01-05-2014, 10:11 | #1 (permalink) | ||
No Life Poster Join Date: Feb 2008 Location: ALGERIA
Member: 714722 Status: Offline Thanks Meter: 33 | Help lumia 800 boot change - [SOLVED] Quote:
01-06-2014, 09:12 | #3 (permalink) |
Member: 714722 Status: Offline Thanks Meter: 33 | all is ok please wheris the probleme i'am not activate the jtag in my atf i yhink not important for do that and i'am anew user of atf i havan't mor experiance oi it and i need to change the boot to quelqom dload thanks for help |
01-06-2014, 10:58 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | You do not need Test Points to change boot loader. It can be now done via USB cable: http://forum.gsmhosting.com/vbb/f609...steps-1580402/ |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
01-07-2014, 10:00 | #5 (permalink) | |
Member: 714722 Status: Offline Thanks Meter: 33 | Quote:
http://forum.gsmhosting.com/vbb/9004471-post6.html THANKS | |
01-07-2014, 10:34 | #6 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote: BR | |
01-07-2014, 14:17 | #7 (permalink) |
Member: 714722 Status: Offline Thanks Meter: 33 | but the phone it dead now after playing withe test point repair and not conected by usb and volume up and i have bay the atf nitro please it need to do this modification or no For ATF Nitro, you need some small modification to give Power to eMMC socket via RJ-45 PIN 2 (the pin beside VBATT PIN 1). Needless to say, if you modify your Nitro Box, you will loose warranty. So just decide for yourself if you need to modify or you want to buy external power supply instead. Anyway, here is modification needed, just look at light blue encircled area... you will see a very thin wire connected to PIN 2 of RJ-45. thanks for help |
01-08-2014, 10:34 | #8 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, Your box does not need any modification. Repair Boot to alive phone again, since it was stopped during Boot Change because of BAD SOLDERING. BR |
01-13-2014, 10:30 | #10 (permalink) | |
repairs Boot via eMMC - both are different, lumia 710/ 800 does not requires ATF JTAG. But for all the rest of lumia, JTAG is needed for JTAG Boot Repair. | |
