05-23-2015, 04:36 | #1 (permalink) |
Junior Member Join Date: Aug 2012
Member: 1799810 Status: Offline Thanks Meter: 1 | Help Lumia 1020 no Wifi, Bluetooth, FM Radio after flash ..... ..... ..... ..... Wifi ..... ..... Bluetooth ..... ..... FM Radio |
06-30-2015, 13:56 | #2 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2419246 Status: Offline Thanks Meter: 0 | I have the exact same problem........ : ((((( Tryed flashing to older(8.0 WP) - no effect, only longer delay in auto-off for not working wi-fi and bluetooth. Next to try- check for hardware antenna connection on motherboard- but when my new front glass arrives. p.s.: My RM-875 is second hand with broken front glass, so I do not know the story. |
07-02-2015, 08:18 | #3 (permalink) |
Member: 2419246 Status: Offline Thanks Meter: 0 | Update Antenna connection checked- no problem found: ( Downgraded to generic firmware ver. 1.0, it also downgraded radio firmware- no good effect, now wi-fi is infinitely turning on(still not working) Last edited by almosthumanrs; 07-02-2015 at 08:23. |
12-20-2015, 21:19 | #4 (permalink) |
Junior Member Join Date: Dec 2015
Member: 2503759 Status: Offline Thanks Meter: 0 | Good time! I had the same problem, Decided problem corrects itself. I entered in the "##3282#" has selected 2G and everything working again! After a while, I did a hard reset. That's all. The problem returned. The problem accurately in the software, can anyone have a way to solve it? |
12-21-2015, 22:59 | #5 (permalink) |
Member: 2503759 Status: Offline Thanks Meter: 0 | Dear friends! The solution to this problem following! Warm hot air 350 * C chip Qualcomm PM 892. This power controller. I helped to solve this problem the guys from XDA sealed copper foil |
