KB
HC ERASE GROUP SIZE: 2048 KB
USER AREA SIZE     : 3959422976 BYTES
BOOT PARTITION SIZE: 2048 KB
RPMB PARTITION SIZE: 2048 KB
eMMC Device Information
Manufacturer ID: SANDISK
Device Type    : Embedded BGA
Application ID : 00
Product Name   : SEM04G
Product Rev    : 2.8
Product SN     : 059CF08B
Manufactured   : January 1998
Card Specific Data
CSD_STRUCTURE     : Extended
SPEC_VERS         : Version 4.1/4.2/4.3
TAAC              : 3 ns
TRAN_SPEED        : 4000000 KHz
READ_BL_LEN       : 512 Bytes
C_SIZE            : HIGH CAPACITY
WP_GRP_ENABLE     : YES
WRITE_BL_LEN      : 512 Bytes
CONTENT_PROT_APP  : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Old 05-03-2015, 23:26   #2 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 84
when i try to read emmc log windows blinks and only retries!!!!
why???and after a few retries 4in1 adaptor led turns off and again turn on and log windows blink again and retries and i stop operation
Old 05-04-2015, 10:35   #3 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 84
anyone knows why retry loops happening???
Old 05-04-2015, 17:34   #4 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 84
Anyone?......support,.......
Old 05-05-2015, 21:00   #5 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
User area size : 3959422976 bytes
Old 05-05-2015, 23:15   #6 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 84
i dont know what is wrong too maybe emmc damaged
this is easy jtag log
look at emmc date
easyjtag : EMMC Date: 03/2014 Rev.0x28
atf : Manufactured : January 1998
wtf i cant read and i cant write to this emmc with both tools..
when i read i get retry loops
Z3X EasyJtag Software ver. 2.0.0.0
Loading eMMC Addon Firmware... IO: 3300 mV
Box S/N: 07009009xxxxxxxxx5, ,FW Ver.: 01.52
CMD Pullup Level:2062 mV
CMD Active Level:2485 mV
EMMC CID : 45010053454D30344728059CF08B315A
EMMC CSD : D00F00320F5903FFFFFFFDFF8A4040A6
EMMC Manufacturer ID: 0045 , OEM ID: 0100
EMMC NAME: SEM04G , S/N: 94171275
EMMC NAME (HEX): 53454D30344700
EMMC ROM1 (Main User Data) Capacity: 3776 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48.
Backup saved: SEM04G_ 94171275_20150402_0008.extcsd
Done.
Old 05-06-2015, 00:02   #7 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 84
i can write but cant read.....its getting me crazy
Old 05-07-2015, 23:12   #8 (permalink)
Member: 447517
Thanks Meter: 22
i have galaxy wonder with same emmc ,,, it can read but cant write... now i try erase with direct emmc conection.. all ok.. but now i can write and phone completely dead... and in your phone i think emmc problem like i have.. before direct conection.. if i erase with riff box 100% complete.. but phone still alive and not affect with erase proces..
The Following User Says Thank You to medariy For This Useful Post:
Old 05-08-2015, 01:38   #9 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 84
I can write but cant read ....
Dont know maybe its not supported completely..?or emmc damaged
Old 06-11-2015, 19:25   #10 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 84
bump...
anyone have emmc dump for g730 ???
Old 06-13-2015, 03:56   #11 (permalink)
madgoeslim's Avatar
Member: 1853929
Sonork: 1653495
Thanks Meter: 423
Just replace emmc with new one.
Because this is MTK devices, and preloader checking serial of the emmc, so you can only use specific Emmc.
You can use SkHynix H9TP32A8JDAC,
or use Samsung KMKJS000VM-B309,
or sandisk like you found in your board.
You don't need write full dump to this device.
Just write extcsd, and flash the rest with SPflashtool.
when you write bp1, and connect to pc, it should be known in pc as preloader device, and flash rom in spflashtool.
Here all you need to write in new emmc.
Gud Luck..
The Following 2 Users Say Thank You to madgoeslim For This Useful Post:
Old 09-18-2015, 21:21   #12 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 114
any body have G730 emmc pinout for share?
Old 09-23-2015, 19:38   #13 (permalink)
Member: 1887569
That code for write in eMMC applies to any model of G730??
(L075, U00, U30, C00, U10, U251)
Old 01-30-2016, 15:38   #14 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 425
@oktay50000
@madgoeslim
Sir Plz Share EMMC Pinouts
Thanks Anticipation
Old 02-01-2016, 14:40   #15 (permalink)
Member: 1887569
Red face Please Help
Please oktay50000...
Share pinout !!
Originally Posted by oktay50000 View Post
hi
i got g730 u10 dead
Interface Reset OK!
Application ID : 00
Product Rev    : 2.8
Card Specific Data
TAAC              : 3 ns
WP_GRP_ENABLE     : YES
The Following User Says Thank You to cheche358 For This Useful Post:
Page generated in 0.38831 seconds with 7 queries
